#1 |
Member#: 527694
Vehicle:2004 WRX Black |
![]() Hello, I've been having issues with my car lately and I cannot figure out what it is. Whenever I get to around 13 PSI on my turbo my car starts throwing a fit and there's a lot of popping going on and what not. Obviously it's misfiring, and it only does it when my turbo is in the 13-16 PSI range, (16 is the max its set at). I've changed the spark plugs, and for the first pull it was fine. After that it started doing it again.
I imagine my next move would be to change the MAF or Coil packs. I don't want to throw parts at it, so I'd like to learn what I can do in order to isolate the actual issue. Again, it only misfires at higher throttle. I also thought that maybe it was a fuel issue? Maybe I should change my fuel filter? I replaced the old pump about a year ago. Should I buy a fuel pressure gauge and test it out? 190k miles Cars stock.
#2 |
Member#: 29292
SCIC
Vehicle:2004 WRX wagon silver |
![]() your coils are going bad
#3 |
Member#: 527694
#4 |
Member#: 339987
![]() OEM coils are pretty decent for most reasonable applications.
#5 |
Member#: 29292
SCIC
![]() oem don't need anything else, but make sure they're from subaru
#6 |
Member#: 527694
![]() I figured you'd normally get a misfire code for this, is there any way i can tell for sure before i buy these?
#7 |
Member#: 180111
Vehicle:* 2004.114.3 STi Aspen White |
![]() I had a similar issue some years ago. I wasn't sure what was happening at first. Once I figured out it only occurred on boost. I ended up taking it to my local shop and it was a coil pack...I know at some point the CEL came on as I was waiting to take it to the shop but initially it wasn't on.
#8 | |
Member#: 527694
![]() Quote:
#9 | |
Member#: 333468
RMIC
Vehicle:93 SS - 06 OB XT 03 WRB GD 205/22T 20G-XT |
![]() I posted this a while back in this thread: https://forums.nasioc.com/forums/sho...5#post46735985
#10 |
Member#: 29292
SCIC
![]() FYI it takes a lot for the cel to come on for a misfire code on the 2002-2005 wrx, especially if it only occurs when on boost
#11 |
Member#: 527694
![]() Just replaced them, took it for a drive and all was good. Thank you everyone for your help ***128077;
#12 | |
👏 Big Ron 👏
Moderator Member#: 18062
Vehicle:on car parts so PM me b4 j00 buy |
![]() Quote:
#13 |
Member#: 525807
Vehicle:2002 Impreza WRX Black |
![]() I actually had similar issues that plagued my '02 for a while when I first got it; ended up being fuel filter. You already fixed yours, but if you haven't replaced the in-bay fuel filter for the time you've owned the car might be time
#14 |
Member#: 371869
South East
Vehicle:2004 Impreza Wrx WR Blue |
![]() following
