Welcome to the North American Subaru Impreza Owners Club Thursday November 15, 2018
Old 06-22-2018, 11:54 AM   #1
dilAY571
Member#: 300837
2004 WRX
Default Vehicle speed calibration?
I bought an SG XT recently. It came with aftermarket wheels and they're smaller than stock so my speedo is off. I don't really want to get new tires just to fix this because they are basically brand new. I've been looking at options and found the "Yellow Box Speedo Recailbrator" (https://yellr.com/yb_home.htm). Concept seems solid and I've read decent reviews from other people but I wan't able to find anything specific to a Subaru.
I like the idea of installing one of these because I could then run whatever size tire I wanted and still have accurate ODO/Speedo readings. I know I can "do a mental calculation" but that doesn't help when I let someone else drive my car and have to explain "the speedometer isn't accurate".
My question is this: Does anyone know if the vehicle speed is a direct input from the sensor in the trans or does it get calculated with inputs from the ABS sensors too? I'm worried I could install a YB and then hit limp mode or something because the ECU has some safeguards I don't know about.
Thanks
dilAY571 is offline   Reply With Quote
Old 06-22-2018, 01:18 PM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Stop.....
Just because the rims are a different OD, does not mean the speedo/odd are incorrect.
You can play with tire width and sidewall aspect ratio and maintain a stock TIRE OD which is what is important.
Some tire places have online tire calculators to allow changing rim size and matching tires to maintain the OD.
If you have a GPS, go drive 55MPH and some other speeds and see the GPS speed vs. speedometer. Most are calibrated for 55.
Beyond that, I can't tell you the answer.
What year XT?
Old 06-22-2018, 03:03 PM   #3
dilAY571
Member#: 300837
2004 WRX
Tire has a different OD. I know you can play with it. I have 18's on my WRX that I did that with. I didn't buy these tires though and I don't want to replace them because they have maybe 5k miles on them.
'05 that I'm very happy with. This is just something that I'm mildly annoyed with and I'm curious about. If I end up getting one of the Yellow Boxes I will do a write up if the install and post on here so others can learn from my trial and error.
