04-21-2017, 02:09 PM | #1 |
Member#: 121532
SCIC
Vehicle:06 FXSTi, 06 FXTAT 06 STi Wide Body Wagon |
+2mm rod and Stroker Piston not a thing anymore?
There was a lot of activity on this forum a couple years back with +2mm rods and stroker (83mm) pistons, which seems to have died out.
Any builders out there that are still doing this? The obvious benefits are documented, TDC dwell, improved rod angle, piston speeds etc. So what happened? Why have most builders gone back to standard stroke, standard rod length etc? Any input eagerly anticipated.
04-21-2017, 02:12 PM | #2 |
Member#: 93646
Vehicle:Many Track Records Let us help you go fast! |
+2 rod is 90% of the motors we build.
We've been extremely happy with them. |
04-21-2017, 02:39 PM | #3 |
Member#: 29292
SCIC
Vehicle:2004 WRX wagon silver |
probably cause the shops that were doing it arent really around anymore
04-21-2017, 05:45 PM | #4 | |
Member#: 121532
SCIC
So is the standard or at least accepted way of doing it to go with +2mm rods like the Turbo Tuff I beams and 83mm pistons for a DiY build? I have the ability now to build my next engine with this concept in mind. Do you see any challenges with doing so? Thanks for your input sir. Actually did a little searching on IAG's website and see that their Tuff Stage 4 block uses +2mm rods with "custom" IAG pistons so there is at least one shop doing it. |
04-22-2017, 12:16 PM | #5 |
Member#: 103232
Vehicle:GTX 3071R'd 11WRX PPG,4.44,LSD,E85,6spdx3 |
This is still a thing for sure. The issue is options/availability.
TIC gets the Manley H-Tuff made in a +2mm rod. Doms design and he can get them aswell. Manley only sell the +2mm HTuff to a few select vendors. Im pretty sure Woolman Performance also uses them. The TurboTuff is also available in the +2mm PN 14436-3 with arp2000 bolts. IMO I think the +2mm rod with the stroker piston on a 79mm stroker 2.5 is a great option. The manley stroker piston are about 10-15+ grams lighter then the standard stroke pistons. Manley standard platinum 99.75mm PN 612002c-4 slug weighs around 394-398 grams. Manley Stroker platnium 99.75mm PN 622002c-4 slug weighs around 383ish grams. Manley standard TurboTuff 99.75mm PN 632202c-4 weighs in at 408grams. Manley Stroker Turbotuff 99.75mm PN 632402c-4 weighs around 393grams. I need to get some small and big end weights of different +2mm rods. I think the reciprocating weigh "Small rod end, piston, pin, rings" should be close to the same weight over all. Ian, |
04-22-2017, 08:51 PM | #6 |
Member#: 362723
E. Canada
Vehicle:2002 WRX w/ V7 EJ207 WRB |
I was talking to Carillo a while ago about extended length rods and the numbers they came back with for weights equaled to about 3-4g per 1mm of added length for their Pro-H and HD Pro-H (not advertised or in their catalog but the part number is SB-B2LHD-0HS-5137B6S if you're wondering) rods.
Personally I wouldn't do a standard length rod build due to the EJ's rod/stroke/bore ratio anyway, but I like high RPM to make power over low RPM grunt. |
04-23-2017, 04:43 AM | #7 |
Member#: 25768
RMIC
Vehicle:2003 XONA 9569S 40++ 2.3 slobaru |
04-23-2017, 10:04 AM | #8 |
Member#: 103232
I think TiC mostly build them to a 2.5. Most of the time at least...
04-23-2017, 12:12 PM | #9 |
Member#: 273868
TIC can do a +2 or 4mm rod destroker in a bunch of bore sizes
and the 2.5 +2 is pretty sweet also, I think they called it the "honey badger" personally i'll have a sleeved 101mm or closed deck 99.75 bore , 75mm crank , +2mm rod destroker for the bang per buck quotient , and I like they way the destrokers feel my 99.5 +2mm budget destroker was very linear but I needed more turbo |
04-23-2017, 05:59 PM | #10 |
Member#: 300551
SCIC
Vehicle:2002 FOZ STI 2.34 Fullers Garage |
I also run the +2's in my destroker. I like the feel of it.
04-23-2017, 08:00 PM | #11 |
Member#: 25768
RMIC
I really wanted to do a +2 2.34, but I live at 7000 ft and I've heard they are a bit more lazy than the 2.5 down low and that really adds up at altitude. I need to meet someone here in Colorado that has one so I can see how it feels.
04-24-2017, 01:59 PM | #12 | ||||
Member#: 93646
2.5, but I have done some +2 2.34 setups as well. I have also done a 2.34 with a +4 rod, and while really nice we don't do them that often due to the lead time for +4 rods. Quote:
I love the revs of a 2.34, but we're a good bit lower than you for elevation. In your case I would stick with the larger displacement. |
04-24-2017, 02:18 PM | #13 | |
Member#: 56203
Vehicle:00 RSTI Coupe Twin Scroll 2.5XTR EJ207 |
IAG makes a nice I/Tri beam +2 rod for a reasonable price. |
04-24-2017, 02:40 PM | #14 |
Member#: 343367
Vehicle:2002 rotated gt3076 |
Are you guys going to have them listed on your website? I have a EJ25 block I plan to build this summer. I need to buy rods and pistons for it and was considering doing a +2 rod set up. I've been trying to find them in h beam or h tuff.
04-24-2017, 02:59 PM | #15 |
Member#: 93646
Eventually. We're in the middle of completely rebuilding the site so once we go live we'll be adding all sorts of new things.
04-24-2017, 04:36 PM | #16 |
Member#: 71875
Doesn't the compression ratio go down when you do this? Like 0.4 or so?
04-25-2017, 07:40 AM | #17 |
Member#: 273868
only when destroked
04-25-2017, 10:50 AM | #18 |
Member#: 385165
Vehicle:2005 WRX STI Aspen White |
I live in CO as well. When i finally get around to finishing my wiring i would be more than happy to take you for a ride in it!
04-25-2017, 11:16 AM | #19 |
Member#: 71875
04-25-2017, 11:26 AM | #20 |
Member#: 143837
Vehicle:2000 Impreza 2.5RS BRP |
Just so I am clear, because I am working on this myself for a EJ22 CDB....
The "+2" rods are the 5.181 (131.6mm) length rods correct? Or is there some other market rod that is 5.22" (132.5mm) ? Also, what kinds of rod clearance issues have people seen with the long rod <--> 79mm cranks? Last edited by station2station; 04-25-2017 at 11:33 AM. |
04-25-2017, 11:32 AM | #21 | |
Member#: 143837
There isn't any actually spaces machined into the block or added? You simply mean that during assembly the block halves have to be seperated to line the wrist pin holes correct? |
04-25-2017, 11:35 AM | #22 | |
Member#: 273868
+4mm destrokers are very fun to put together is what he means +2 jobbies are cake |
04-25-2017, 11:44 AM | #23 |
Member#: 25768
RMIC
04-25-2017, 05:41 PM | #24 | |
Member#: 121532
SCIC
It is not actually "destroked" because the crank throw of 79mm remains the same. Using "de-stroked" pistons simply provides the piston clearance (by moving the wrist pin up and shortening the skirts) to account for the +2mm at the top of the stroke and -2mm at the bottom of the stroke for the longer rods as I understand it. The piston actually moves 158mm since it has 79mm throw at the top and bottom. You add them to get total swept length. Last edited by Team Scream; 04-25-2017 at 05:53 PM. |
04-25-2017, 06:00 PM | #25 |
Member#: 143837
http://www.submariner.org/thepno95/T...calculator.xls
I like to ponder about different configurations using this. Thought this might be a good place to share? |
