Welcome to the North American Subaru Impreza Owners Club Tuesday February 7, 2023
Old 10-03-2022, 08:38 PM   #326
pcampbell
Member#: 437670
2005 2.5 SC OB
Random but I finally measured my water meth output at the nozzle.
I tried DO3, 4 and 5 nozzles with my old Snow 40220A pump, which is a 300 psi pump but I understand they turn it down to something like 200(?) psi from the factory. Either way it's at the factory setting.
So very simple, DO3 was 150ml a minute
DO4 was 200 ml a minute
DO5 was 250 ml a minute.
Honestly I'm not sure what the right size nozzle is. I was getting bogged down definitely with both #5 and also #4 if I recall right. I don't remember the full details of when I had it coming on initially. I'm using the 3 now but it seems too small on paper...
Any thoughts as to these flow rates?
Is there a guideline of water meth flow rate compared to fuel flow rate or air flow rate?
pcampbell is offline   Reply With Quote
Old 01-16-2023, 11:02 AM   #327
pcampbell
Member#: 437670
2005 2.5 SC OB
Any thoughts on max power we can do on 93 octane + say 50/50 water meth (I'm assuming a stock casting head EJ25 4 cylinder here and not revving to the moon)? Can we make 400, 450, 500? My guess is the limit is somewhere in the 400s . Thoughts?
Old 01-17-2023, 01:43 PM   #328
Homemade WRX
Member#: 33782
96 3MI Racing
search FIRST, then PM!!!
I mean with a large enough turbo and enough revs....
Assuming you're on a respectable turbo, intercooler and good injectors; I'd say probably 450-500 assuming 7k redline and nothing fancy. Also depends on dyno.
water / methanol injection kit -new or used blazin sti Private 'Wanted' Classifieds 3 05-27-2006 09:01 PM
Water/Methanol Injection or Race Fuel or Both ejh25 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-28-2005 07:35 PM
Derek Devises Water/Methanol Injection mistaboosta Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-01-2004 06:52 PM
Derek Devises Water/Methanol Injection mistaboosta Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-01-2004 05:51 PM
