#1 |
Member#: 107618
Vehicle:2006 WRX Wagon 2009 FXT |
![]() I have the basic 07 STI trans swap in my 06 WRX wagon. I acquired an 07 STI R180 with a Cusco 1.5 LSD and just got it back after a rebuild at Rallispec.
I plan to keep my 5x100 hubs so have been considering hybrid axles with either SuperDave's way or the SpecB way. Since I acquired some oem wagon axles already, I'm leaning towards the former so looking for a cheap set of STI axles to use the inner CV joint. I figure newer STI axles would be better since they would have less mileage. However, it seems the inner CV joints are different between the STIs and model year 2011 is the cutoff. 05-11: 28492FE040 11-20: 28492FG000 I can't imagine the difference is due to physical R180 changes as I don't think there's anything different about the R180 all these years. I think there was some change with the STIs going wider body in 2011 (I could be wrong). So perhaps the 11+ inner CV joints are longer to account for the wider track? I'm just guessing here. Anybody know the difference between them? In the end, I'm trying to figure out if I can grab a set of 11+ STI axles to rebuild into hybrid axles with 07 WRX wagon axles. Of course using SuperDave's parts.
#2 |
Member#: 130990
Vehicle:06 Red Ltd.Wagon Dom 1.5xtr JJ tuned |
#3 |
Member#: 107618
![]() Yeah I know if I call them up, they can make them for me but it will probably cost $1K. The donor wagon axles I have were free, I'm thinking no more than $200 for STI axles and another $200 for the races I think. Maybe another $100 in miscellaneous parts. I rather keep the $500 but who knows. Down the line I may value my time more and just say eff it and buy the DSS ones.
#4 |
Member#: 107618
![]() bueller?
#5 |
Member#: 297799
South East
Vehicle:2003 WRX EJ207 version 8 |
![]() That is weird. I am also in a similar boat. I have an R180 waiting to go in and I need axles as well. I want to convert to bolt-in rear bearings.
So, the WRX changed to widebody in 2011 and got longer rear axles, but the STi more or less remained the same; sans the addition of the widebody sedan. However, Subaru also lists the complete rear axles as fitting the +2011 WRX, STI, and Impreza. https://parts.subaru.com/p/Subaru_20...8421FG022.html I think their site has an error. If you are looking at used axles then basically on the diff side you want 27 splines for the R180 (R160 is 25). All rear GR axles (and probably VA too) have 27 splines on the bolt-in hub side. So, a GR WRX rear axle will be 27/25, and GR STI rear axle will be 27/27. And FWIW, the LGT Spec B rear axles are 25/27; GD WRX are 24/25. And I think all STI axles F/R are 27/27. And just to state the obvious, hybrid rear axles be 24/27. I am trying to document a lot of this stuff in the link below. After you pop your joints off, let me know what the shaft spline counts are and I will add them to the table. https://b.obsdian.com/2021/01/15/res...axle-database/ I am also curious to hear how you like the 1.5 LSD. I may just repack my cLSD. |
#6 |
Member#: 107618
![]() you are more than welcome to test out the 1.5 LSD but it's got the smaller flange since I didn't want to invest in a DSS STI driveshaft; I already have the DSS 4EAT one.
You sadden me everytime you want to know how these parts feel LOL. Long story short, I had an overheating idling engine in my driveway and so I don't even want to look into it right now due to heartache and time. Short term I am focused on my SH FXT and long term planning - posts like these - for my GD wagon. If I don't start asking these questions now, there's even less chance in the future they will get answered here in the forums as they die a slow death. Hardrace parts are still on their way; I just checked in with their USA office. If you are interested to try them out, hit me up after I post some pics of them on NASIOC. |
#7 |
Member#: 107618
#8 | |
Member#: 297799
South East
![]() Quote:
If you were local I would consider taking you up on the 1.5 LSD offer (that sounds weird). I do miss my 5MT DSS CF driveshaft. The clunking/lunging is annoying after not having to deal with it for several years. Eventually, I will get another one for the 6MT. The prices are just crazy high right now. I'm definitely interested in the Hardrace parts. Didn't you order those a year ago? |
#9 |
Member#: 107618
![]() Yes, I also had a 5MT carbon fiber DS until 3rd gear broke and I did the swap. Had the shop throw in a 4EAT oem DS since I wanted the car back on the road. After one drive, I immediately ordered the DSS one lol.
Hardrace order was placed end of September. |
