02-10-2004, 11:25 AM | #1 |
Member#: 33990
What mods does it take to max out stock fuel system?
Just wondering? Does it correlate to more boost or can a stocker max it out?
02-10-2004, 11:48 AM | #2 |
Member#: 51163
Vehicle:02-5 02WRXwgn &05FXT sedona & cayenne red |
Virtually all of the larger turbos are capable of maxing-out the stock blues. Unless you do the decapatation mod (740 cc) or enlarge the 12 holes (still experimental). The stocker can come close if overboosted.
02-10-2004, 12:28 PM | #3 |
Member#: 12454
Vehicle:10 Toyota Taco K8 SV650SF |
Running at the stock a/f ratio i bet you could do it with just a boost controller. Chances are your going to max out your injectors before you run into fuel pump problems so IMO injectors are the first thing to "max out".
I used to get IDCs in the low-mid 90s with stock injectors on the stock turbo running around 10.5-11.0:1 a/f. |
02-10-2004, 01:03 PM | #4 |
Member#: 21400
NESIC
Vehicle:2015 WRX Limited ISM |
on my utec stage 2 setup i was around 100 idc's. it wasn't professionally tuned or anything, but i was surprised they were that high.
02-10-2004, 01:08 PM | #5 | |
Member#: 16041
Vehicle:'02 SCRAP METAL ZERO whp.... :( |
again, i agree that you can max out the stock injectors with a boost controller if you turn it up high enough, but you'll also be making your turbo work over time. |
02-10-2004, 01:13 PM | #6 | |
Member#: 12454
02-10-2004, 01:19 PM | #7 | |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
How many mods does it take to beat a wrx? | T.C | Normally Aspirated Powertrain | 197 | 02-01-2009 10:03 AM |
How long does it take to blow out the center differential? | Wrench40 | Newbies & FAQs | 34 | 12-16-2006 12:10 PM |
How long does it take to switch out an air intake hose? | Yasin | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 08-19-2003 08:43 PM |
Does the Cobb stg 2 ecu come close to maxing out stock fuel limits? | waitandbleed92 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 04-24-2003 11:43 PM |
What mods would it take to beat an Eclipse GSX? | jImp | Normally Aspirated Powertrain | 18 | 02-13-2001 07:32 PM |
