Welcome to the North American Subaru Impreza Owners Club Sunday March 26, 2023
Old 08-10-2006, 04:14 AM   #1
Marc5000
Member#: 94894
2002 Impreza WRX
Platinum Silver Metalic
Default Need help with FMIC BOV install with wrong application
ok before I start.. please don't just tell me to get the right one. I'll do that on my own if I absolutley have to... I just want to know if there is an alternative...
now here's the thing.. I have a FMIC on an 02 WRX and I bought the APS FMIC BOV but the site I got it from did not specify that there was a different application for the different year models so they sent me the application for MY01-05 when I need the MY97-00 which should look like this...
But I have the one that looks like this....
As you can see, the BOV return hose will not fit onto that because it does not have that piece that the hose can pushed over... Is there something I can do even if I can buy a part from the dealer from a later year WRX to make my hose fit that?
Thanks,
Marc
Marc5000 is offline   Reply With Quote
Old 08-10-2006, 04:28 AM   #2
kenny08
Member#: 79907
02 blue wagon
18g goodnesss
go to autozone, buy a rubber longer rubber hose thats the same size as the bov return hose, and some couplers. simple.
kenny08 is offline   Reply With Quote
Old 08-10-2006, 05:16 AM   #3
Marc5000
Member#: 94894
2002 Impreza WRX
the one that I have is the bottom picture... The return hose should be hooked up to where the 2 hex screws are where you see the gold piston... I think you're either looking at the wrong picture or you're looking at the bottom part of the picture in the bottom pic...
the bottom part in the bottom picture is what goes to the intercooler piping.. I'm not worried about that.. but you're absolutley right about that part.. thats what I'll be doing.. but wrong part you're lookin at ;-)
Old 08-10-2006, 05:43 AM   #4
WRXfirefighter26
Member#: 112366
2006 STI
Dirt over Obsidian Black
The hole where you can see the gold piston is where you screw on the elbow from the stock recirculating valve. Just unscrew it from the stock one and put it on the new one using the hex bolts. I still have a stock TMIC and I am pretty sure that most FMIC's keep the bov in the same general location for the exact reason of keeping it close to the return line. There were no extra parts so I was running the bov at 100% atmospheric until I took my car to get dyno tuned and the guys at the shop told me what to do. PM me with any question's
WRXfirefighter26 is offline   Reply With Quote
Old 08-10-2006, 05:52 AM   #5
Marc5000
Member#: 94894
2002 Impreza WRX
thanks a lot man.. that helps so much.. i had no idea thats what stuck inside there.. i don't have my oem bypass valve tho.. and i've got an 02 wrx.. not 04+.. so i believe it is different.. but now at least i know what the hell goes into that stupid hole.. i'll stop by the dealer tomorrow and see if i can get a hold onto sumthin that'll work out.. they better not rape be from behind w/o lube tho.. or i guess i'll havta buy someone's oem bypass valve from here.. or sumthin.. lol.. make me offers if you've got one.. i need this thing to work 100% operational by aug 19th which is my appointment date with the tuner.. thanks again..
need help on fmic install under0athh51189 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-07-2009 07:26 PM
Need Help on FMIC Install ! magicman90 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 02-08-2008 11:22 PM
Help ASAP! Car will NOT run with ANY BOV installed.... 03WRXMA Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 07-06-2004 08:31 PM
need help?? How do I install my Blitz DD BOV?? k2snow North West Impreza Club Forum -- NWIC 7 07-05-2003 02:20 PM
Need help! Perrin Fuel rails installed but I need help with Fuel Evap Line STR8OUT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-18-2003 12:11 PM
