Welcome to the North American Subaru Impreza Owners Club Wednesday March 22, 2023
Old 07-05-2004, 11:00 AM   #1
03WRXMA
Member#: 35081
2012 WRX
Default Help ASAP! Car will NOT run with ANY BOV installed....
Just did a VF30/Pinks/Pump install on a buddies car.
The car basically wont start.. Cranks over fine, but sounds like its getting choked for air.
Try to take the I/C off, car runs/idles fine. Put the I/C back on, and car wont stay running. Take the BOV off the I/C car runs. Try another BOV, car runs...
ANY ideas?!?!
03WRXMA is offline   Reply With Quote
Old 07-05-2004, 11:04 AM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
Have you tried the stock bypass valve yet? Or tried adjusting the BOV you're using? It's possible it's leaking at idle.
Calvin
cnk is offline   Reply With Quote
Old 07-05-2004, 11:27 AM   #3
03WRXMA
Member#: 35081
2012 WRX
Calvin
Calvin -
I tried the OEM one of my car which runs fine.... Put it on this car and it dies right out. Take it off... and POOF! Fires right up..
Old 07-05-2004, 11:49 AM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
You haven't considered the pinks fueling more....mebbe...???
Have you re-set the ECU??? and I'd use the stock valve until the ECU gets a little happy with the extra fuel.
Old 07-05-2004, 12:21 PM   #5
03WRXMA
Member#: 35081
2012 WRX
Yup running thr UTEC to 550 injector scaling...
But FWIW the car idles fine in stock mode, or on the stage 4 map... AS LONG as the BOV isnt on the IC...
Old 07-05-2004, 01:55 PM   #6
blackie
Member#: 42979
03 wrx
blizzzack stage IV
the car should idle with or with out a working bov. that means in your situation that the extra air coming in from the lack of a bov is alowing it to idle with all the extra fuel you have now for some reason. does the car smell of gas when you try and start it with the bov on?
blackie is offline   Reply With Quote
Old 07-06-2004, 01:49 AM   #7
sonicowrx03
Member#: 41566
I have my car dying on me once and wouldn't start, the problem was the upgrade BOV . The piston inside the BOV got stuck because I excessively lubricated it with WD-40, once the WD-40 disappeared the remain oil and the dirt created a bound of dirt and grime that wouldn't allow the piston to move freely therefore it got stuck in the open position.
The car wouldn't even start at all.
Try the hoses that go to the BOV , they might be discconested.
Good luck!!
sonicowrx03 is offline   Reply With Quote
Old 07-06-2004, 03:26 PM   #8
03WRXMA
Member#: 35081
2012 WRX
**** YES!
Whats the cause?
Old 07-06-2004, 06:29 PM   #9
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
The car is totally out of whack. It should barely run (if at all) with no BOV attached as you have massive amounts of unmetered air coming in with that setup. Sounds like you have too much fuel going into the car and when it gets more air than it thinks, it actually can somewhat idle.
Your tuning is off somewhere; go back and double-check it all. Your BOV isn't the problem; it's the poor control of the new fuel injectors.
Unmetered air == bad.
Want a test? Go take a stock car and disconnect the BOV and see what happens. If it idles, it's barely there. I've left the BOV disconnected a couple of times and learned my lesson when it was time to crank the car back up again.
DrBiggly is offline   Reply With Quote
Old 07-06-2004, 06:39 PM   #10
03WRXMA
Member#: 35081
2012 WRX
I hear ya, and it WAS RICH, about 9.5:1 on my WB02, so I leaned out the map... SAME results...
thoughts?
Thanks for the reply, and test. I KNOW it makes NO sense.....
Old 07-06-2004, 06:46 PM   #11
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
If you have it apart enough, toss the stock injectors back in and set the UTEC for the correct injectors (aren't they 440 I think?) and see if it will run right with the entire system intact. If so, bad injectors or bad setup on the UTEC.
Old 07-06-2004, 06:47 PM   #12
cronic
Member#: 9749
Originally posted by 03WRXMA
**** YES!
Whats the cause?
Do you have the stock inj entered correctly? Do you have a way to check fuel trims? What is the afr at idle?
cronic is offline   Reply With Quote
Old 07-06-2004, 08:31 PM   #13
blackie
Member#: 42979
03 wrx
blizzzack stage IV
its gotta be somthing with the utec and the bigger injectors, let us know what you find out.
Car will not move in any gear WRteXan Transmission (AT/MT) & Driveline 2 01-07-2010 08:46 AM
Urgent help needed: Car will not run with MAF plugged in. Carter Alaskan Impreza Club Forum -- AKIC 11 02-25-2009 09:49 PM
Need urgent help: Car will not run with MAF plugged in. Carter Normally Aspirated Powertrain 10 02-25-2009 09:47 PM
need help car will not run 387hardcore Tri-State Area Forum 20 03-22-2004 01:29 PM
car will not run need help 387hardcore Mid Atlantic Impreza Club -- MAIC 17 03-22-2004 12:54 PM
