Welcome to the North American Subaru Impreza Owners Club Wednesday May 25, 2022
Old 10-30-2021, 08:29 AM   #1401
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Thinking my PCV valve is clogged or stuck based on how my car behaving right meow. Is the v7 PCV valve the same as the 02/03 USDM 205? Or is there a specific JDM part number I need to find?
snow_bound26 is offline   Reply With Quote
Old 10-30-2021, 12:10 PM   #1402
D-Rodman
Member#: 110078
02 Bugeye JDM STi
OBP BLACK
Same as 02-03 wrx, a threaded nipple onto the back of the intake manifold
D-Rodman is offline   Reply With Quote
Old 10-30-2021, 12:52 PM   #1403
snow_bound26
Member#: 395793
2005 92x Aero
Beige
That's what was thinking since it's looks identical from the outside. Thanks
Old 01-19-2022, 12:23 PM   #1404
HaasMonster
Member#: 522220
I'm leaning towards swapping EJ207 into my 2005 WRX. I've considered short-block builds but would prefer to avoid the long break-in period since the car is mainly used for RallyX.
Is there anything I should be aware of when looking at V7 engines? They're getting up in age and inventory is low but I think they're more reliable than EJ205 swap for my needs.
I'm open to any suggestions!
HaasMonster is offline   Reply With Quote
Old 01-20-2022, 06:38 PM   #1405
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
get the nicest v8/9 engine you can find then prepare to overhaul it anyway
Gigs90 is offline   Reply With Quote
Old 01-21-2022, 02:59 PM   #1406
D-Rodman
Member#: 110078
02 Bugeye JDM STi
OBP BLACK
He may be looking at a v7 in order to stay single scroll.
Old 01-22-2022, 09:37 AM   #1407
Bluestreak03
Member#: 125887
2001 EJ207 V7 RSTi,
Mica Blue
I would say that's ultimately going to based on budget, and at the very least if they can get a verified compression and leak down test... Won't make a difference if you go single or twin scroll... Minor things needing swapped
Bluestreak03 is offline   Reply With Quote
Old 01-23-2022, 07:57 AM   #1408
D-Rodman
Member#: 110078
02 Bugeye JDM STi
OBP BLACK
Choose wisely, do you already have a good turbo and turbo back exhaust you want to continue to use or are you looking for an all new setup ?
Do you have an Accessport you want or need to continue using or do you want to run on a jdm ecu with functional avcs and open source tuning ? Are you setting up a street/track car or street only, track only ?
The direction you need to take is based on many considerations, including budget.
Old 05-20-2022, 03:22 PM   #1409
SunBurntGinger
Member#: 530118
2004 Impreza WRX
Question Nuetral Safety Switch Polarity V7 EJ207 2004 WRX
Hello!
I recently completed dropping in a used V7 EJ207 into my 2004 WRX. I have been following this EJ207 info thread which has been amazing help! I'm getting ready to start up the car. But before I do, I wanted to make sure the Neutral Safety Switch had the correct polarity. I'm a little confused on how to do this, and how to change the polarity if I end up needing to. I haven't used Romraider before. Is Romraider the only method to check the polarity?
My thoughts are that I'm overthinking this polarity thing and that all I have to do is cut the wires and just swap the wires around.
More info:
- Manual 5 speed
- AVCS wiring is installed
- The car has a remote start installed.* (Im assuming this affects things)
SunBurntGinger is offline   Reply With Quote
Old 05-20-2022, 05:36 PM   #1410
iNfEk
Member#: 21339
Chapter/Region: HIIC
2002 LHD STI V7 6MT
[email protected] EJ205 4EAT
My understanding from what I remember from back in the day is NSS is reverse vs usdm. But everything else is the same.
iNfEk is offline   Reply With Quote
Old 05-20-2022, 05:39 PM   #1411
SunBurntGinger
Member#: 530118
2004 Impreza WRX
Okay so am I correct in thinking that i just cut the wires and flip the connections?
Old 05-20-2022, 06:05 PM   #1412
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
Donít cut anything. Just de-pin the 4 pin for 5MT or 6 pin for 6MT
Old 05-20-2022, 09:21 PM   #1413
D-Rodman
Member#: 110078
02 Bugeye JDM STi
OBP BLACK
Default EJ207 Info
Have your tuner change it, thatís what I did because like you, I couldnít do it myself.
Sent from my iPhone using NASIOC
Old 05-20-2022, 11:42 PM   #1414
NewSilverWRX
Member#: 58485
2004 RASC.207 WRX 5M
You should be able to hex edit the ROM. This dependent on the ROM you are using. I did it for mine, v9 spec c into 2004 wrx 5mt. If I recall Romraider doesn't have a toggle for it hence the hex edit. Also, I think the problem is a NO vs NC thing, not polarity. If it was me I wouldn't cut or depin anything you can do with a simple rom edit.
Start here and search for NPS on the Romraider forums: https://www.romraider.com/forum/view...p?f=15&t=10794
NewSilverWRX is offline   Reply With Quote
Old 05-21-2022, 07:12 PM   #1415
SunBurntGinger
Member#: 530118
2004 Impreza WRX
Thanks guys! Iíll see if I can do it my selfÖ Iíll need to get a tractixs cable and RomRaider. Then learn how to use it because Iíve never used it before! Lol. But regardless I should learn how to use RomRiader since my Cobb wonít work with the ecu anyways.
