Welcome to the North American Subaru Impreza Owners Club Saturday December 14, 2019
Old 12-01-2014, 05:19 PM   #1
remski
Member#: 151895
Default 25DB Widebody Rsti
Lets get to the point.
Donor car: 2005 sti slightly modded.
Was fun while it lasted.
Fun in the snow.
And on the track.
Then some water happened along with a crazy idea and this was purchased.
and the FUN begins.
Old 12-01-2014, 05:20 PM   #2
remski
Member#: 151895
After 1 year, lots of unpleasant calls and a credit card to pay off.
This arrived.
A destroked 2.34, benson sleeved and bored out to 2.5
Had to be inspected on the spot.
With no room in the garage it took the main spot in the living room.
New 2.5 RS intake manifold was purchased and given a shave.
Test fitted with 8mm Grimmspeed Phenolic spacers.
Old 05-04-2018, 03:12 PM   #3
dWRXa13
Member#: 362941
Start em young!
This arrived.
dWRXa13 is offline   Reply With Quote
Old 12-01-2014, 05:25 PM   #4
remski
Member#: 151895
Heads came ported.
Taking no chances KillerBee oil pickup was installed.
Ditching side feed, Top Feed Cosworth fuel rails came in but needed a custom bracket.
From this.
This was hacked.
ID 1000's were the only choice.
Test fit and all seemed to fit.
After few more hacks the engine was in the STI.
Break in tuned few weeks later made ~370WHP @1bar.
Then the STI was damaged and things took a break.
Old 12-01-2014, 05:28 PM   #5
remski
Member#: 151895
After a year of sitting it was time to disassemble the STI.
Took about 1/2 a day to get to this stage.
Hoping that the engine have survived.
By next working day the car was stripped of most usable parts.
All wiring was ditched.
and ready to get rolling again.
Old 12-01-2014, 05:30 PM   #6
remski
Member#: 151895
Now was time for the GC.
Before
After
(keeping my buddy anonymous for now)
And a pile of unusable GC parts was created in the process.
It was then time to lighten up the car and remove sound deadening.
Old 12-01-2014, 05:31 PM   #7
remski
Member#: 151895
While at it sti front end was bolted.
Few cans of brake cleaner and a small buzz later ...
We decided to to take off the heads, since the exhaust manifold didnt look too healthy.
Cylinder 4 was done for.
There was damage in the pistion and pretty much all sleeves had a layer of rust.
It was time for a tear down.
Halves have been split since the block had to be re-sleeved.
A quick chat with Benson and the halves were shipped for honing and re- sleeving.
All packed and ready for ups.
Old 12-01-2014, 05:33 PM   #8
remski
Member#: 151895
Permanent position for now.
... Meanwhile battery tray was shaved.
Rear was bolted up and them GC05F mounted.
And then finally after more than a year of aggravation this arrived.
This was really the deal breaker. If I couldnt get the kit, project would have been scrapped.
Old 12-01-2014, 05:36 PM   #9
remski
Member#: 151895
It was now time for some welding to be done.
But first....
It really took 3 of us to get the car on its side.
It was now time to prep for seam welding.
Weld-meister doing the honors.
And the finished product.
A pleasant surprise from Benson.
o-ring-ed and shiny
With only one half re-sleeved.
Moving along.. RS AL hood was finally picked up and installed.
Old 12-01-2014, 05:36 PM   #10
remski
Member#: 151895
And in the parts department... A guy from nasioc had created a new fuel rail bracket. Making things lighter quite a bit.
The old and the new.
After a many days and nights I gave in to the thought of caging the car.
FIA cage has been ordered, and paint prep-work begun.
All scuffed-out before the cage install.
Seam welding traces
And in the parts department those arrived.
And those as well.
Then came the roof time.
Cf should do just fine.
M0ar good news came from JE.
4 new custom pistons have been delivered.
Old 12-01-2014, 05:38 PM   #11
remski
Member#: 151895
Also Japanparts delivered as well.
I know its early but the brains are here as well.
Time to make things neat.
And for those wondering here is the turbine housing of the turbo to come.
Cage prepping in progress.
Some rust here and there got taken care of.
Breaking power is ready.
Few parts of the dieting process.
Old 12-01-2014, 05:39 PM   #12
remski
Member#: 151895
Update: Sep.07.2014
Finally some movement.
After a month of waiting and some struggles with shipping company...
This arrived.
Unpacking the goodies.
T45 FIA Certified straight from UK.
Mounting plates.
Dash Bar test fit.
Main hoop tests.
Gave up testing when all of the bars fell apart.
Now trying to find a decent welder that will TIG-it.
Old 05-04-2018, 03:13 PM   #13
dWRXa13
Member#: 362941
Because race car
Update: Sep.07.2014
This arrived.
Mounting plates.
Dash Bar test fit.
Main hoop tests.
Old 12-01-2014, 05:39 PM   #14
remski
Member#: 151895
More goodies arrived.
Cossie oil baffle.
1400' of mil spec tefzel wire.
And a Motec PDM to suport it.
Old 12-01-2014, 05:40 PM   #15
remski
Member#: 151895
So... chassis is at the welders..
All ready for TIG welding !!!
Old 12-01-2014, 05:40 PM   #16
remski
Member#: 151895
and if you are lucky enough to have an ex. Prodrive engineer work on your car, you get ideas like this...
Didn't take long to talk me into those front plates.
Old 12-01-2014, 05:41 PM   #17
remski
Member#: 151895
Cage weld progress.
Old 12-01-2014, 05:41 PM   #18
remski
Member#: 151895
Fancy front plates in the making...
And first plate has been welded !!!
Old 12-01-2014, 05:41 PM   #19
remski
Member#: 151895
Almost done ....
Old 12-01-2014, 05:45 PM   #20
EVT_Dan
Member#: 143534
Holy Hell man !
What will the car be used for. Not often you see a proper Custom Cages cage
EVT_Dan is offline   Reply With Quote
Old 12-01-2014, 05:48 PM   #21
remski
Member#: 151895
Well..
the plan is to use it as weekend track toy and have it street legal.
Old 12-01-2014, 05:53 PM   #22
Ultimateone
Member#: 48025
17 BMW M2
AW
I love threads like this, incredible.
Ultimateone is offline   Reply With Quote
Old 12-01-2014, 05:56 PM   #23
cenix
Member#: 246027
2011 STI
Well..
I can't wait to see this thing completed. Lots of hard work and money and dedication!
cenix is offline   Reply With Quote
Old 12-01-2014, 08:53 PM   #24
Brandon2k13
Member#: 376571
A Subawooooo
Talk about a project haha. This is awesome man, nice work.
Brandon2k13 is offline   Reply With Quote
Old 12-02-2014, 01:27 PM   #25
lingling1337
Member#: 312120
Mother of God.
lingling1337 is offline   Reply With Quote
