#1 |
Member#: 102126
![]() hi all, my 2021 STI 15000km has been using about a quart evey 3000 km, and subaru has been doing a oil consumption monitoring. the first 3000 they agree the car used 1 quart, now waiting for the next 3. what will subaru do under warranty, and what should I be looking for? will they replace the engine?
#2 |
Member#: 454737
Vehicle:2005 STIpsm 2013BRZswp2017IMPREZAlrp |
![]() I think for it to warrant engine replacement it has to be a quart and a half +. I still think that the oil consumption you're dealing with is excessive and you should get a new engine. See what the dealer says, if it's something you don't like then reach out to subaru corporate to voice your displeasure with a new vehicle consuming so much oil. Good luck
#3 |
Member#: 527528
![]() How has the engine been used? Lots of high revs? Has the used oil been analyzed for metal content (bearing debris)? STI's do use lots of oil - it's fairly normal. Doubt they will replace the engine without proof.
#4 |
Member#: 198281
Vehicle:2005 WRX/STi WRB of course |
![]() Subaru's definition of excessive oil consumption is 1 quart per 1,000 miles.
If you're concerned about the engine's health, have a compression and leak-down test performed. That should rule out a major engine problem. |
#5 |
Add Lightness
Moderator Member#: 13699
NESIC
Vehicle:2021 Building It Better |
![]() I'm surprised to see a quart in 1000 miles is the problem point. For the FB problem, 10 ounces in 1200 miles means short block replacement. I had that done, so it's burned into my head. That's 1/3 the quart in only 200 extra miles.
#6 |
Member#: 102126
![]() so did it solve the problem after the short block replace?
#7 | |
Member#: 512891
Vehicle:2010 STi/21 Passport RIP 19 WRX & 16 FXT |
![]() OP, my buddy has a 2019 STi with Cobb Stage 3 + EBCS and he doesn't consume any oil. He told me he drives like a granny but also said he's hit redline a few times.
#8 |
Member#: 527731
![]() If consumption hasn't decreased after the initial break in period, something internally is severely wrong. I have a built EJ20 with 75k miles that uses a quart in 3000 miles or so at 24psi, and a stock EJ20 that uses a quart in 2000 miles because it has 175k miles. Take that anecdotal response with a grain of salt.
#9 | |
Member#: 198281
![]() Quote:
1 quart/1K miles is a LOT of oil to consume. At that rate, it has to be going somewhere and leaving a tell. Leak-down would have been nice, but until you get a tester, pull the intercooler and downpipe. It could be a burned up turbo or better yet, a bad PCV valve. As a general rule of thumb, if you have excessive oil consumption, no AOS on the planet is going to stop it. It may mask the problem, but it will not resolve it. |
#10 |
Add Lightness
NESIC
#11 | |
Member#: 512891
![]() Quote:
#12 |
Member#: 478146
![]() Subaru corporate was a pleasure to deal with when i encountered the same issue prior to logging 5k miles. If you’ve added aftermarket parts they’ll have you sign an agreement not to do so once they’ve replaced the engine. Definitely get it checked and resolved though.
#13 |
Member#: 186084
Vehicle:2018 STI SWP |
![]() If you're unmodded call Subaru of America and just get the ball rolling with them if they don't acknowledge a problem. They always get something done.
If you're modded... you might be ****ed. The poster before me was extremely lucky in getting a new motor from one that had been modified. |
#14 | |
Member#: 102126
![]() Quote:
#15 | |
Member#: 355254
![]() Quote:
What did Subaru claim to be an OK amount? |
#16 |
Member#: 102126
