Welcome to the North American Subaru Impreza Owners Club Thursday December 5, 2019
Old 07-14-2011, 05:35 PM   #1
outfrontmotorsports
Member#: 220204
Default ever had a stripped cam bolt?? here's a 5 minute fix from Outfront Motorsports
***********We have seen a lot of posts regarding the removal of stuck cam bolts and methods of how to hold the cam gear in the futile attemps to remove these bolts with success. We have heard of horror stories of drilling, special bits and long times to do it, we have personally seen the results of dealerships using cut-off wheels/air chisels and the damage left behind on the gears that the dealer reinstalls.
the video was not edited, the motor we have is a ej205, three of the four cam bolts came loose with an impact gun, the forth one did not. this method for us is so fast that it's not worth the time to clamp the timing belt together, nor to use the cam tool. On really tight ones with the tool, we have chipped the gears. we have also seen broken head castings due to using a wedge/prybar on the cam lobes.
Often the cam bolt get really tight due to heat cycles, with the welding we do, the rapid heat applied to a stripped bolt makes them come off like butter, not damaging the cam gear at all. If you are local to us, we would perform this operation for $20 per bolt
<iframe width="425" height="349" src="http://www.youtube.com/embed/WjZ0XtLYtzc" frameborder="0" allowfullscreen></iframe>
http://youtu.be/WjZ0XtLYtzc
outfrontmotorsports is offline   Reply With Quote
Old 07-14-2011, 05:37 PM   #2
Bo0stin5STI
Member#: 162174
05 CGM STi - SOLD
13 SWP STi - TITS
Thanks for the video. This will come in handy when I pull my heads off.
Bo0stin5STI is offline   Reply With Quote
Old 07-14-2011, 10:39 PM   #3
classicaddict
Member#: 220619
04 wrx wagon
nice trick! what i always do is put some valve grinding compound in the allen head, prevents it from striping
classicaddict is offline   Reply With Quote
Old 07-14-2011, 10:45 PM   #4
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
Awesome! Thanks for the advice, wouldnt have thought of doing that
Old 07-15-2011, 01:17 PM   #5
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Very cool thanks for posting up!
Mike
GrimmSpeed is offline   Reply With Quote
Old 07-15-2011, 01:33 PM   #6
88.jeremy
Member#: 265692
is there a way to post/embed the video so it plays in the forum and not a link to it?
88.jeremy is offline   Reply With Quote
Old 07-23-2011, 01:59 AM   #7
[JT]
Member#: 218435
2001 RSTi / LGT
where was this when my friend too FOREVER to saw the damn gear off lol
[JT] is offline   Reply With Quote
Old 07-27-2011, 06:13 PM   #8
02ej20wrx
Member#: 245333
psm
done this more times than i can count that trick works 90% of the time on almost any broken or stripped bolt... great post!!!
02ej20wrx is offline   Reply With Quote
Old 08-14-2011, 02:18 AM   #9
imprezive tek
Member#: 290942
01 WRX
good deal!
imprezive tek is offline   Reply With Quote
Old 08-25-2011, 03:29 AM   #10
gc6sti
Member#: 292465
awesome write up, will use this in the future!
gc6sti is offline   Reply With Quote
Old 09-04-2011, 10:25 AM   #11
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
nice vid guys
Old 09-18-2011, 03:58 AM   #12
MY EJ20TTTTTT
Member#: 275239
2002 Rallying WRX
Rock chipped MBP
very awesome trick!
MY EJ20TTTTTT is offline   Reply With Quote
Old 09-18-2011, 09:49 PM   #13
mavstang73
Member#: 186271
2007 FXT
GRP
God damn... I know what I'll be doing if I round out an Allen bolt now.
Awesome vid.
mavstang73 is offline   Reply With Quote
Old 09-28-2011, 02:44 AM   #14
ICPWRX
Member#: 244085
Not to ruin anything......but the zipp zipp of that impact gun is a little bit less than realistic....(maybe in a perfect world) so what does he tell you about what the cam dowell is rounding out ?when they dont just pop off? truth be told....FYI....leave the belt on, use a strong 10mm bit, and buy the damn cam wrench cheapskates......if you dont/won't then go ahead and weld yourself a CAI for a flood zone because your obviously retarded....I know its sounds great but this is not your normal occurance, for it to be that easy........in a worst case senario use a craftsman sprialed nut remover or use a die grinder and cut the top of the bolt into a hexagon and use a 17mm 12pt socket to remove it with (the cam sprocket tool! cheapskates!!!!!!)
ICPWRX is offline   Reply With Quote
Old 11-17-2011, 08:14 PM   #15
pettyj54
Member#: 214243
thanks for the video
pettyj54 is offline   Reply With Quote
Old 11-19-2011, 05:16 PM   #16
owner232
Member#: 297389
lol thats what i had to do
owner232 is offline   Reply With Quote
Old 12-11-2011, 08:14 PM   #17
TurboTeggyBoy
Member#: 81247
2005 PSM WRX
TD04L-19T Stage 2ish
Wicked sweet, had to do the same with some suspension hardware,.
TurboTeggyBoy is offline   Reply With Quote
Old 01-03-2012, 03:28 PM   #18
WheelsCSM
Member#: 20765
2008 Forester XT
6mt/18g-xt
awesome, thanks.
Just stripped one of mine last night - now I have to see if I can get my friend to bring a welder over to the house.
WheelsCSM is offline   Reply With Quote
Old 01-11-2012, 07:39 AM   #19
STOOPID
Member#: 243512
Awesome video and a great tip. Thanks!
STOOPID is offline   Reply With Quote
Old 01-17-2012, 04:30 PM   #20
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
Genius level
djerickd is offline   Reply With Quote
Old 01-17-2012, 04:37 PM   #21
xilles
Member#: 147056
does the composite cam gear warp under heat load from the welder?
i. always break cam bolts loose with a breaker bar,pipe extension wedged in between the hoist and turn the cam itself, with the timing belt still attached. ive never had a problem with my method.
:edit: nice thinking out of the box +1
xilles is offline   Reply With Quote
Old 03-03-2012, 02:46 AM   #22
YZ86
Member#: 188705
GD Widebody STI
Lexus Pearl White
Thanks for the advice! Very helpful
YZ86 is offline   Reply With Quote
Old 06-17-2012, 10:09 AM   #23
bori_racer787
Member#: 303909
Chapter/Region: PRSIC
2002 wrx
tremendo video! buen trabajo!!
bori_racer787 is offline   Reply With Quote
Old 01-07-2013, 01:41 PM   #24
killacam661
Member#: 341930
o3 wrx
Psm
i just did this on ALL FOUR CAM BOLTS! good thing i had 4 brand new axle nuts laying around. i pulled out my miller welder and welded em on and broke out my 3/4 in mikita impact gun and BAM! off like butter!!! I DUNNO ABOUT $20 a piece to remove but i did it myself for free
killacam661 is offline   Reply With Quote
Old 02-11-2013, 10:06 PM   #25
Mechie3
Member#: 120152
Wish I saw this a little while ago. Tried welding allen keys to the inside of the bolt and ended up shearing those in half. Now I have a mess to clean up before I can try this method.
Stripped cam gear bolts scoobywagon06 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 26 03-23-2018 07:17 PM
How do you fix a stripped seat bolt? Jncominco2 Rocky Mountains Impreza Club Forum -- RMIC 11 02-19-2009 09:32 PM
stripped cam sprocket bolt limestoner Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-02-2006 09:55 AM
Stripped banjo bolt hole in brake caliper? Fix it!!! thrdeye Brakes, Steering & Suspension 0 10-14-2005 04:10 PM
Anyone ever have a Intake Cam bolt snap off while driving???? fastlane Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 05-16-2005 06:18 PM
