Welcome to the North American Subaru Impreza Owners Club Saturday September 22, 2018
Old 06-15-2017, 05:59 PM   #2076
Indolesco
Member#: 439870
2008 Wrx (Sedan)
Default New Set UP
Wheel Specs: SSR GTX01's, 18x8.5 +44
Tire and Specs: Hankook Ventus V12 EVO2, 235/40-18
Suspension: Stock for now (Feal 441's going on soon)
Fender Modification: none
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Indolesco is offline   Reply With Quote
Old 06-18-2017, 08:13 PM   #2077
terrainasaurus
Member#: 464727
2008 OB(Wan)S
OBP/DGM 2-toner
Can anyone confirm if 17x8 or 18x8 +40's will need fender rolling?
I'm on KYB Excel G's.
terrainasaurus is offline   Reply With Quote
Old 06-25-2017, 12:06 PM   #2078
Btanner3
Member#: 469897
Default 2009 Wrx
Can anyone confirm that 18 X 8.5 et 35 would fit without modification? With 235 40 tires
2009 WRX Hatch Stock Suspension.
Btanner3 is offline   Reply With Quote
Old 07-12-2017, 11:28 AM   #2079
Tuning Technologies
Member#: 199386
Have a 2009 WRX Sedan and was wondering if anyone has seen or installed the WORK T7R in 18x8.5 +45? Will be using a 235 40 18 tire
Im pretty sure the offset will work but I dont want to have any caliper issues.
TIA
Tuning Technologies is offline   Reply With Quote
Old 07-13-2017, 05:56 PM   #2080
2009wrxHatchGuy
Member#: 465504
Default Wheel fitment
Would 18x8.5 +45 with 255/40/18 fit my 2009 hatch ? If I need to roll/pull my fenders I will.
2009wrxHatchGuy is offline   Reply With Quote
Old 07-13-2017, 05:58 PM   #2081
2009wrxHatchGuy
Member#: 465504
Default ^^^^
I'm already running bc racing coilovers also
Old 08-06-2017, 07:02 PM   #2082
zgriff71
Member#: 464840
Default The 08-10 WRX (non STi) 17"/18" wheels thread
This thread is back from the DEAD!!!
I've been looking at this thread for a while and finally pulled the trigger on some 18x8.5 et47 Work emotion Kiwami and 245/40r18's stock suspension, no scrubbing, nor camber, or fender rolling required.
zgriff71 is offline   Reply With Quote
Old 08-18-2017, 06:54 PM   #2083
terrainasaurus
Member#: 464727
2008 OB(Wan)S
OBP/DGM 2-toner
Looks good griff!
Old 08-21-2017, 09:12 PM   #2084
Gendy
Member#: 261613
09 WRX
I wanna pull the trigger on some rpf1s, but still trying to nail down the size. i'm thinking 18x8, and maybe 225 or 235/45s. Anybody have this setup they can share?
I swapped to a 6spd and i wanna a taller setup, just not sure how that would look in our wheel wells. I'm lowered on coils but would prefer not to roll my fenders if possible
Gendy is offline   Reply With Quote
Old 08-26-2017, 12:53 PM   #2085
ninjor
Member#: 473513
Motegi 17x7 +48
All season 215
Stock Suspension
I am looking for a race track setup and and want to go 18x9. What do you think the best offset would be for handling and wheel well clearance?
I am also about to put a whiteline 1.4-2.5 inch drop coilovers and swaybars on that I just got in the mail. My current setup looks like it won't allow me to drop it the full 2.5 without hitting the fenders.
ninjor is offline   Reply With Quote
Old 08-30-2017, 10:42 PM   #2086
Breezio
Member#: 234357
2009 WRX
Sportwagen zum einbauen!
If you are going 18x8. Do 235/40 tires.
Breezio is offline   Reply With Quote
Old 08-30-2017, 11:28 PM   #2087
10rex408
Member#: 314033
17x9 With 255/40/17
10rex408 is offline   Reply With Quote
Old 09-20-2017, 05:42 PM   #2088
terrainasaurus
Member#: 464727
2008 OB(Wan)S
OBP/DGM 2-toner
Bump!
Finally nabbed some used wheels on good deal . 245/45/17 17X9 +45
I'll tell ya there is no way I'm clearing fenders if I lower it lol. I want to do bilsteins with rce yellows but, will it clear those even after fender rolling? Or will I have to do some pulling?
Old 11-21-2017, 07:25 PM   #2089
ste_V
Member#: 422806
How are you hatchback owners able to roll your front fenders? my rear fenders are rolled but the front doesn't have a lip to roll, its blocked by the plastic in the wheel well.
ste_V is offline   Reply With Quote
Old 03-24-2018, 03:20 PM   #2090
fearjac
Member#: 297765
Default Trying my luck
Hello all,
I've got a sport 2.5 Impreza 5 door. Bone stock. Love the car and just put fresh set of tires on it for our westcoast winter.
Wondering if these will fit:
18 x 9
ET 30
5 x 114
225/40/18
As mentioned, my car is stock....not lowered or anything. My first guess is these will not fit due to the bolt pattern. We're 5 x 100 correct?
Just asking as I found a wicked set (like new with rubber for decent price).
Thx buds
fearjac is offline   Reply With Quote
Old 03-29-2018, 11:43 AM   #2091
jjbtexas
Member#: 229546
10 STI
Originally Posted by fearjac View Post
Hello all,
18 x 9
ET 30
5 x 114
225/40/18
Thx buds
Wrong bolt pattern and not enough offset
jjbtexas is offline   Reply With Quote
Old 06-22-2018, 09:14 AM   #2092
Loya1ty
Member#: 383680
2008 Impreza 2.5i
Newport Blue Pearl
Anyone running RCE Blacks on OEM struts with the ~1 inch drop?
That's my current set up and I'm searching for some hard numbers on fitment. Looking at 18x8.5, +55 offset. I usually only see around 40-44 for offsets so I'm not sure on them.
Loya1ty is offline   Reply With Quote
Old 06-22-2018, 10:07 AM   #2093
isotopesope
Member#: 265783
2017 Forester XT
Niner ROS 9
looks like you already found your answer then. you need a lower offset for clearance on the inside of the wheel. i know this is not exactly your car, but the first post has some good descriptions of wheel fitment for the wide bodies that relates to narrow bodies:
https://forums.nasioc.com/forums/sho....php?t=2155863
if those stock dampers aren't already blown, they will be soon. if you actually care about handling, i would upgrade your dampers before you worry about wheels. that spring is too stiff and too low for the stock dampers, let alone 10 year old ones. even the 09-14 WRX dampers are under damped for their stock spring rates.
Old 06-23-2018, 12:43 AM   #2094
Breezio
Member#: 234357
2009 WRX
^^ What he said.
+45mm - +48mm is ideal for a narrow body with 8.5" wide wheels and minimal suspension work/no fender work. Run a 235/40 tire.
Old 06-25-2018, 08:35 AM   #2095
Loya1ty
Member#: 383680
2008 Impreza 2.5i
Newport Blue Pearl
Thanks! Yeah, narrow body makes me sad sometimes, except when parking in tight spots.
I plan on doing Konis when I hit ~100k miles (only at 91k now). I know I said OEM, but what I meant was I swapped in the OEM WRX struts at the 77k mile mark with only about 43k miles on them as of now. I figured with the short commute I have, they'd last me until I can take care of some other upgrades.
I love the meaty tire thread and aim to get there in the future, but my first step is upgrading the stock wheels to something a little bigger without needing fender work since I'll need new tires within the year. I'll keep my search around your numbers Breezio. Thanks.
Old 06-25-2018, 10:57 AM   #2096
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Originally Posted by terrainasaurus View Post
Bump!
I did some pulling. I had same wheels with 255/40/17. I was lowered on Koni GC, never had rubbing issues with the 255s. I also had Whiteline offset tophats to get some more room on the strut side.
The plastic should be above a lip. That lip can be rolled.
Getting into the wider widths, the higher offsets will limit your ability to get negative camber. At +45 and 255 tires, full negative with the stock bolts left a few mm between the tire and the strut. I think +45 is the perfect offset and I think fender work is needed beyond 235. IMO, the "Meaty Tires" start at 255.
Old 07-22-2018, 11:12 PM   #2097
zgriff71
Member#: 464840
Lowered now on BC racing "Black" springs and ISC struts with Megan racing RLCA's and 18x8.5 +47mm and 245/45. And a buddies ScatPack in the background of one pic
Old 07-25-2018, 12:06 AM   #2098
Fa20flyaway
Member#: 488600
Originally Posted by SilverFleet View Post
Ok, I'll play.
Wheel Specs: 17x8 Rota Torque in Steel Gray Metallic
Tire and Specs: Kumho Ecsta ASX, 225/45/17
Suspension: Bone stock, except for a STI rear sway bar, if that matters
Fender Modification: None
Wheel Spacers: None
Pics:
like your wheels
Fa20flyaway is offline   Reply With Quote
Old 08-04-2018, 05:23 PM   #2099
Ryan Ortyl
Member#: 322889
Looking to buy some Rota grid concaveís. Iím lowered on bcís, live in south Florida, itís not my daily driver and I do not track the car. What size and tire would you guys recommend without running into problems? 2010 wrx hatch
Ryan Ortyl is offline   Reply With Quote
Old 08-08-2018, 12:30 PM   #2100
jhestertandoc
Member#: 489834
2011 Subaru
Default What bumper lip did you put on the white one?
Where can i buy like that?
jhestertandoc is offline   Reply With Quote
