Welcome to the North American Subaru Impreza Owners Club Wednesday March 22, 2023
Old 02-08-2008, 09:43 PM   #1
magicman90
Member#: 137815
Default Need Help on FMIC Install !
Hey guys im doing a 18G upgrade and I am also installing a FMIC SSauto Chrome Kit on my 06 WRX ...... but I ran into a big problem ....
Heres the problem:
On the drivers side of the wheel well there are 2 hard line ( rubber tubing with metal tubes running threw them .... ) The lines are in the same Hole where the Windshild Wiper Fluid resivour sits .... The 2 hard lines are RIGHT in the way of the Hole where the intercooler piping fits into !
Has anyone run into this problem and know the fix for it !?
Heres a Pic:
magicman90 is offline   Reply With Quote
Old 02-08-2008, 10:15 PM   #2
magicman90
Member#: 137815
Anyone else run into this problem ??
Old 02-08-2008, 10:21 PM   #3
camshaft06
Member#: 149694
2005 Stage 2 Sti
CGM
Maybe lay out your pipes, and make sure you have the correct placement? I have never done this, but I have seen a ton of people that have, with no issues. Take a minute and lay it all out to be sure.
That's just a guess, but maybe worth while.
camshaft06 is offline   Reply With Quote
Old 02-08-2008, 10:40 PM   #4
magicman90
Member#: 137815
its layed out right .... my friend does NOT have these lines on his 05 WRX ! ... the pipe HAS to go threw right where the lines are.
Old 02-08-2008, 10:56 PM   #5
Woodward
Member#: 102424
2003 Tundra
GrEy
I have the SSAC fmic on my '06 and dont remember having problems right there. Can you maybe bend them out of the way a little bit?
Woodward is offline   Reply With Quote
Old 02-08-2008, 11:02 PM   #6
magicman90
Member#: 137815
nope .... The car is auto so i think there tranny coolers lines they gotta be
Old 02-08-2008, 11:09 PM   #7
Woodward
Member#: 102424
2003 Tundra
GrEy
Ooo. Maybe. I know I only had to remove the washer fluid and that was it. Sure you can't bend them a little?
Old 02-08-2008, 11:15 PM   #8
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
Wait!!?? You have an auto turbo charged car????
4ST-AIR is offline   Reply With Quote
Old 02-08-2008, 11:17 PM   #9
magicman90
Member#: 137815
im not posting to be raged on .... im posting for help k thx
Old 02-08-2008, 11:20 PM   #10
wRxbeater11
Member#: 12682
Yea it seems that auto's have those hard lines there. Try and see if they will flex out of the way. Though be care not to kink one of them, def. wouldn't be good.
wRxbeater11 is offline   Reply With Quote
Old 02-08-2008, 11:22 PM   #11
altima04
Member#: 104134
2006 STI
i also did not have this problem at all. im thinking since u have an auto everything would be placed differently around the engine bay? I have never heard of this issue, good luck though.
altima04 is offline   Reply With Quote
need help on fmic install under0athh51189 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-07-2009 07:26 PM
Need help with FMIC Install SteelDragonSTi Water/Methanol Injection, Nitrous & Intercooler Cooling 3 02-23-2009 11:00 PM
need help on Fmic Support beam mod brandonbeeb Interior & Exterior Modification 9 02-03-2007 05:14 PM
Help on FMIC install All8up Mid Atlantic Impreza Club -- MAIC 20 04-13-2004 05:21 PM
Need Help on Ej20 Install EddyRS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-17-2002 02:26 AM
