11-05-2019, 02:12 PM | #1 |
Member#: 483720
SCIC
Vehicle:2004 sti jbp |
Need Advice: Foam Cannons!
Hey Guys, What foam cannons do you guys use? I'm currently using a trinova but its starting to perform poorly. For the life of me I cannot remember where I purchased it to try and initiate a return. I was thinking about getting a MTM foam cannon.
11-05-2019, 02:18 PM | #2 |
Member#: 472279
NESIC
Vehicle:2023 WRX WRB |
I bought one off Amazon for around $20. Worked great for a while but then it stopped foaming like it originally did and was watered down. I guess you get what you pay for.
11-05-2019, 02:34 PM | #3 |
Member#: 483720
SCIC
Thats exactly what is happening with my trinova. its not pulling as much soapy water as it used to, regardless of how much I turn the knob on the top.
09-24-2020, 06:36 PM | #4 |
Member#: 489026
11-05-2019, 02:39 PM | #5 |
Member#: 454737
AKIC
Vehicle:2005 STI PSM 2013BRZSWP2022ForesterCGS |
How long did you guys use those cannons before they started foaming poorly? Supposedly you're supposed to run water through the cannon with no soap to clear out any blockages. I did buy a second cheap foam cannon that did not foam as good as the 15 dollar one I bought few years back
11-05-2019, 02:46 PM | #6 | |
Member#: 483720
SCIC
11-05-2019, 03:01 PM | #7 |
Member#: 454737
AKIC
11-05-2019, 03:23 PM | #8 |
Member#: 472279
NESIC
I got a good amount of usage out of mine. I don't have access to hot water outdoors, so I just got rid of it.
11-05-2019, 05:31 PM | #9 | |
Member#: 483720
SCIC
For everyone else, is there a foam cannon you are using that has been bulletproof?? If I cant get it unclogged, i'll take some recommendations |
11-05-2019, 07:14 PM | #10 |
Member#: 138957
MAIC
Vehicle:2016 WRX STI Limited DGM |
Most of these foam cannons have a wire mesh filter that can be cleaned or replaced. Takes a little bit of disassembly on the nozzle end, but nothing too hard.
I have the MTM PF22 and have over a year of no issues. They sell extra filters, picked it up half off during black friday last year. |
11-05-2019, 09:12 PM | #11 |
Member#: 489993
NWIC
Vehicle:2019 WRX STI LTD Pure Red |
Got this one a couple of weeks ago from Amazon.
https://www.matcc.company/Foam-Canno...-p-185880.html Do you run plain water through it after every use? |
11-06-2019, 10:55 AM | #12 | ||
Member#: 483720
SCIC
Black Friday is coming up, i'll have to check it out then and see if they are running the same promo. Quote:
02-14-2020, 12:23 PM | #13 |
Member#: 511680
Chemical guys
Hey bud im using the Chemical guys "garden hose" version because i dont have a pressure washer. it works awesome and id say its 100x better then the pressure washer one. have different options for the foam. only thing is you need to use a heavier soap with it.
03-02-2020, 04:15 PM | #14 |
Member#: 512121
South East
Vehicle:2020 STI World Rally Blue |
I’ve used both Chemical Guys’ garden hose version and (currently) pressure washer version and can testify that this is 100% wrong. Pressure works way better, which is why most people eventually go pressure washer anyway. I would get a good $100-$150 electric pressure washer and a foam cannon for it (I like my Chemical Guys one and it makes suds like crazy).
03-07-2020, 03:14 PM | #15 | |
Member#: 377862
I have a Kranzle pressure washer and the same chemical guys hose attachment that you reference above for when I want some quick foam and don’t want to lug and set up the Kranzle. If you think the hose attachment is even 2x better than ANY pressure washer, I’d suggest that you are doing something profoundly incorrect with the pressure washer setup, or the weed in your part of the country totally blows away the rest of the country’s supply. Perhaps both...? But I couldn’t possibly disagree anymore with your assessment of the hose attachment vs pressure washer. |
03-07-2020, 07:06 PM | #16 | |
Member#: 482289
03-06-2020, 10:48 PM | #17 |
Member#: 377862
mtm pf22. end of story
03-07-2020, 11:05 AM | #18 |
Member#: 512122
Vehicle:2011 Impreza WRX STi Plasma Blue Pearl |
I also use the Chemical Guys ACC 326 on all of my vehicles. Easy to use and works with any foam refill solution. I also clean it out with hot water after every other use to prevent buildup that may lead to clogging/failure.
03-11-2020, 02:20 PM | #19 |
Merci Buckets
Moderator Member#: 88606
MWSOC
Vehicle:2018 Grand Cherokee Velvet Red Pearl |
Agreed. I have the older "original" MTM foam cannon. It's been bulletproof for 3 or 4 years and the only time it gets "cleaned" is when I fill it up for the next car wash. The newer PF22 has an upgraded nozzle, and the new .2 has the wider base so it doesn't fall over when empty! I don't NEED to upgrade, but I might .
03-11-2020, 01:15 AM | #20 |
Member#: 474004
DUSICHIN SFL-001 Foam Cannon is a good pick! Try it.
03-12-2020, 11:49 AM | #21 |
Member#: 377862
03-13-2020, 08:25 AM | #22 |
Member#: 512320
SCIC
Vehicle:2005 Wrx Sti BLK |
Amazon foam cannon was around $15-20 range. Has been working fine so far.
03-13-2020, 03:02 PM | #23 |
Member#: 472751
NESIC
Vehicle:2018 WRX WRB |
03-28-2020, 12:08 PM | #24 |
Member#: 461058
I'll add my vote for the MTM PF22. I bought the one with the original bottle and I just recently got the "upgraded" bottle with the wider base so it doesn't tip over.
03-30-2020, 08:12 AM | #25 |
Member#: 512977
Not a big fan of foam cannons. They really haven't saved me much time. I like a car wash mp with a 5 gallon bucket with a grit guard and frequent dunking and rinsing of the mop. I can get the car washed in under 10 minutes without scratching.
