Welcome to the North American Subaru Impreza Owners Club Tuesday April 16, 2024
Old 04-08-2009, 01:41 PM   #1
scoobynoobEMT
Member#: 199206
2002 WRX wagon EJ257
Default ignition key ring light install?
anyone know of a write up to install an ignition key ring light into my 2002 WRX sedan?
help, please.
and yes, i've searched..
scoobynoobEMT is offline   Reply With Quote
Old 04-08-2009, 03:01 PM   #2
toutanje
Member#: 153465
2004 Suzuki GSXR 600
WRX now FS!
02 and 03's dont have them stock? Never knew that... 04+ all have em.
Try searching for an 04+ ignition key ring then and just replace it with current one, should slide right over the ignition key cylinder just fine.
toutanje is offline   Reply With Quote
Old 04-08-2009, 03:33 PM   #3
scoobynoobEMT
Member#: 199206
i have the ring, i just need to know which wires to tap into.
Old 04-08-2009, 03:35 PM   #4
integral_machine
Member#: 157016
02 WRX - MBP
Invisible...
My 02 has a ring, but as far as I know, they don't illuminate! Does yours have a bulb in it?
EDIT: I see you found one that does. Maybe you can splice off an interior light that lights up on entry?
integral_machine is offline   Reply With Quote
Old 04-08-2009, 03:36 PM   #5
crpwrx
Member#: 180710
2006 Sti WRB
WFC# 229
How many wires run off of it? Im assuming its power and ground. If so you can get an add a cuircuit from autozone and run it from an accessory power spot that lights up when the interior lights come on, then ground it to the negative terminal on your battery or bare metal somewhere.
crpwrx is offline   Reply With Quote
Old 04-08-2009, 03:37 PM   #6
crpwrx
Member#: 180710
2006 Sti WRB
WFC# 229
Originally Posted by integral_machine View Post
My 02 has a ring, but as far as I know, they don't illuminate! Does yours have a bulb in it???
He has one from a year that came with them. 02 did not but 03 up does.
Old 04-08-2009, 03:39 PM   #7
scoobynoobEMT
Member#: 199206
I'm guessing maybe there is a harness that can be tapped into?
Old 04-08-2009, 03:42 PM   #8
toutanje
Member#: 153465
WRX now FS!
The ones that have it from factory, its connects to a harness with only 2 wires being used. LEDs use two wires: power and ground. Ground is self explanatory. Power, splice it into a switched 12 volt wire. All set.
Old 04-08-2009, 03:58 PM   #9
ekw
Member#: 92141
2014 GT-NC-PRHT
Zeal Red.
you searched, eh?
did you see this?
keylight?
or this even?
Interior Color Change Tutorial: Key Ring
(which gets to your question around post 15)
ekw is offline   Reply With Quote
Help Needed: Key Ring light and Power Door Lock Not Working Linkseal Electrical & Lighting 2 03-24-2010 05:50 PM
key ring light, radio and clock are not working moose00015 Newbies & FAQs 5 03-23-2010 11:29 AM
Key Ring Light Spore Interior & Exterior Modification 1 05-23-2008 01:49 PM
lighted ignition key hole surround TerenceT Interior & Exterior Modification 11 08-25-2002 02:02 AM
Lighted ignition key ring V6 Interior & Exterior Modification 4 11-01-2000 04:49 AM
