Welcome to the North American Subaru Impreza Owners Club Wednesday December 11, 2019
Old 03-17-2017, 03:50 PM   #351
remski
Member#: 151895
Ok....
Time for few updates...
So.. chop.. chop and now the hood clears.
Next up was booster delete assembly.
Here we are waiting for 97WRXwagon to show up...
Before we start chopping them AP Racing master cylinders...
Measure, cut, trim, repeat....
Last thing we want is a cut thats too short...
Finally assembled.
Installed... and more clearance issues..
Brake reservoir doesnt clear the front strut bar...
SS lines are provided but wherever I mount, it seems to be sitting below the highest point of the master cylinder.
Might put a 90 and make my own lines so I can mount it on the firewall, right above the booster delete..
Old 03-17-2017, 03:51 PM   #352
remski
Member#: 151895
Last but not least.. started on the center console ....
Option 2 with DCCD switches...
Option 3...
Then I realized I forgot the heater controls....
Old 03-18-2017, 07:42 PM   #353
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Good stuff going on here.
I second the idea of using 90* for the SS lines.
KeithS05RS2.5 is offline   Reply With Quote
Old 03-18-2017, 10:02 PM   #354
SuchCar_MuchPower
Member#: 387773
Subscribed. Love home builds that are this in depth. Can't (weight) to see your final weight. Surprised you didn't do CF hood and trunk
SuchCar_MuchPower is offline   Reply With Quote
Old 03-20-2017, 12:28 PM   #355
remski
Member#: 151895
Hi.
I thought about it.. but JDM hood isnt much heavier than its carbon counterpart.
We were mostly concerned with fitment... as already having a cf fenders could make things more complicated.
As for the trunk.. Rear might be too light already..
All this on top of "running way above the planned cost" .. doesnt help..
Old 03-20-2017, 01:50 PM   #356
SuchCar_MuchPower
Member#: 387773
It's only money
Old 03-20-2017, 03:43 PM   #357
Notbrick
Member#: 433072
2004 STI, Stock, 55K
All of this and in a oversized one-car garage. Absolutely amazing work! I can barely manage to cut a sheet of plywood in my garage, and here you are building this masterpiece. Bravo!
Notbrick is offline   Reply With Quote
Old 03-20-2017, 10:29 PM   #358
remski
Member#: 151895
Well.. the bodywork was done in a larger i'd say 2-3 car garage...
Now.. this.. yes.. its a 1 car..
Tight but still better than working outside.
Old 04-19-2017, 09:16 PM   #359
remski
Member#: 151895
Some work was done over the last few weeks.. just havent had a will to take pics..
Ok then.. after 3 years of laying around .. the front axles finally got cleaned up, an installed.
Rubber gloves that were at the ends to protect the shafts were somewhat embeded into them.
Fuel filler and cap were installed with the vent, venting inside the filler..
Lets see how that works out.. I'am thinking it will need to be vented to the outside.
Started working on fuel lines. Both are cut and run. Started mounting them as well, but run into some really crappy m3 rivnuts. (pics to come)
Old 04-19-2017, 11:51 PM   #360
SharinganSora95
Member#: 466325
this is the stuff of legends....
SharinganSora95 is offline   Reply With Quote
Old 04-30-2017, 09:11 PM   #361
remski
Member#: 151895
So.....
Lesson #1 .. dont buy **** rivnuts.
Bought some Ginese knockoffs...
First try was M3 ... threads stripped before the rivnut was compressed.
Next was M4 ... same outcome as M3...
Finally decided to go to M5.. those seem to hold now...
Lots of back-and-forth...
Spent a whole day drilling out the ****ty rivnuts (cursing a bit) and enlarging holes and hose clamps.
Mounted brake line splitter. Fuel lines are raised to clear the brake lines.
Made a front plate to accommodate the firewall connections as well as rear brake line.
A set of hose flew in straight from Germany. Were supposed to be black but the shipper messed up.
Buttoned up the manifold with the spacers.
Since the up-pipe was mounted it was time to test mount the turbo.
Seems like its going to be a tight fit for the piping.
Old 04-30-2017, 09:11 PM   #362
remski
Member#: 151895
Next up was the brake reservoirs.
Started hacking the bracket....
This process took up the whole day..
It sits a tiny bit above the master cylinders and it clears the hood.
Some 90 fittings and it should be fine.
Old 05-04-2017, 09:49 PM   #363
isurfnj1
Member#: 343367
2002 rotated gt3076
This is insane. Do you have an estimated completion date?
isurfnj1 is offline   Reply With Quote
Old 05-04-2017, 11:19 PM   #364
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
[b]
I had a tight fit when I was setting mine up clocked like that, so I did this:
Originally Posted by Scuby04STi View Post
Well I was able to weld on that elbow:
IMG_20160330_065505954 by Bret Stevens, on Flickr
IMG_20160330_065523074 by Bret Stevens, on Flickr
Scuby04STi is offline   Reply With Quote
Old 05-05-2017, 11:54 PM   #365
remski
Member#: 151895
Thats a very nice idea !!!
Old 05-05-2017, 11:55 PM   #366
remski
Member#: 151895
Well... Last winter it was supposed to be completed..
I am hoping it will be ready for few track days this season.
Old 05-10-2017, 10:18 PM   #367
SuchCar_MuchPower
Member#: 387773
So, next year?
Old 05-12-2017, 12:18 AM   #368
remski
Member#: 151895
Nooooooo... this year!!!!
So, next year?
Old 05-13-2017, 02:07 AM   #369
guyfromNY
Member#: 467577
Thousands of hours spent building for a few hours of driving. still worth it. beautiful car my man.
guyfromNY is offline   Reply With Quote
Old 05-30-2017, 01:03 AM   #370
remski
Member#: 151895
So... I've been lazy lately .. but here are few updates...
Both side windows got glued in.
Its a bit early but trying to install what I can before the move.
Rotated the turbo and compressor, position is more/less set.
Downpipe got wrapped and installed as well.
The seat was bolted in its approximate position and the handbrake got mounted.
Picked up a 2 wire coolant sensor in favor of 3 .. since i couldnt find a 3 wire connector.. Lets see how that plays out with the new ecu.
Used throttle connector was also acquired.. Old one was a bit "rusty".
All I am missing now are just cam position connectors.
...and ignition coils...
...and MAP connector...
... yeah and IAT as well
Ebay special starter was installed and the engine is now primed.
Wiper assembly has been installed and a "new" cover has been sourced.
Old 05-30-2017, 01:04 AM   #371
remski
Member#: 151895
Engine bay vin plate got riveted in.
Got an alternator off a 09/10 impreza.. What do you know.. it almost fits.
Last but not least.. found what appears to be a 45 coupler...
Looks like a 90 will have to be used on both ends.
Old 06-11-2017, 11:10 PM   #372
remski
Member#: 151895
Brake/fuel line plate got completed today..
Finally the 45 bulkhead fitting was found..
All riveted and siliconed up..
Main breaker was installed and a positive run to the PDM.
The alternator turnbuckle came in.. and the belt was here few days after that.
Might need to clean that alternator a bit..
It was time to start the wiring.. now that running brake lines seems to be a PITA.
That pretty much covers the rear of the car..
I think there are maybe 3-4 more wires that will be run.
The doors got wired up as well.
Fiddled around with the door cards.. Its manageable but I expected a better fit. Rear side panel is a different story.. it will have to be cut and trimmed because it doesnt clear the cage.
After spending about 2 days.. Finally figured out all the connectors and pins that will need to be used in the engine bay..
Old 06-12-2017, 01:49 AM   #373
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
Always worth the wait for updates in here!
Really moving along. Nice work, keep it coming!
Old 06-12-2017, 08:31 PM   #374
Jgz1994
Member#: 409888
2015 WRX
Spent a good hour reading this thread. **** me this is gonna be good.
Jgz1994 is offline   Reply With Quote
Old 06-12-2017, 08:35 PM   #375
johnnyapp
Member#: 465392
2017 WRX
Ice Silver Metallic
This is the only NASIOC thread I get excited for when I get a notification. Did the same, read the whole thread and can't wait to see the finished product. Labor of love.
johnnyapp is offline   Reply With Quote
