Welcome to the North American Subaru Impreza Owners Club Friday May 20, 2022
Old 12-21-2018, 01:39 PM   #1
De36
Member#: 475437
2018 WRX
Default De36's VA1 Build
2018 VA1:
w/ Enkei Rajins (18" Summer):
Engine: FA20DIT
Transmission: 6MT
MAP: Protune by EFI Logics on E85 (60%)
ENGINE:
Perrin Crank Pulley
Perrin Water Pump Pulley
Perrin AOS
Perrin Turbo-Sump Restrictor
Perrin TGV Deletes
Perrin Charge Pipe
Turbo XS Catted Downpipe
HKS Fine Tune Drive Belt
HKS Legamax Catback (Installed)
GReddy RS-Race Catback (Not Installed)
Cobb CAI
Cobb Accessport
Cobb EBCS
Cobb Flex Fuel (E85)
AEM 340LPH (E85)
Restrictor Pill Removed
Mobil 1 Full Synthetic
Torque Solutions EGR Delete
Process West Khanacooler TMIC
Koyorad Radiator
Perrin Oil Cooler
ACT Perf Street Clutch - 449 ftlb
ACT Streetlite Flywheel - 13lbs
Versus Clutch Fork
SUSPENSION:
Perrin Front Strut Tower Brace
Eibach Prokit Springs
Bilstein B8 Struts
OEM Front Swaybar (25mm)
Perrin Rear Swaybar (25mm)
TRANSMISSION:
Kartboy Shifter Lock
STI Duracon Shift Knob
Torque Solution Short Throw
Motul Gear 300 75w90
WHEEL& TIRES:
Muteki SR48 Lugs
Enkei Raijin 18x8 et+45mm (20 lbs) - Street
Conti DWS 06
Motegi MR131 Traklite - 18x9 et+35mm (19.6 lbs) - Track
Toyo R1R - 255/35R18 - Track
CHASSIS:
Seibon CF Fender Caps
Seibon CF Spoiler
Perrin Rear Window Vents
Velox Throttle Pedal Relocate
Whiteline Front Roll Center Kit (Lower Balljoints)
Whiteline Front Bump-Steer Kit (Tie Rod Ends)
STI Group N Pitch Stop Mount
STI Group N Trans Mount
Whiteline Trans Mount Bushings
Whiteline Rear Differential Bushings
Whiteline Rear Subframe Bushings
Plate Relocation Kit
Subispeed's OLM Fog Light Kit (Removed)
Subaru OEM Foglight Kit w/ Lamin-X Yellow Fog Covers (Installed)
Rally Armor Flaps (Breast Cancer Awareness)
S207 Grill Pinstripe
Weather Tech Liners
Subispeed Rear Foglight
Panavise Phone Mount
HT Autos V3 Front Lip
S209 Rear Vents
Spare Tire Delete
BRAKES:
Motul RBF 600 Brake Fluid
StopTech Slotted BBK
StopTech SPORT Pads - Street
Hawk DTC-60 Pads- Track
SAFETY:
Bell Sport MAG
Bell M8
Other Builds: Honda
De36 is offline   Reply With Quote
Old 12-21-2018, 03:36 PM   #2
De36
Member#: 475437
2018 WRX
Default Perrin Pulley Set
Crank Pulley:
Water Pump Pulley:
Fitment was perfect. Perrin supplied great directions. Install time was ~30min.
Old 12-21-2018, 03:39 PM   #3
De36
Member#: 475437
2018 WRX
Default Turbo XS Catted Downpipe
Side-by-side cat comparison:
Notice the restricted inlet shape of the OEM cat:
Issues*:
1. I could not re-install a heat-shield that protects the water pump and drive belt. The new cat is bigger than stock.
2. The front lambda sensor harness was too short, so AFR sensor 1 would NOT reach the bung on the Turbo XS cat.
*I sent Turbo XS an email and a voice message, they never responded to either of these issues.
Old 12-21-2018, 05:41 PM   #4
De36
Member#: 475437
2018 WRX
Default Sparco F5000K - Car Seat
Not what I meant when I said I wanted Sparcos...
Old 12-27-2018, 05:38 PM   #5
De36
Member#: 475437
2018 WRX
Default Perrin - Front Strut Brace
The bar fits way back under the cowl:
The only issue with the install was that the driver-side bracket touched against one of the lines. The direction do not mention this:
I slightly bent this bracket to prevent rubbing:
Now there is clearance:
Old 12-27-2018, 05:45 PM   #6
Calamarii
Member#: 492826
2002 EJ207 WRX Wagon
Don't think the pictures quite worked on that last one. There they are.
Cool car though. I feel like I don't often see white mud flaps on the white car but i like it.
What did you end up doing with the afr sensor that wouldn't install on the new cat?
Calamarii is offline   Reply With Quote
Old 12-27-2018, 06:05 PM   #7
De36
Member#: 475437
2018 WRX
Default Turbo XS Downpipe with short O2 Sensor
Originally Posted by Calamarii View Post
What did you end up doing with the o2 sensor that wouldn't install on the new cat?
OEM Heat Shield:
I disconnected the O2 connector from its bracket and zipped tied it for now. The wiring is too taut. I will be addressing this in the Spring along with the custom Heat-Shied to protect the water pump and drive belt. I will either find a sensor with a longer pig tail, or just solder in wire to extend the connector properly.
Removed Heat Shield & Zip Tie:
Old 02-10-2019, 10:45 PM   #8
De36
Member#: 475437
2018 WRX
Default GReddy RS Race Catback
A bit dirty from road grime:
[/IMG]
Old 02-21-2019, 03:45 PM   #9
De36
Member#: 475437
2018 WRX
Default Custom Adjustable Rear Endlinks
The key features here are the over sized heim joints w/ seals to protect against the weather.
Also the lower-sleeves for proper hole placement.
Old 02-21-2019, 04:00 PM   #10
De36
Member#: 475437
2018 WRX
Default Perrin AOS
Waiting on a warm day to install
Install Update:
I waited to do this install until I performed the Walnut Blast + Stage 3 to ensure fitment. An AOS combined with a EGR-Delete is a must to reduce/eliminate carbon build up on valves because of the direct injection.
Impression:
AOS's like this are expensive & time consuming install jobs. 3/5 install difficultly. The benefits of not having to empty this (unlike a catch-can) out weigh the price. It's a little nerve racking cutting the hoses to length know you only get one shot. Perrin's quality is amazing.
Notes:
You will need coolant to properly bleed the system, this would be a good time to do a coolant flush (2 gallons) and some Water Wetter. I purchased crimp-hose-clamps for a cleaner install https://images-na.ssl-images-amazon....L._SL1500_.jpg
2017+ slightly different (and easier) install than 2015-2016 MY.
Old 02-21-2019, 04:05 PM   #11
De36
Member#: 475437
2018 WRX
Default Perrin Window Vents
Just delivered. New product for those hot trackdays and races events:
Really high quality and installs in seconds
Old 02-22-2019, 03:14 AM   #12
DaveS16
Member#: 311573
2004 Impreza Spec C
Thanks for good picture story =)
DaveS16 is offline   Reply With Quote
Old 02-22-2019, 03:39 AM   #13
Eww Evo
Member#: 299687
I love my Perrin AOS. I was very annoyed being indecisive about getting this one or the COBB AOS.
Eww Evo is offline   Reply With Quote
Old 03-18-2019, 03:03 PM   #14
De36
Member#: 475437
2018 WRX
Default Subi Bros Walnut Blast Kit
Mileage: 30k
Without an AOS & EGR-Deletes a walnut-blast cleaning would need to be completed every 15k-30k miles.
I completed the walnut blasting using the recommended Harbor Freight Blaster with 30,000 miles on my car.
The Blaster:
The HF-Blaster was temperamental and would not consistently blast. I returned it and got a new one and it acted the same. It is important to have a 1hp (or more) air-compressor that can hold 110-120 PSI consistently. It worked pretty fast and cleaned large areas quickly.
The SB Adapter:
Fit and worked well, but walnuts still escaped. I purchased the shop-vac reducer at Home Depot for $9. The driver side was more difficult to maneuver.
Carb Cleaner w/ Gun-Barrel Brush:
The HF-Blaster did not remove the thick build up on the valves (see images below). I purchased a 22 caliber gun-barrel brush @ Cabelas and performed a Soak & Scrub w/ carb cleaner.
My Method:
1. Walnut Blast
2. Soak & Scrub
3. Walnut Blast
4. Soak & Scrub
Overall Impression/ Results:
It took a little improvisation and a lot of patients, but I am happy with the results. I never suggest reusing fluids (coolant, oil, etc.) or gaskets. I spent ~$150 in gasket and new coolant (2 gallons). The difficulty to the average person I would say is a 4 out of 5. For a technician this is a 2 out of 5. Walnut shells go every where and can do a lot of damage if they are not removed. Subi-Bros sell an 1/4" NPT Adapter sold separately that is a must have to attach this kit to the HF-Baster. Do not for get to order this!!!
Setup w/ Shop-Vac Reducer:
Pre Walnut Blast:
Post Walnut Blast*:
*I forgot to take an image after I performed the Soak & Scrub. But the valves came out very clean in the end.
___
Old 04-12-2019, 04:07 PM   #15
De36
Member#: 475437
2018 WRX
Default Cobb 3-Port EBCS
Cobb makes great quality products:
Old 04-12-2019, 04:16 PM   #16
De36
Member#: 475437
2018 WRX
Default Perrin TGV Delete & Torque Solution EGR Delete
Perrin TGV Delete:
Easy Install. Great quality. I do suggest replacing the gaskets.
TS EGR Delete:
I completed this install with the Walnut-Blast and the intake manifold off which made for an easy install. TS makes great products. The kit doesn't come with the EGR-to-Intake Manifold gasket, I suggest replacing this gasket. The lower plate sees a lot of heat and water, they rust quite quickly. I also suggest replacing these nuts w/ anti-seize (I went a little heavy with the anti-seize). You will need coolant to properly bleed the system.
Old 04-12-2019, 04:25 PM   #17
De36
Member#: 475437
2018 WRX
Default Perrin Charge Pipe and Process West Khanacooler
Perrin Charge Pipe:
Aligning the lower coupler required patients. The BOV is tricky to align and clamp down. Great quality.
Process West Khanacooler:
PW makes great quality products. Having a slight fitment issue that I am working through w/ PW. The OEM look is what attracts me to the Khanacooler.
Old 04-23-2019, 07:45 PM   #18
De36
Member#: 475437
2018 WRX
Default Protune by EFI Logics
Street Map: 281 whp/303 ftlbs - (w/ stock air box, w/ Greddy RS-Race Catback) 101 dB
Street Map: 272 whp/275 ftlbs - (w/ Greddy Silencer installed) 96 dB
Old 07-16-2019, 12:48 PM   #19
De36
Member#: 475437
2018 WRX
Default Palmer Trackday
I got a sound warning @ 96 dB (w/ scilencer). Palmer max sound level is 95 dB. Time for a new cat-back!!!
Old 07-16-2019, 12:52 PM   #20
De36
Member#: 475437
2018 WRX
Default Poly Bushings
Whiteline Front Roll Center Balljoints
Whiteline Front Bump-Steer Outer Tie Rods
Whiteline Rear Subframe Inserts
Old 07-27-2019, 05:34 PM   #21
De36
Member#: 475437
2018 WRX
Default HKS Legamax, Cobb CAI, and Re-tuned
Although I love the Greddy RS-Race CB it was too loud at 101dB. The HKS is a 3" catback without the noise. And the quality is outstanding.
Stock: 85dB
Greddy RS-Race: 101dB
Greddy RS-Race w/ Scilencer: 96dB
HKS:86dB
Greddy vs HKS
Cobb CAI:
Retuned*:
286 whp
296 ftlb
*(added HKS Legamax & Cobb CAI)
Old 11-11-2019, 03:59 PM   #22
De36
Member#: 475437
2018 WRX
Default FA20DIT Dyno Sheet
Broke Even swapping the exhausts and airbox...
Dotted = RS-Race + OEM Air Box (93 Oct)
Solid = HKS + Cobb CAI (93 Oct)
*Mustang Dyno
Old 01-26-2020, 10:18 PM   #23
De36
Member#: 475437
2018 WRX
Default Palmer Motorsports Park 9/25/2019
A few pics from my final trackday last year with the HKS Exhaust & Cobb CAI. Very happy with the car so far.
The brakes over heated by the end of the day and had a scare into turn 1. I am currently on StopTech Slotted rotors and Hawk 5.0 pads. The StopTech rotors are great and have not warped the entire season, highly recommend. The 5.0 pads faded a little too easy.
So the next upradges: BBK w/ Hawk Blue Pads & 200AA tires.
Coming onto the front straight (all alone)
Chasing down a fellow WRX
#Mopowababy
Chasing down a BRZ last lap of the day with brake fade
Old 02-27-2020, 12:44 PM   #24
De36
Member#: 475437
2018 WRX
Default Seibon - CF Fender Caps
Old 03-21-2020, 06:02 PM   #25
De36
Member#: 475437
2018 WRX
Default StopTech BBK
Front 4 Pot:
Rotors: 355x32mm 18lbs ea
Caliper: 42/38mm Trailing Piston 7lbs 11oz ea
Rear 2 Pot:
Rotor: 345x28 (Vented) 16 lbs ea
Caliper: 34mm 4lbs 3oz ea
Torque Specs:
FRONT
Bracket Bolts (17mm): 60 ftlbs
Caliper Nuts (1/2"): 30 ftlbs - [instructions say 40 ftlbs, this is incorrect]
Bridge Allen Bolts (5mm): 8 ftlbs
REAR
Bracket Bolts (14mm): 50 ftlbs
Caliper Allen Bolts: 40 ftlbs (+ Loctite 262)
LINES:
Banjo Bolt (14mm): 14 ftlbs
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
