Welcome to the North American Subaru Impreza Owners Club Sunday May 29, 2022
Southern California Impreza Club
Go Back   NASIOC > NASIOC Chapters > Southern California Impreza Club Forum -- SCIC
Old 08-08-2021, 01:04 AM   #26
NutBucket
Member#: 90804
2021 Ascent
2012 Accord
IMHO keep it out of boost and get the readiness monitors set and you should be ok. Do you have a scanner to read those?
NutBucket is offline   Reply With Quote
Old 08-08-2021, 02:13 AM   #27
thesmokingman
Member#: 17751
Yes, have scanner at the ready. I'll probably test it this week to see how the stock ecu takes the mods. I'm probably freaking out too soon, as smog isn't till next May or so lol. But I wanna get my ducks in line before.
thesmokingman is offline   Reply With Quote
Old 08-08-2021, 02:42 PM   #28
oreganobag
Member#: 518019
I'm looking at moving back to Los Angeles with my 05 WRX STI.
I have a grimmspeed catted DP, GS uppipe, and Tomei UEL headers ready to install, but I haven't, yet. I might just sell them because I don't see myself uninstalling things every other year, let alone trying to pass inspections with them on a CARB-compliant map. Already have an EBCS installed which sucks because there are no CARB tunes that can handle that.
If I reinstall the stock BCS, how would a CARB map (assuming COBB Stage 1) handle the GS uppipe, tomei UEL headers, and the Killer B turbo inlet as long as I can keep it out of boost? I could forgo the headers, I hear the stock uppipe doesn't have a cat in it already, so an aftermarket is probably fine without a tune, the turbo inlet is a little concerning as the increased airflow is pretty considerable and installing a stock one is a PITA.
I mean, I may just return to stock at this point. The value of the car is only going up and stock blobeyes with low miles are rare, so it's tempting to just be that guy with a stock STI.
oreganobag is offline   Reply With Quote
Old 08-08-2021, 04:47 PM   #29
NutBucket
Member#: 90804
2021 Ascent
2012 Accord
The bigger problem you'll have is passing visual with those parts. It is pretty hit or miss with smog guys. The stock ecu should be fine with them. I've heard of people being failed because the downpipe bolts had wrench marks on them. Granted that is an extreme, but you never know.
Old 08-08-2021, 06:53 PM   #30
oreganobag
Member#: 518019
Yeah, I won't be putting on the downpipe. Or do you think they won't pass visual on a turbo inlet, AOS and MAF hose? The headers would be covered by the skid pad under the engine so not worried about that.
Old 08-08-2021, 07:03 PM   #31
NutBucket
Member#: 90804
2021 Ascent
2012 Accord
Correct, all those parts are not ok. Most guys are being picky because of the consequences of getting caught. I mean they even took a pretty close look at my totally stock Accord. Can only imagine how they would scrutinize a tuner car.
Old 08-26-2021, 01:40 AM   #32
subiblue2002
Member#: 225666
2002 2.18 stroker
super wagon
I passed last year.
But what I had to go through was rough...
Not looking forward to 2022..
subiblue2002 is offline   Reply With Quote
Old 08-27-2021, 11:06 PM   #33
NutBucket
Member#: 90804
2021 Ascent
2012 Accord
Godspeed
Old 08-28-2021, 12:45 AM   #34
thesmokingman
Member#: 17751
Good gawd!
Old 09-15-2021, 10:44 PM   #35
my name is joe
Member#: 171412
Theres a meeting in october 7th 10-1 about this stuff via microsoft teams. Here is the link
my name is joe is offline   Reply With Quote
Old 09-16-2021, 05:50 PM   #36
thesmokingman
Member#: 17751
My 02 is running a jdm vf37 setup. In preparation for next springs smog check, I slapped bought a used ecu off ebay and got a rear o2 sensor spacer. I'd rather validate this sooner than later, giving myse;f some time to pivot if I need to. I swapped the ecu and spacer in two days ago. I've been driving it around town gently and will try to put some miles on it on the fwy to get the ecu flags ready. But so far no cells, crosses fingers. Cannot wait to stick my ecutek tuned ecu back in once I can prove this works.
Old 09-17-2021, 09:00 AM   #37
subaru_gc8
Member#: 29292
2004 WRX wagon
the other thing you need to do is to make sure the Vin on the ecu matches your VIN as well.
Old 09-21-2021, 10:52 PM   #38
subiblue2002
Member#: 225666
2002 2.18 stroker
super wagon
Not sure that this maters, or is even possible.
Last smog I did for my car I had another car same year and model go in for me and I was fine..
Old 09-22-2021, 11:48 AM   #39
thesmokingman
Member#: 17751
It doesn't need to match, it does need to be oem or the hashes will not match.
Old 09-28-2021, 10:33 PM   #40
my name is joe
Member#: 171412
i heard its mostly the cars with canbus ecu's that are going to have the most problems. Basically any impreza before 2008 will be fine. Up until 05(wrx) and 04 sti is even better because 16bit ecu dont provide enough info in the ecu. Not for sure until people start updating this forum and word gets out on what would pass.
Old 01-18-2022, 08:50 PM   #41
goodcar
Member#: 57654
05 wrx wagon stg2
obp
Default Update on my 2005 wrx
I reset to stock ecu, removing the access port. I have not been able to pass with the STI up pipe and gutted downpipe so I am looking to buy a used intact wrx uppipe and downpipe and hope that will pass. What a bummer.
goodcar is offline   Reply With Quote
Old 01-19-2022, 05:04 PM   #42
oaklandish_WRX
Member#: 267339
2002 0[[XXXXoXXXX]]0
MBP LongRoof
How, exactly, did you fail (visual on the DP, OBD error/tune, etc.)? I may still have my '02 OEM catted UP but the temp sensor cable is cut off at the pipe... you'd need to do the 2.2k resistor trick at the harness connector. Pay shipping and its yours. DM if interested.
Data point: Mine passed OBD check in NOV with pseudo-OEM tune (UP and maybe DP cat efficiency codes turned off via rom raider, etc.). Believe I read somewhere reliable that all pre-CANBUS cars did not even need the OEM to supply the software hash, etc. So our antiques just need sensors set and visual OK'd.
oaklandish_WRX is offline   Reply With Quote
Old 02-04-2022, 01:42 PM   #43
goodcar
Member#: 57654
05 wrx wagon stg2
obp
I believe it was an OBD error. fyi I uninstalled the access port thinking it would fail if I had it in place. Are you thinking I should try with accessport? I am not familiar with rom raider. If I can pass without replacing up and down pipe and uppipe, I am all ears.
Old 02-08-2022, 03:43 PM   #44
oaklandish_WRX
Member#: 267339
MBP LongRoof
(big) IF they got you on an OBD software check and you have an AP, you could go to the stage 1 CA map, as that (as I understand from COBB) is approved for CA and has an approval # that the SMOG shop could check. That would get rid of that...if...
But if you have a non-OEM DP, then they'll more likely get you for that. I suspect that is how you got caught the first time...visual is too obvious. SMOG shop receipt should state what the fail was. Time to beg, borrow or buy if you don't have the DP any more. UP is almost never caught at SMOG, based on tribal knowledge. Mine is catless OEM but wrapped in thermal insulation and heavy alum foil the whole length - never a peep. good luck...
Old 02-10-2022, 08:32 AM   #45
goodcar
Member#: 57654
05 wrx wagon stg2
obp
My cats are gutted oem up and down. I still have a cat in the mid pipe. Think I will pass with stage 1 if I provide the eo# ?
Old 04-24-2022, 11:12 PM   #46
thesmokingman
Member#: 17751
Update, my rex was due for a smog. Setup is v7/8 twinscroll with 2.5 block. It runs an ecutek/prodrive tune from so far ago, don't even remember. The car has always passed some with room to spare with the jdm exhaust, cat in downpipe, not other cats per jdm setup. Anyways to the point it passed smog w/o issue. Yay! The tuned ecu was promptly swapped back in afterwards, so glad I didn't have to do any herculean effort to pass... knock on wood.
Old 04-27-2022, 12:35 AM   #47
dLo R6
Member#: 108719
2004 VF39'd WRB WRX
2003 Honda CBR600RR
i passed smog 2 months ago with a 10 year old HB Speed tune from an AP1 (boost solenoid has been changed so i can't run boosted w/ a stock tune). VF39 + bolt-ons and sti pinks.
i had no idea about this rule, but i wasn't bothered about it and i passed just fine.
dLo R6 is offline   Reply With Quote
Old 04-29-2022, 09:58 PM   #48
sigma pi ver. 14.0
Member#: 164838
How you been?
sigma pi ver. 14.0 is offline   Reply With Quote
Old 05-04-2022, 06:10 PM   #49
thesmokingman
Member#: 17751
Originally Posted by sigma pi ver. 14.0 View Post
How you been?
Hey man, I'm doing good especially since passing smog hehe. How have you been? Oh, I see the OG thread has some activity now.
Old 05-10-2022, 02:06 PM   #50
T WRX rawr
Member#: 215168
2006 WRX stage 2 OS
Anyone in the inland empire with a tactrix cable? I'm moving out of state but leaving my car with my dad for now, and he doesn't want to deal with smog hassles. I am open source tuned stage 2 and would love to grab the pro tune and flash back to stock. I haven't fiddled with romraider in ages.
T WRX rawr is offline   Reply With Quote
