Welcome to the North American Subaru Impreza Owners Club Friday February 28, 2020
Old 04-22-2010, 03:57 PM   #1
mikeythejew
Member#: 141672
Default Anyone make stiffer springs that maintains the stock ride height?
Looking for stiffer springs for my 07' WRX. Need to keep the stock ride height. Cant get away with lowering my car any, that includes the minuscule drop STi springs would lower it.
Doesn't someone sell or custom make stiffer springs? Really don't want coil overs.. .
mikeythejew is offline   Reply With Quote
Old 04-23-2010, 06:06 PM   #2
mikeythejew
Member#: 141672
Anyone?
Old 04-23-2010, 07:43 PM   #3
happs subi
Member#: 200288
2002 Impreza WRX
World Rally Blue
you can contact eibach or swift to see if they will make you what you are looking for
happs subi is offline   Reply With Quote
Old 04-24-2010, 01:49 AM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
ground control is about it for that
Old 04-24-2010, 02:25 AM   #5
WRBear
Member#: 207171
2016 Golf R
Check out Racecomp Engineering's Regular Guy Springs
http://racecompengineering.com/osc/p...products_id=34
Says they're for the STi, but for the WRX, you need a conversion kit Not sure, but I guess call them.
WRBear is offline   Reply With Quote
Old 04-24-2010, 02:35 AM   #6
Back Road Runner
Member#: 60082
2004 Forester STI
Regular Guy's still a bit of a drop.
Really the only way you're going to not drop is Ground Control's coilover kit. This is exactly why I went to GC. I wanted a very stiff spring and lots of travel (auto-x + rally-x) and nothing existed.
Old 04-24-2010, 04:11 AM   #7
JDwhiteWRX
Member#: 190502
We should start one of these threads each month until it happens
You could go STi takeoffs and then add spacers front and rear to get more ground clearance. These ones http://www.camotoy.com/products/saggybutt/index.php
you will still lose 10mm bump travel though.
JDwhiteWRX is offline   Reply With Quote
Old 04-24-2010, 10:23 AM   #8
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
This is a tough thing - a couple of us have been working on it and so far nobody's made much headway.
sniper1rfa is offline   Reply With Quote
Old 04-24-2010, 10:36 AM   #9
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Turn in Concepts told me a couple years ago they were going to spec something just like this mainly for rally guys. Bug them.
Old 04-20-2011, 07:09 PM   #10
Bad Dogg
Member#: 8331
2017 Forester
Stealthified
It's been more than a month, but let's revive this.
Stiffer than stock, normal ride height? 02 wagon.
Will STi springs lower?
I have heard about King Springs thru Primitive racing. Any reviews/updates about these??
Would really like an option like this.
TiC can get even more of my money if they do this!!!
Bad Dogg is offline   Reply With Quote
Old 04-20-2011, 07:31 PM   #11
Scooby921
Merci Buckets
Member#: 88606
2018 Grand Cherokee
Velvet Red Pearl
King Springs, available through Primitive Racing. They are generally designed to lift the car, but you can ask for custom spec springs. Just be prepared to pay a bit more for something that may be a one-off.
http://www.get-primitive.com/
Scooby921 is offline   Reply With Quote
Old 04-20-2011, 08:44 PM   #12
JDwhiteWRX
Member#: 190502
The king springs are not very stiff, less than Sti takeoffs
Old 04-20-2011, 09:04 PM   #13
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
We keep looking at this every few months. I may very well just do it for a small run to see how it goes.
Let me see what we can do....
Old 04-20-2011, 10:33 PM   #14
JDwhiteWRX
Member#: 190502
I will take a set, I'm currently on 07 sti takeoffs with d-specs but an extra 20-30mm bump travel and ground clearance would be nice, springrate seems ok on the takeoffs but could go a little higher.
Old 04-21-2011, 08:25 AM   #15
Bad Dogg
Member#: 8331
2017 Forester
Stealthified
Great! Will give you a call..
best,
H
Old 04-21-2011, 12:03 PM   #16
02wrxRally
Member#: 205994
'02 Bawkeye WRX
'04 tOtaledBS | '68 MGBGT
subscribed, I'm interested in a stiffer stock height spring as well.
02wrxRally is offline   Reply With Quote
Old 04-23-2011, 06:04 PM   #17
2_fast
Member#: 237523
2008 WRX Wagon
Count me in as well! 2006 WRX wagon
2_fast is offline   Reply With Quote
Old 04-23-2011, 10:33 PM   #18
reid-o
Member#: 103631
2004 STI
Gray
What about a spring perch spacer? Wouldn't that allow you to choose from different springs assuming coil bind is not an issue
reid-o is offline   Reply With Quote
Old 04-23-2011, 10:36 PM   #19
reid-o
Member#: 103631
2004 STI
Gray
Something like this but one that follows the struts count our
http://www.solomiata.com/images/springperchspacers.jpg
Old 04-24-2011, 03:06 AM   #20
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
Pleaseletithappenpleasletithappenpleaseletithappen .
Ground Controls aren't a bad deal though. You get to pick your own spring rate and all that.
Though if you have tokicos, it's 350ft/lbs MAYBE 400, (theoretically anyway) according to the suspension calc xls.
formula91 is offline   Reply With Quote
Old 04-24-2011, 08:51 AM   #21
rich728
Member#: 40328
2004 WRX STi
BSP #728
I'd be in for a stock ride hight spring for an 07 STi
rich728 is offline   Reply With Quote
Old 04-24-2011, 04:35 PM   #22
mexicanzero
Member#: 167820
2003 WRX wagon
ej207 + 6 speed
for the wrx guys... i have an 03 wagon and i put the wagon specific sti pinks on my car(USDM version) and they are quite a bit stiffer than stock and along with 1/4" saggy butt spacers the wheel gap all around is pretty even and the car does not look dropped(maybe lost 5mm)
great ride/handling for dd and occasional track... they are made for 04+ though so the early years will need 04 rear top hats and the spacers for the rear struts
all in all a great setup for the money
-Alex
mexicanzero is offline   Reply With Quote
Old 04-27-2011, 06:12 PM   #23
rich728
Member#: 40328
2004 WRX STi
BSP #728
Just to know, how many sets would it take to make it interesting for you?
Old 04-27-2011, 07:51 PM   #24
indytruckboy
Member#: 192599
2004 STI
2007 Outback Wagon
I would definitely be in on some stiffer factory height springs for my 04 STI.
indytruckboy is offline   Reply With Quote
Old 05-29-2011, 07:16 PM   #25
reid-o
Member#: 103631
2004 STI
Gray
Bump
Would these work with something like an RCE black?
http://www.suspension.com/COILS_SPRING_ISOLATORS.html
I need to measure the dimensions of the stock perch
FS IL: STi V7 RA springs - stiffer with stock ride height peterex MWSOC Private Classifieds 7 10-29-2009 11:42 PM
FS IL: STi V7 RA springs - stiffer with stock ride height peterex Suspension/Brakes/Handling 8 10-29-2009 11:42 PM
stiffer stock ride height springs??? Scott F. Williams Brakes, Steering & Suspension 10 04-18-2005 08:32 PM
whats the stock ride height? huey Brakes, Steering & Suspension 3 02-03-2001 03:06 AM
What is the stock ride height of a MY 99 SubePwr Technical Forum Archive 4 06-21-2000 09:47 AM
