10-30-2005, 08:30 AM | #1 |
Member#: 11808
timing belt replacement cost?
I would like to know what people are paying to have the timing belt & water pump replaced on a SOHC 2.5L engine.
10-30-2005, 09:04 AM | #2 |
Member#: 35584
South East
Vehicle:1965 FFR Roadster Coyote + TR-6060 |
Wirelessly posted (Treo 600: Mozilla/4.0 (compatible; MSIE 6.0; Windows 95; PalmSource; Blazer 3.0) 16;160x160)
??$$ DIY, is always the best price. The belt and pump are going to run close to $300. |
10-30-2005, 10:09 AM | #3 |
Member#: 32846
Vehicle:1998 Impreza L-SOLD Arcadia Green |
I think that's a subjective question, but:
Labor would be variable anywhere from 3-6 hours at $75/hour $225-$450 Subaru Water Pump: $88 Subaru T-belt: $59.95 ----------------------------- Total: $350 - $600 would be my guess. And then you might as well replace the seals... -Charles- |
10-30-2005, 01:26 PM | #4 |
Member#: 82841
Any idea about the cost if a Subaru garage did the job?
10-31-2005, 10:07 AM | #5 |
Member#: 19470
SWIC
Vehicle:1981 Brat GL Blue |
They're going to charge the going rate for labor. Usually they have it posted, it's somewhere in the $70-80 /hr region.
01-08-2006, 03:50 PM | #6 | |
Member#: 41870
Vehicle:2003 WRX-Wagon Blue |
Arm and a Leg and First and Second born and wife also
01-08-2006, 07:46 PM | #7 |
Member#: 11808
My dealer quoted 5-$600 for the T-belt alone and another $100for the WP. I bought a " NEW" Bosch water pump at PepBoys for 49.95 and an OEM belt for $69.95 or 59.95 and did the job myself with the help of a friend (who has a better back than mine). I also carefully checked all the idlers, oil pump and seals for leakage. I replaced the thermostate, coolant hoses and drive belts at the same time. I used ALL OEM parts except the WP and the complete job was about $190. You mush be machanically inclined to do this job as it is not a good place to practice. Go to www.endwrench.com and they have a file on how to do it correctly.
01-09-2006, 01:39 PM | #8 | |
Member#: 30669
Vehicle:1998 Legacy 2.5GT Silver Sleeper BK, 5MT |
The Bosch water pump is fine after a year and ~20K miles. I figure it is about 2 hours work for the whole thing. Add in a front crank seal while doing it and check the cam seals before starting. |
01-10-2006, 08:58 PM | #9 |
Member#: 13910
Vehicle:2005 Legacy GT blue |
holy heck $800 just for the timing Belt :-/
Similar Threads | ||||
What should a timing belt job cost? | Alex Wetmore | North West Impreza Club Forum -- NWIC | 19 | 06-11-2009 09:39 AM |
Water pump replacement at second timing belt replacement? | doobie | Service & Maintenance | 1 | 10-19-2007 12:12 PM |
What else to replace while doing timing belt replacement? | the_glassman | Normally Aspirated Powertrain | 3 | 04-16-2006 11:58 AM |
Timing Belt Replacement - Hours or Cost? | lumpy | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 9 | 08-08-2005 10:24 PM |
Belt Replacement Cost ?? | Chris Cuevas | Service & Maintenance | 10 | 04-28-2005 09:14 AM |
