03-20-2009, 06:52 PM | #1 |
Member#: 173164
Vehicle:2013 STI Sedan LTD SWP |
need help for complicated swap
i'm merging my 2.5 rs wiring with the 04-05 usdm wrx wiring for my 97 ver. 4 jdm 2.0 motor to work. would i be needing any wires that go to the fender from the 04-05 wrx?
i am also merging the 04-05 wrx engine wiring to the jdm motor so that i can get it to pass emissions through the wrx ecu. and would anyone know which wires i need to merge?
03-20-2009, 07:52 PM | #2 |
Member#: 98961
Vehicle:2003 WRX Black |
Wow, sounds tough. If you intend to use the WRX engine and ECU, I think you need the complete harness that runs under the left fender and through the firewall in front of the passenger seat (but, not under the right side fender). I assume you're using a late model engine harness too?
Have you thought about not bothering to merge but, to use an entire WRX harness? The emissions controls requires lines to the fuel tank and the evap tank under the car in the back. Yeah, I'm thinking you want an entire WRX harness front to back and then you just tack on the parts you need for the RS. I'm sure you can do it the way you are. It just seems like more work. If you have a wrecked 04 parts car, why not swap everything over? That's what I did. |
03-21-2009, 09:39 PM | #3 |
Member#: 177
Vehicle:The 93 W/EJ20K-sold Subaru-less :( |
this won't work
the cam pickup points are different on the v.4 and the cams are a different diameter (cam gears not interchangable with newer cam gears) the crank wheel is also different but its easier to change |
03-22-2009, 04:18 PM | #4 |
Member#: 173164
no i have a jdm ej20k complete motor not usdm motor..
03-22-2009, 04:19 PM | #5 |
Member#: 173164
are you sure because i was told that doing this would work..
03-22-2009, 04:49 PM | #6 |
Member#: 177
by who
the only person i know who has made it work custom milled a newer cam pickup then welded it into the old cam gear |
03-23-2009, 04:09 AM | #7 |
Member#: 173164
icic... well we'll see what happens lol
03-23-2009, 04:14 AM | #8 |
Member#: 102140
South East
Vehicle:2016 Single Speed or Death |
Just throwing it out there, maybe you should listen to Jaxx before you hack up a harness and find out it won't work... or sell the JDM motor and just get a USDM motor, they're better anyways unless you have an EJ207. (which you don't)
03-23-2009, 09:52 AM | #9 |
Member#: 107569
Vehicle:1998 Forester S SRP |
I've done this a few times but the 05+ RS cam gear might also work. Never tried but it has the triggers and bolts up the same as the WRX. But one is SOHC and one is DOHC.
03-23-2009, 11:46 AM | #10 |
Member#: 3362
Vehicle:2001 I've wired a Few cars in my day |
Your original question, Yes, you will need the front harnes, the section that goes through the drivers side fender.
03-25-2009, 03:09 PM | #11 |
Member#: 173164
would it work if i just took off the jdm engine harness and used the us 04-05 wrx intake manifold and us 04-05 wrx engine harness?
03-25-2009, 06:23 PM | #12 |
Member#: 141232
Vehicle:02 v7sti wagon signal green |
you will have to run a US WRX throttle body ,and as Jaxx said a cam gear that fits your cam with the WRX triggers. the crank trigger is different as well. turbomike as a thread about this.
03-26-2009, 10:54 AM | #13 |
Member#: 177
03-26-2009, 11:49 AM | #14 |
Member#: 3362
You'll also need to change the timing gear on the crank as the old cars use a six tooth design.
Get a USDM motor, you'll save yourself a huge headache. |
03-26-2009, 03:33 PM | #15 |
Member#: 173164
i would but this motor is fully built and came with a tranny only for 2grand and it has less than 20k on it. and it came with a lot of goodies such as: vf23, 850cc fuel injectors, stage 3 excedy clutch and 14lb flywheel and on top of it its fully built... i have a set of obx 04 wrx cams so that wouldnt be a problem switching out. and i really dont want to give up on this swap.
03-26-2009, 04:06 PM | #16 | |
Member#: 173164
would i only need the us wrx throttle body? or would i "HAVE" to get the us wrx intake manifold as well? Last edited by gc8v6; 03-26-2009 at 04:18 PM. |
03-26-2009, 08:33 PM | #17 |
Member#: 105736
Vehicle:2011 135i lemans blue |
if it were me, i would sell the motor and keep all the fun parts ( tranny, turbo, injectors, ect.) and pick up a usdm 2.0.
or i would hunt for the correct wiring harness for the motor. but you wont pass emissions. good luck with the swap |
03-26-2009, 08:50 PM | #18 | |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
This swap isn't going to work the way that you are trying to do it. |
03-27-2009, 02:16 PM | #19 |
Member#: 173164
yeah but i dont think the usdm wrx internals can handle the turbo with stock internals and i dont have time to do a rebuild.
03-27-2009, 02:20 PM | #20 |
Scooby Scammer- Do Not Buy From User
Member#: 194555
Vehicle:1997 GC8 coup green |
if you use the larger injectors and not running huge amounts of boost i doubt that the wrx internals would be destroyed.
03-27-2009, 02:35 PM | #21 |
Member#: 173164
03-27-2009, 02:44 PM | #22 |
Member#: 194555
hm, im dont know, ive heard of WRX motors being able to take that, as long as you have the fuel and tuning done.
im in the process of putting my EJ20K into my 97 coup, but im using a hybrid of the USDM and JDM engine harnesses. im not sure what the stock boost is on those turbo's, i heard it was less, but could be wrong. are you using a wrx or sti k series? |
03-27-2009, 02:48 PM | #23 |
Member#: 173164
all i know is that its a jdm ej20k from a sti ver. 4 if that answers anything?
03-27-2009, 03:59 PM | #24 |
Member#: 194555
im sure that some subaru guru will know what the factory boost is, or post the question in the pre-02 powertrain forum since it deals with the EJ20G and K
im hoping to have mine up by next week, so i'll know if i do. but i know the WRX bottom end can handle 18psi if its tuned correctly. there's a guy selling one locally tuned for 18psi with stock internals.... |
03-30-2009, 11:41 AM | #25 |
Member#: 3362
I've been running a VF23 on my 02 USDM WRX swap for years now and have not had any issues. Aso running a dumb light Fidenza flywheel.
If you got a killer deal on it get the right engine management for it. I'm sure you can find the needed bits to run the stock ECU. |
Similar Threads | ||||
need help for rear diff swap | gc8v6 | Subaru Conversions | 4 | 04-21-2009 03:25 PM |
Need help for Turbo Swap | pdpawd | Alaskan Impreza Club Forum -- AKIC | 20 | 06-13-2008 10:12 PM |
Need help for JDM STi version 7 swap in 02 WRX | mathroch | Subaru Conversions | 3 | 08-11-2006 10:14 AM |
Need help for swap STI tranny 6spd on WRX 03 | jpRACING | Transmission (AT/MT) & Driveline | 0 | 05-18-2006 12:11 PM |
Need help for swapping interior? | orwrx | Interior & Exterior Modification | 2 | 09-26-2005 12:21 PM |
