01-10-2018, 11:35 PM | #1 |
Member#: 480408
Oil consumption question
I was wondering how much is a typical oil consumption rate I recently bought a new 2017 2.5l and im burning a lot of oil. My dealer says its normal
01-11-2018, 12:58 AM | #2 |
Member#: 460907
RMIC
Vehicle:2020 Golf GTI |
Brand, brand new, like as in break in new, it's acceptable to eat some oil. But after the first thousand miles it shouldn't have oil consumption issues. How much oil is burning? What car do you have? How many miles/oil changes?
01-11-2018, 05:40 AM | #3 |
Member#: 480068
South East
Vehicle:2018 WRX Crystal Pearl |
+1 on this. Almost every owners manual of various manufacturers I have ever read has an oil consumption disclaimer. Something like "It is normal for an engine to consume 15 gallons of oil between change intervals." The 15 gallons is sarcasm, but it is to cover their butts in the event you get a "burner" fresh off the lot new. I luckily have never had this issue, but I have had friends that have. I would check your owners manual, but usually the manual says like 1-2 quarts between changes, which in my opinion is unacceptable in this day and age. I could understand 30 years ago, but with the manufacturing technology and tolerances they can achieve today it is just bunk.
01-11-2018, 01:56 AM | #4 |
Member#: 475697
As I understand it, Subaru has an "Oil Consumption test" you can request be done. There is also an acceptable limit of oil burning per miles that the dealer should be able to tell you.
Apparently this was an issue that was supposed to be fixed in 2016 from my research. |
01-11-2018, 07:19 AM | #5 |
Add Lightness
Moderator Member#: 13699
NESIC
Vehicle:2021 Building It Better |
The engine in the '17 is new compared with the FB20 from 2012-2016. With the older engine, the test is to change the oil and drive 1200 miles. If the level drops 10 ounces or more, the short block is replaced.
How many miles on the car? How much is "a lot of oil"? With the upside down oil filter, if you change the oil and add until it's at the top of the dipstick and don't recheck after the car runs, it's going to be down a bit and you should add enough to bring it up to level. |
01-11-2018, 08:00 AM | #6 |
Member#: 767
Tri-State
Vehicle:04 FXT 20 OB Onyx XT |
2.5L is N/A Foz/Legacy/Outback but fill out your profile and provide more details please. Regardless, I believe this info is the same in all manuals.
• Engine Oil Consumption Some engine oil will be consumed while driving. The rate of consumption can be affected by such factors as transmission type, driving style, terrain and temperature. Under the following conditions, oil consumption can be increased and thus require refilling between maintenance intervals: • When the engine is new and within the break-in period. ... Under these or similar conditions, you should check your oil at least every 2nd fuel fill-up and change your engine oil more frequently. Different drivers in the same car may experience different results. If your oil consumption rate is greater than expected, contact your authorized SUBARU retailer who may perform a test under controlled conditions." Check the manual for all conditions listed. https://stis.subaru.com/proxy/130146...A-BSTIS_16.pdf |
01-11-2018, 09:05 AM | #7 | |
Member#: 428511
Vehicle:2016 STI |
now at 52,000 it still consumes zero between 5k intervals In it's first 800 miles (first change) it consumed a whole quart. |
01-11-2018, 08:55 PM | #8 |
Member#: 472037
MWSOC
Vehicle:2018 WRX Limited CWP |
I think subaru standard is 1/3qt per 1200 miles. If more than that it's considered excessive.
01-12-2018, 09:56 AM | #9 |
Member#: 480408
My car is a 2017 crosstrek with about 6500 miles on it. The first 4000 miles it was burning about 1 quart every 1000 miles. It has lowes a little recently but not to an acceptable level. I have taken it back to my dealer and done the oil consumption test. Each time the dealer fills it over the top fill mark by about a quarter inch and it will be half way between the top and bottom mark when i bring it back in 1200 miles. The dealer says its fine and it's what Subaru do and they will refill it any time I bring it in.
Even of it is normal I agree in this day and age it is not acceptable. I also own a '66 Ford that leaks from every gasket and I still don't have to add oil between changes. I don't know what to do now. |
01-12-2018, 12:28 PM | #10 | ||
Member#: 30669
Tri-State
Vehicle:1998 Legacy 2.5GT Silver Sleeper BK, 5MT |
If you have never dealt with a flat engine, yes, oil burn tends to be higher than what you may be used to. |
01-12-2018, 03:05 PM | #11 |
Add Lightness
NESIC
Ok, so a 17 Crosstrek is exactly the same as my 13 Crosstrek. Give it several oil changes. Ours used a lot of oil at first and slowly got better. I will have the oil check done somewhere in the 90k mile area. Already gone through one expendable CVT. Once the warranty on it, extended by Subaru expires at 100k miles, that thing is gone. The FB20 is also warrantied to 100k miles because of the oil consumption settlement.
You've got a 2.0 by the way....not a 2.5. |
01-12-2018, 07:56 PM | #12 | |
Member#: 475983
Vehicle:2018 WRX Limited Silver |
01-14-2018, 09:44 PM | #13 | |
Add Lightness
NESIC
I don't know if there were design changes to solve the oil consumption issue during the run of FB engines. |
01-12-2018, 08:20 PM | #14 |
Member#: 459629
International
Vehicle:2017 WRX base WR Blue |
Surprisingly my '17 WRX has never used a measurable amount of oil since new. And it saw boost way before it should have according to manual. Not for any extended time a few seconds at most in low gears. It's been my experience rings babied too much lead to a weak seating and blowby.
01-12-2018, 11:41 PM | #15 |
Member#: 480408
I realized right after I posted that I have the 2.0. And my spell check makes me sound illiterate so I apologize if I sound uninformed . I also have noticed in the past that cars that are babied seem to have more issues and not only Subarus. This o e has not been babied nor abused. It had 8 miles on it when we got it so it shouldnt have had much abuse before we got it. What is the consensus of the people out there, if the manual says 6000 miles for oil changes under normal conditions how many quarts is acceptable between oil changes. My opinion is that it should be none between. I have owned several other Subarus with no issues and they were perfect. I bought this for my daughter to take off to college and was hoping for trouble free times.
01-13-2018, 02:52 AM | #16 |
Member#: 459287
VIC
Vehicle:1998 JDM Impreza STi V4 GF8 White |
Use NO oil in 6000 miles?
01-13-2018, 07:59 AM | #17 | ||
Member#: 30669
Tri-State
Based on that, a quart added and maybe getting close to another one at change time. So, 6K changes, 2 added and getting close at change time. Quote:
Type of oil, oil viscosity, miles on engine are all part of the consumption. |
01-13-2018, 11:19 AM | #18 |
Member#: 88514
HIIC
Vehicle:2010 Outlander XLS Brown Metallic |
So this is still a thing huh? They couldn't figure it out in almost 6 years?
01-13-2018, 11:29 AM | #19 | |
Member#: 30669
Tri-State
As I stated, flat engines "in general" burn more oil than an engine with the cylinders more upright. This is automotive as well as aircraft (I do some aircraft maintenance as well as fly), it's a part of the basic engine design. Some oil lays in the horizontal cylinder after shutdown and seeps past the rings. Then gets burned on startup. Some burn more than others, but flat tends to burn more than other designs. |
01-13-2018, 12:04 PM | #20 | |
Member#: 472037
MWSOC
01-14-2018, 09:25 PM | #21 |
Member#: 99707
MWSOC
Vehicle:2018 WRX Premium CWP |
01-15-2018, 07:19 AM | #22 |
Member#: 472037
MWSOC
01-15-2018, 12:07 PM | #23 | |
Member#: 428511
Vehicle:2016 STI |
people that get sludgy engines get them because they drive 1.5 miles at a time at 20% throttle or less and never get the engine hot like the ads you see selling grandma's 2003 camry with 'only' 13,000 miles on it, and then they state how it was only used once a week to go 1/2 mile to and from the store. For some reason people think that's a good selling point. I wouldn't touch a car like that with a 10' pole. |
01-15-2018, 09:41 AM | #24 | ||||
Member#: 21145
NESIC
Vehicle:2002 Enemy of Aku |
People who tend to beat the piss out of their cars on a daily basis tend to "burn out" the engine rather quickly, compared to those who don't. This is why you see so may people complaining that after 60K ( or less ) they need a complete engine rebuild, as opposed to those who go 150K, 200K and more on the same engine. |
01-13-2018, 02:59 PM | #25 |
Member#: 475983
I break them in a little softer and all my Subi s get a 5-6000 synthetic oil change with zero added oil. I had four 2.5s and my first 2.0 has 1700 miles and used no oil so far. Most of those 2.5 s never saw read line. I also had a flat 6 911 and that got some higher RPM time and used no oil either. I think the majority don t use much oil but the few that do will be posted all over the place for obvious reasons.
