11-09-2008, 03:16 AM | #3801 |
Member#: 118093
Vehicle:2015 WRX WRB |
The high beams have a switched ground, so when they are OFF both sides have 12v. I ran a wire off of the high beams into the car to a factory fog light switch, then back out to my relay box. Lights come on with the high beams only when the fog button is switched to ON.
Stock alternator. Stock harness. Only upgrading I did was on the power circuits for the aux lights.
11-14-2008, 01:42 PM | #3802 |
Member#: 191146
South East
Vehicle:2005 Sti WRB/Gold, what else... |
Bump.
11-14-2008, 03:01 PM | #3803 |
Member#: 166269
NWIC
I like the combo of light/horn/light/horn/light
also 2 stock lights + 3 driving/fog lights = legal in all 50 states! |
11-14-2008, 03:14 PM | #3804 |
Member#: 118093
It will have two more lights eventualy.
11-17-2008, 12:26 AM | #3805 | |
Member#: 29355
NWIC
so you can't have 3 driving + 2 fog, at least not legally... if anyone cares to prosecute/cite you. that's only some states though. |
11-17-2008, 12:40 AM | #3806 |
Member#: 55252
SCIC
Vehicle:* pullup bar * |
what if you have more than 4, but have covers on 'em?? i thought that was legal
11-17-2008, 01:48 AM | #3807 |
Member#: 29355
NWIC
yeah if you have them covered with opaque covers it's okay but then why have them on at all? just have a removable mount to have them on when you need them, and off when you are driving on road.
i mean, are you going to get out and take the covers off when you need to see deers, and then put them back on when you need to see cops? |
11-17-2008, 02:56 AM | #3808 |
Member#: 55252
SCIC
ya i figured that too=/
11-17-2008, 01:34 PM | #3809 |
Member#: 139289
Vehicle:2003 WRX Wagon PSM |
I decided that I was going to do something to my subaru to set it appart from everyone elses car. I decided to make my own light bar, I modeled it after the rally inovations discountinued light bar and wanted it to minic the lines of my upper grill but a mirror image. I think it turned out pretty good, I'm going to add two hella 500 fogs to the light tabs. I'm planning to add a sheet of aluminum to the center section of the bar for a skid type protection.
after wleding before grinding after grinding on the bench grinder after grinding with my rotozip-awesome tool painted just a few hours ago close up of the bed liner spray I used and the light tabs I made I got impatient and mounted it to the car after baking the bar mounting point under the car to the subframe and I cut the splash guard to fit thoughts? should I got with the clear or yellow hella 500 fogs? Either way I want yellow light for the fogs. |
11-17-2008, 01:35 PM | #3810 |
Member#: 131272
Vehicle:2003 WRX Wagon |
That's something i'd never even worry about because it'd take a real hell bent cop to cite you over your lighting. I mean i can understand it if you had them all on, but other than that, it'd be stupid to cite someone for it.
~Alex |
11-17-2008, 01:37 PM | #3811 |
Member#: 142405
Vehicle:#716 Group5 S10 |
Thoughts? How about awesome!
11-17-2008, 02:03 PM | #3812 |
Member#: 118093
The only downside to mounting the bar like you did is that they tend to bounce since they are set out so far. I had mine mounted like that and it was very bouncy. I ended up using the license plate screws to make it more solid.
11-17-2008, 03:52 PM | #3813 |
Member#: 135252
Vehicle:2002 WRX Wagon |
11-17-2008, 04:24 PM | #3814 | |
Member#: 143094
SCIC
Vehicle:08 LGT DBM |
Hella 500's are great lights for the price and they're really all you'll need if you're not doing some serious backwoods driving. |
11-17-2008, 11:54 PM | #3815 |
Member#: 139289
already got that covered with a secondary mounting point farther ahead of the subframe ones, just didn't post a picture, I can stand on my bar and it'll bend before it'll wobble.
11-17-2008, 11:57 PM | #3816 |
Member#: 133676
NESIC
Vehicle:2005 WRX Aspen White |
looks real nice. good work.
go with the piaa's instead |
11-18-2008, 02:21 AM | #3817 |
Member#: 139289
I was going to go with the piaa dual beam 525 setup but they are hella pricey and I'm not sure about the light output, I searched a few of the toyota FJ forums and found a light that was kinda like a hybrid hella fog and driving light
They are originaally $145 ish but they found them at costco for $89 http://www.costco.com/Browse/Product...se=&lang=en-US They are the same size as the hellas so I'm gonna try them on my light bar they come with 55w and 100w bulbs and a relay and a cool switch. Features * High impact, black resin body * 55W & 100W halogen bulbs included * Polished, hardened glass lens * Multi function reflector * Multi direction mounting system * Dimensions: 7"H x 6.5"W x 3"D * Complete kit includes o 2 lights with connectors o Complete snap together wiring loom & relay o Mouse style switch o White protective covers * SAE compliant, legal in 50 states not sure if I can run them in town, they say 50 state legal, though. |
11-18-2008, 04:11 AM | #3818 |
Member#: 55252
SCIC
^^^is that an online product only?? i never see any auto lighting products in costco
11-18-2008, 02:57 PM | #3819 |
Member#: 139289
yup online only, they are carried by arb which is a major offroading brand and makes some oem toyota parts, but these are just renamed and are lower priced, seems like a great deal.
11-18-2008, 04:27 PM | #3820 | |
Member#: 129089
AKIC
Vehicle:06 Impreza2.5Bug-i OBP |
11-18-2008, 04:42 PM | #3821 |
Member#: 166269
NWIC
it's probably just a mixture of a pencil beam / spotlight and a fog, but basically half of each... so you won't get the brightness or projection of either
11-18-2008, 11:11 PM | #3822 |
Member#: 139289
11-19-2008, 09:07 AM | #3823 |
Member#: 135252
The only way to have two beam patterns in one housing is to compromise somewhere.
11-19-2008, 05:10 PM | #3824 |
Member#: 29355
NWIC
very true.
the reason that 9007 lights suck so bad |
11-19-2008, 07:53 PM | #3825 |
Member#: 135252
Stock Bugeye headlights FTL.
The Ultimate Bulb Lighting Thread: All You Ever Need to Know About Bulbs | Yesitsdrew5310 | Electrical & Lighting | 616 | 03-09-2024 10:09 PM |
The Ultimate DIY Water/Alc Injection Thread | hippy | Water/Methanol Injection, Nitrous & Intercooler Cooling | 33 | 03-08-2008 03:11 AM |
My new Hella FF200 Driving Lights and mounts | wrxinfx | Electrical & Lighting | 14 | 04-17-2005 12:24 PM |
WTB: WRX or Impreza RS (old school) fog lights and mounting brackets. | Yamaha600Biker | Private 'Wanted' Classifieds | 2 | 06-08-2004 03:37 PM |
