Welcome to the North American Subaru Impreza Owners Club Tuesday December 11, 2018
Old 02-20-2008, 11:23 PM   #1
SubarNoober
Member#: 133261
Default When doing a timing belt change on an EJ22...
Should I necessarily replace the oil pump? The waterpump?
What else do you suggest and
1) why?
2) what's the cost factor?
SubarNoober is offline   Reply With Quote
Old 02-21-2008, 12:41 AM   #2
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
How many miles on it? I don't change anything unless it needs it. It might be nice to have cam and crank seals handy should you need them.
Tim Sanderson is offline   Reply With Quote
Old 02-21-2008, 12:45 AM   #3
SubarNoober
Member#: 133261
Miles, good point...
It's at 140k.
Old 02-21-2008, 01:10 AM   #4
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
replace water pump. Oil only if its leaking. My 2 cents. Oh yeah, the cam seals if they are leaking.
reddevil is offline   Reply With Quote
Old 02-21-2008, 01:13 AM   #5
my4isflat
Member#: 120002
2000 2.5 RS, '95
Legacy w/325k mi (RIP)
I wouldn't worry about the oil pump. On everyone of the high mileage Subarus I've owned never once was one changed (325,000mi, 200,000mi and as of now 166,000mi). And out of those three cars only one had the water pump changed, the one with the lowest miles. The water pump was fine, I just did it for peace of mind, as do most others.
I would go ahead and replace the idlers and the tensioner though. They will, if not already, get noisey, and worst case fail (once again peace of mind). The tensioner should be looked at as a wear item too, you don't want the belt to skip a tooth or come off. If you have the time and money seals are a good idea, especially cam seals on your 2.2.
I'm not going to do the homework for you, but a rough estimate would be somewhere around $300 for all the parts, give or take a few. I guess to sum up a long story if nothing is broken you can get away with just the belt. All the other parts are just for peace of mind.
my4isflat is offline   Reply With Quote
Old 02-21-2008, 01:15 PM   #6
Guerice
Member#: 51519
2006 2.5i Wagon
AKA Drtywgn
I will never say it enought, change all the timing belt idlers and the tensionner. I didnt and on my yearly trip, one of the idlers cooked it's bearing and came out the front of the engine. Trust me it wasnt worth the price of the part to have a pissed off gf nagging at me
Guerice is offline   Reply With Quote
Old 02-21-2008, 01:22 PM   #7
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
I'd recommend replacing the o-ring that connects the oil pump & block. Also, the screws on the backing plate of the pumps can sometimes back out. If you're in there, I'd replace the o-ring and check the screws. It also makes changing the front crank oil seal easy.
Here's some pics from my timing belt job that shows the oil pump & backing plate, etc
http://www.main.experiencetherave.co...ges/timingbelt
Legacy777 is offline   Reply With Quote
Old 02-21-2008, 02:44 PM   #8
SubarNoober
Member#: 133261
Thanks to all for the help. Much appreciated. I think I'll follow the advice around new tensioners, but I'll ask in a separate thread so it's easier for others to find in the future.
any mods to do with timing belt change? (2.2L) darkwaterz Normally Aspirated Powertrain 9 04-28-2008 06:36 PM
When do the timing belt/water pump need to be replaced? Bilybobjef Service & Maintenance 10 07-08-2007 10:52 PM
EJ22 has shorter timing belt change interval? pieces Service & Maintenance 3 04-15-2005 04:02 PM
When should the timing belt be changed? Cajual Legacy Forum 5 05-28-2002 01:33 PM
about buying an used car and timing belt change cj917 New England Impreza Club Forum -- NESIC 1 01-14-2002 05:59 PM
