Welcome to the North American Subaru Impreza Owners Club Sunday May 29, 2022
Old 12-29-2021, 04:09 PM   #1
livinon2wheels
Member#: 442772
2009 WRX sedan
the faster charcoal grey
Default 2005 2.5i wagon - compatible tran swap for 5 spd
My factory 5spd has decided to take a dump at 130k and due to covid parts are practically unavailable to rebuild it. Soooo...is there a six speed that will swap in directly to replace the existing 5 speed? or perhaps a stronger version of the 5 speed that is a bolt in swap? In case you can't tell I'm looking for the least expensive option that will get the car back on the road reliably and possibly with better performance too.
I seem to recall reading somewhere that some transmissions have a 1:1 ratio in the transfer case and others use some other ratio...but I dont remember specifics. Any help with this would be appreciated. Its my daily driver and it has been dead since right after thanksgiving....HELP
livinon2wheels is offline   Reply With Quote
Old 12-29-2021, 10:43 PM   #2
AceKingNYC
Member#: 406087
06 VF48 Wagon
most economical and quickest options is probably just to swap out the trans with a used unit and call it a day.
PMP Auto groups has a handful of impreza manual transmissions available
AceKingNYC is offline   Reply With Quote
Old 12-30-2021, 06:11 PM   #3
livinon2wheels
Member#: 442772
2009 WRX sedan
I have no idea which impreza 5 speeds will work in the legacy I have. Anyone have any way to figure this out? Many thanks for your suggestion Ace, I will check and see what PMP has but will they know what works and what doesnt?
Old 12-30-2021, 06:20 PM   #4
livinon2wheels
Member#: 442772
2009 WRX sedan
it appears they have something that might work...have to check some numbers and see but at first glance it seems they have what I need. Thanks for your help. I appreciate it very much!
Old 12-31-2021, 07:41 AM   #5
AceKingNYC
Member#: 406087
06 VF48 Wagon
it looks as if they may have 2 transmissions for a 5speed manual. Give them a call though, good group of people working there. I suggested them because they are somewhat close (eastcoast) and I have had nothing but positive experiences with them
