01-08-2009, 01:04 PM | #1 |
Member#: 87653
South East
Vehicle:97 Supra / 17 GTR 16 Z06 / 07 STI / 05 Evo |
Back to back Camshaft dyno plots??
Is there any no bull****, real information, regarding power pickup with camshafts in our engines?
If you have some back to back dyno plots or testimonials about your cams, please post them up. |
01-08-2009, 05:29 PM | #2 |
Member#: 32669
SCIC
Vehicle:2007 2.34LR, EFR7670 LINK G4+ hybrid STi |
I'd love to find some concrete info but there really is no such thing as back to back when it comes to dynoing a car, pulling the motor to swap cams, then dynoing again. That's a lot of work and time in between just to compare numbers.
I changed to many things when I installed my cams so I can't attribute all my gains to just the cams. |
01-08-2009, 05:59 PM | #3 |
Member#: 78165
South East
Vehicle:05 STI 35r + e85 |
I changed a lot of things also when I installed my cams (cosworth 278/274 avcs) but I'm happy I got em, besides the fact that the first set of cams broke. Comparing maf volts to boost pressure, the difference is night and day. At 22psi on pump/93 with the cammed built motor I made slightly more HP than my stock motor+35r did at 26psi on 93+meth.... and it made more power with 5 degrees less ignition timing and a full point AFR richer. But I also changed the fmic, headers, uppipe, had some head porting done, larger valves, pistons/rods, etc.
01-08-2009, 08:29 PM | #4 |
Member#: 87653
South East
I wish I could rev my engine out to make use of some of the higher duration camshafts.. I really wish there was some solid evidence of how much just camshafts affect our engines.
01-08-2009, 10:13 PM | #5 |
Member#: 32669
SCIC
Eventhough I'm only rocking an 18G right not the car itself is much more excited in the upper rpm range and there's not a day when I don't get jiggy @ 7600rpm. I have the 3076 ready to go and I'm stoked because if my car feels this good with the 18G on it, it's gonna be re-goddamdickulous with the 3076 on + cams.
01-08-2009, 10:30 PM | #6 |
Member#: 133692
SCIC
Vehicle:2003 Chevy Z06 Black/Black |
01-08-2009, 10:51 PM | #7 | |
Member#: 32669
SCIC
I'm gonna be out in LA Friday night but I'll try and make it to the track. Maybe you can log me again. |
01-08-2009, 11:28 PM | #8 |
Member#: 2818
Vehicle:2000 2.5RS |
I've posted this up few times but I'll post it again. This was a 2.5L with 2.0 STI heads, stock cam vs kelford 272 cam, everything else was the same. Picked up almost 80whp at 7000rpm.
http://chrono.firex.org/images/cam_comparison.jpg |
01-09-2009, 01:54 AM | #9 | |
Member#: 87653
South East
01-09-2009, 10:42 AM | #10 |
Member#: 2818
The heads were large-port heads to begin with (non-AVCS) but they were the same in both plots. The stock 2.0 cam profile in the 2.0 head is simply too mild for the 2.5 bottom end. If I was running 2.5 heads with stock STI cams it would probably fall between the two plots.
Basically, I think this is a best case scenario because it's a hybrid. You may not see the same magnitude of gains in another setup until you're pushing a lot of air through the motor. There's a couple of posts showing tremendous gains with the GSC cams on TopSpeeds time attack car, you might want to search for those as well. |
01-09-2009, 11:45 AM | #11 | |
Member#: 87653
South East
04-12-2009, 09:39 PM | #12 |
Member#: 95109
No but thats what you are implying and its pretty ****ty of you to do that.
04-12-2009, 06:40 PM | #13 | |
Member#: 70981
RMIC
Vehicle:2005 WRX WRBlue 01 Outback/5mt |
04-13-2009, 10:08 AM | #14 |
Member#: 2818
01-08-2009, 11:56 PM | #15 |
Member#: 173122
Vehicle:96 LEGACY/wrx black |
Holy Sh_t!!
01-09-2009, 10:55 AM | #16 |
Member#: 28291
RMIC
Vehicle:2015 WRX |
http://forums.nasioc.com/forums/show....php?t=1456543
2.5 + GSC stg 2 cams + gt35r with spool like a gt30r... ya i'd say they work well |
01-09-2009, 11:48 AM | #17 | |
Member#: 95840
Vehicle:sold to a good bud awaiting next car |
.......ask me how I know. |
01-09-2009, 12:45 PM | #18 |
Member#: 28291
RMIC
Vehicle:2015 WRX |
04-12-2009, 08:23 PM | #19 |
Member#: 77470
Vehicle:04 sti 10.41@141 on e85@ 30psi--spinning |
Just about any good aftermarket cam with the right supporting mods is going to pick you up at least 60whp.I personally prefer kelfords and with talking with Kevin Ban the owner of Kelford he grinds a lot of the custom cams for the Rigolis and their **** flies.
Similar Threads | ||||
Anyone else gonna be a SW nerd and watch all 6 movies back to back to back? | blue-sun | Off-Topic | 21 | 04-12-2009 12:12 AM |
rollin, rollin...back to back...to.... | Deezy1678 | Off-Topic | 30 | 09-14-2008 04:15 PM |
RACECOMP gets 2 back to back podiums at Sebring Panoz Race(wanted to share)with MID-A | RaceComp Engineering | Mid Atlantic Impreza Club -- MAIC | 52 | 02-10-2007 01:13 AM |
2002 SCCA rallies back to back on SpeedTV | gpd323 | North West Impreza Club Forum -- NWIC | 7 | 07-16-2002 10:53 PM |
Back-to-back Auto-Xes in Rome, NY 7/27 & 7/28 | Mike Smith | Tri-State Area Forum | 6 | 06-11-2002 09:23 PM |
