03-14-2012, 07:49 PM | #20501 |
Member#: 188359
SCIC
Vehicle:2011 WRX White |
Going back to stock wheels for comfort and tire cost... I think it actually looks cleaner, thoughts?
from
03-14-2012, 08:03 PM | #20502 |
Member#: 235338
South East
Vehicle:2002 Faggin Wagon srp |
03-14-2012, 08:04 PM | #20503 | |
Member#: 286257
South East
Vehicle:2002 WRX PSM |
03-14-2012, 08:23 PM | #20504 |
Member#: 194530
Vehicle:5555 V-TECH WRB |
speedf50 is that the 06-07 or 04-05 front lip
03-14-2012, 09:49 PM | #20505 |
Member#: 221287
Vehicle:2015 WRX ISM |
03-14-2012, 09:56 PM | #20506 |
Member#: 225582
NWIC
Vehicle:2002 VF39'd EJ205 BRP RS Sedan |
03-14-2012, 10:07 PM | #20507 |
Member#: 280714
Vehicle:1998 Look below. 98 rs 99 forester |
03-14-2012, 10:15 PM | #20508 |
Member#: 286257
South East
03-14-2012, 10:17 PM | #20509 |
Member#: 288958
Waiting to get my Rotas from the powder coater. |
03-14-2012, 11:36 PM | #20510 |
Member#: 184554
SCIC
Vehicle:02 ghettoFABness bugeye rolling. |
03-15-2012, 12:03 AM | #20511 |
Member#: 284247
RMIC
Vehicle:2002 Wrx MBP! |
03-15-2012, 01:45 AM | #20512 |
Member#: 188359
SCIC
03-15-2012, 02:22 AM | #20513 |
Member#: 189314
South East
Vehicle:2002 GGSTi 01G |
03-15-2012, 02:26 AM | #20514 |
Member#: 189314
South East
03-15-2012, 09:38 AM | #20515 |
Member#: 235338
South East
03-15-2012, 09:55 AM | #20516 |
Member#: 169781
Vehicle:2003 Impreza 2.5RS Midnight black pearl |
03-15-2012, 10:00 AM | #20517 | |
Member#: 95823
Vehicle:2003 Imprezza Wrx WRC BLUE |
If you run a nice tire you wont see anymore noticeable understeer unless your tracking it. Go with like a pilot supersport or advan s4... 16.5lb wheel 19 lb tire... prolly pick up a couple tenths and 1-2 mpg |
03-15-2012, 10:45 AM | #20518 | |
Member#: 284247
RMIC
03-15-2012, 10:53 AM | #20519 |
Member#: 213634
Vehicle:2002 Impreza WRB |
Still needs moar low,and lips
03-15-2012, 11:17 AM | #20520 | |
Member#: 95823
Holy Grail? http://compare.ebay.com/like/2208897..._lwgsi=y&cbt=y Too bad they not for subys... |
03-15-2012, 12:37 PM | #20521 | |
Member#: 239283
Vehicle:2016 CWP STI VF 2002 WRX (old) |
I liked the other wheels Ibreel, what size were your old wheels? 17's? And the stockers are 16's. But isn't it the other way around, since you went smaller you have less weight and the rotational spin is not as long so your 17' wheels, so your stockers will spin 2x faster which expends more gas than saves. Tires are what like barely cheaper? I'm runnin 18's I'm looking to get into 17's bc it is so cheap compared. Idk it's all personal. Choice. |
03-15-2012, 12:44 PM | #20522 |
Member#: 177880
South East
Vehicle:2002 Wrx Wagon 6sp Where can I get some cake |
Soooooooooo....the perrin crosslock subframe doesn't fit if you have UEL headers
03-15-2012, 01:27 PM | #20523 |
Member#: 284247
RMIC
^bummer ... did you do some research beforehand?
03-15-2012, 01:37 PM | #20524 | |
Member#: 95823
There are two factors. Overall weight, and location of weight in relation of distance to center. For example 16's with factory spec tires and bbs 17's with factory spec tires are only around a 1% difference in overall diameter. The 16's are 16.5 lbs and the BBS 17s aare 16 lbs, bigger wheels tend to push the mass out towards the edge where it takes more power to spin them up, since tires generally are the heaviest part of the setup. But have smaller sidewalls resulting in less understeer. And thats factory. Rotas for example weigh oh 4-5 lbs more a wheel than factory bbs. General consensus is wheel weight is a 6:1 ratio tire weight is a 8-10:1 so each pound of rotating mass has the same effect as adding 6-10 pounds of weight to the car. What you are thinking of is comparing overall diameters. If you are increasing that on your car without changing the gear ratios to compensate you are pulling your whole vehicle out of its proper powerband. Which can be a very bad thing. |
03-15-2012, 02:19 PM | #20525 |
Member#: 177880
South East
the Bugeye thread | 5spdfrk | Member's Car Gallery | 18633 | 05-20-2010 12:18 PM |
Where's the bugeye lip thread?! | yankdanger | Interior & Exterior Modification | 0 | 04-06-2009 09:43 PM |
