#26 | |
Member Sales Rating: (49)
Member#: 50586
BAIC
Vehicle:64 Impala |
![]() I have no idea if it's cracked or not because its on the car. I guess I can use a borescope when I change the oil next time.
#27 |
Member#: 382191
Vehicle:2006 WRX |
![]() I haven't seen it yet (or I keep missing it); What is the height difference between this and the OEM EJ Pans? Does it hang below any of the bottom bits when installed (in my case, an 06)?
#28 | |
Vendor Sales Rating: (43)
Member#: 198281
Vehicle:2005 WRX/STi WRB of course |
![]() Quote:
For your GD (and I'm relying on my not so great memory) I believe one of the OEM belly pan reinforcement ribs needs to be trimmed. It's a quick cut with a utility knife. I have seen some run without doing this, it will rub under some conditions, but I've never seen it cause any damage. I recommend trimming to provide 1/4-1/2" of clearance.
__________________
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. vs. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#29 | |
Member#: 382191
Vehicle:2006 WRX |
![]() Quote:
#30 | |
Member#: 198281
![]() Quote:
Also, to give you some additional feels, our pan is extremely tough. It's put through two heat treat processes, and dare I say it's the strongest pan out there. In fact, it's VERY popular in off-road rally because of this. One car (El Diablo Rally Team; check them out on FB for the post) had an off into a boulder field a couple years ago, and the skid plat hit so hard it tore the engine from the motor mounts. It left a terrific imprint. They still use that pan today ![]()
__________________
#31 |
Member#: 198281
__________________
#32 |
Member#: 198281
![]() Caught up from the holidays we have our Traditional Performance and Super-G Oil Pans back in stock, ready for the spring rush!
__________________
#33 |
Member#: 198281
![]() As the race season is upon us, does anyone have oiling questions? Or on our new Super-G Extreme Competition pan?
Oil Control Valve? Track PCV management? Oil pump sizes? Pickups, baffles, oil level, etc... We're here for any and all questions you may have ![]()
__________________
#34 |
Member#: 198281
![]() Fun vid of the Super-G showing its sealed center baffle with one-way valves...
__________________
#35 |
Member#: 198281
![]() PSA for those not on our mailer. We're having a 20% off Black Friday sale on all oiling products.
__________________
