Brakes & Suspension Forum sponsored by The Tire Rack |
11-18-2007, 06:20 PM | #1 |
Member#: 142654
Vehicle:2007 OBP WRX RA 1-4 Built Motor DOM3XT-R :) |
Prodrive Spring Install. Rear Strut Rattling?
I just finished installing all 4 of my Prodrive Springs. I had a few complications along the way. STS tire, who was the last person to touch the wheels, stripped on my $130 Work Lugs horrifically. I managed to get them back on there for the time being. They'll hear from me tomorrow.
Then, as I took apart my rear passenger side shock, I realized it was blown out. I finished the assembly anyway. Im looking into some new KYB shocks now. So after all my setbacks, I finally get everything installed and go take it for a drive. I notice that my rear driver side shock ( not the one that was blown out) is rattling up at the top, almost like top bolts were loose or something. Its really only noticeable at low speeds. I can't figure out what it is. If anyone could give me some advice I'd really appreciate it. Regardless, the car looks great and handles like a beast. After a good alignment it should be even better.
11-18-2007, 09:09 PM | #2 |
Member#: 70598
W. Canada
Vehicle:The Oil patch, as fun as it sounds |
Well the first thing I would do is go recheck everything that they did. Doesn't sound like a very good shop.
11-18-2007, 11:13 PM | #3 |
Member#: 118266
Vehicle:2007 Lexus IS250 RWD 6MT |
Did u check to see if u tightened everything on that side. Make sure the spring is sitting properly and recheck the bolts and nuts. Most likely something loose but could be a blown strut like the opposing side.
11-18-2007, 11:22 PM | #4 |
Member#: 142654
I did the springs myself. STS Mounted/Balanced my tires and installed the wheels. When I went to take them off, they were so screwed up. I asked them to tighten them by hand and they insisted that they use torque sticks on the air guns, so everything would be fine. Eff that.
I doubt the struts blown out, because even the one that is doesn't make noise, just the occasional clunk. I guess I'll double check everything tomorrow. As for replacement shocks, what do you guys recommend? |
11-19-2007, 12:32 AM | #5 |
Member#: 65888
RMIC
Vehicle:2010 FXT |
Koni is always a good option. What is your budget?
11-19-2007, 07:40 AM | #6 |
Member#: 126441
SCIC
Vehicle:03 bugeye |
did you torque the top nut tightly?
dspecs are supposed to be good struts too. I got konis and they |
how to fix rear strut rattle? | jetski247 | Brakes, Steering & Suspension | 2 | 02-25-2013 06:20 PM |
Rear Strut Rattle | gigabytexbc | Brakes, Steering & Suspension | 3 | 02-24-2013 06:08 PM |
Worn Strut? Prodrive Springs & Stock Struts | Udonboy | Brakes, Steering & Suspension | 5 | 06-02-2005 10:34 AM |
Prodrive spring install - rattling - advice? | rainwrx | South East Region Forum | 9 | 05-24-2005 09:00 PM |
Got my prodrive springs installed.... where to get KYB AGX struts? | tacomaprime | Brakes, Steering & Suspension | 10 | 03-14-2005 10:46 PM |
