Welcome to the North American Subaru Impreza Owners Club Saturday September 21, 2019
Old 02-07-2008, 02:16 AM   #1
'93Impreza1.8T
Member#: 171092
1993 Impreza 1.8T
Question Impreza 1.8T
I'm trying to turbo my 1.8L Impreza L AWD and I was woundering if my stock ecu will work or could i use the legacy ecu and what else would I need for the set-up to work? I already have the crossmember from a '93 Legacy Turbo, stock turbo from a v5 wrx, complete turbo manifold, uppiupe, turbo back exhaust, and turbo water pump and thermostat housing. Any help or advice if great. Thanks.
'93Impreza1.8T is offline   Reply With Quote
Old 02-07-2008, 04:01 AM   #2
pheonix991
Member#: 154173
2006 STI
Don't bother with putting a turbo on an NA. Just do a swap.
You might be able to get 5lb of boost w/o blowing the engine.
pheonix991 is offline   Reply With Quote
Old 02-07-2008, 09:42 AM   #3
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
This is the typical ignorant reponse you'll get here in Conversions. Start a new thread in the proper forum (aftermarket forced induction) and you'll find out what you really can do with an Ej18. Also, look for "Subachad" and Uniquemotorsports. The information and support is out there, you just need to look in the right place...
Old 02-07-2008, 09:45 AM   #4
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
i don't know that i would go as far as to say ignorant .. more stereotype than any thing else .. yes it will probably blow up
Old 02-07-2008, 09:49 AM   #5
WRC-boxer
Member#: 147186
thats why subiesports EJ18 blew up when they put a TD04 on it right?
(it hasn't, the clutch just slips like hell)
WRC-boxer is offline   Reply With Quote
Old 02-07-2008, 09:51 AM   #6
Matt Monson
Member#: 832
99 2.5RS, '85 911
Saying you "might get 5lbs of boost" is ignorant. It's pretty common knowledge among those of us who have boosted Ej18's that 8-10 is pretty reliable even without an intercooler. 12+ is totally feasible with an intercooler. Though this all depends on turbo choice. The above numbers would be with a tdo4. An early JC/PDM kit with a vf22 is set more at 5-6 for the ej18's.
Everyone takes "ignorant" as some sort of horrid insult. It's not. It doesn't mean you are stupid. It just means you don't know what you are talking about...
Old 02-08-2008, 02:28 AM   #7
'93Impreza1.8T
Member#: 171092
1993 Impreza 1.8T
Thanks for the redirect like i said any info is good.
Old 02-09-2008, 07:11 PM   #8
scubydrew
Member#: 32609
2005 saab 9-2x
rhd ej20tt sold...
I boosted my 1.8 a long time ago and ran it at 7psi then 10psi for a good 6 months beating the piss outta it. towards the end of it's life I was running 14psi on a vf22. had I not had a legacy 2.2 block sitting around, I would have thrown another 1.8 no questions asked.
scubydrew is offline   Reply With Quote
Old 02-29-2008, 02:05 PM   #9
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
For the ECU look into an emanage blue. Swap in some 91-94 legacy turbo 370cc injectors. Once you do this, pull 33% from the the MAF map. This will allow up to about 6psi of boost with no other tuning. To get more boost, you will need to pull timing from the timing map and add some fuel.
subachad is offline   Reply With Quote
Old 02-29-2008, 08:09 PM   #10
simple monkey
Member#: 81067
1989 RX, FX16
both white
if you're going to be pulling the crossmember and what-not, why not put ej22e heads on your ej18 block. with lowered compression and better flowing heads, you'll be able to up the boost with management.
simple monkey is offline   Reply With Quote
Old 03-05-2008, 02:09 AM   #11
'93Impreza1.8T
Member#: 171092
1993 Impreza 1.8T
wut do those heads come off of?
Old 04-11-2008, 05:08 PM   #12
nmbwhitey
Member#: 172443
1995 obs to gf8 conv
red
im gonna be turboin my 1.8 same rods as wrx weird. 9mm thick walls 2.
nmbwhitey is offline   Reply With Quote
Old 05-22-2008, 01:07 PM   #13
OddBallRacing
Member#: 136429
1996 ImprezaBrighton
Gawdawful Green
I'm pondering using TurboL's recipe for my '96 EJ18 Brighton:
TD04 (what about a CT26?)
WRX fuel pump (for which motor, year?)
WRX water pump? (for which motor, year?)
WRX injectors (for which motor, year?)
eBay/chinese crap intercooler and radiator
rising rate fuel pressure regulator
Greddy eManage (Ultra+accys most likely)
I'm thinking I'll keep the stock exhaust manifold and build a custom up- and down-pipe so I don't have to find a turbo crossmember.
The eManage looks like the most expensive part, aside from the new tires I better buy!
Thoughts?
TurboL, are you around? Are your eManage maps available?
Thanks!
OddBallRacing is offline   Reply With Quote
Old 05-22-2008, 09:52 PM   #14
simple monkey
Member#: 81067
1989 RX, FX16
both white
90-94 legacy non turbo had the dual port heads and will accept a wrx manifold. the newer ej22's had single port heads i think? can someone confirm this?
Old 05-23-2008, 11:40 AM   #15
jey
Member#: 32503
2011 Tribeca
1995 Legacy Wagon
My 98 Legacy's 2.2 had single-port heads. I think in 1996 they switched to single-port.
Last edited by jey; 05-23-2008 at 05:50 PM. Reason: Found information on the switchover year
jey is offline   Reply With Quote
Old 05-24-2008, 01:35 AM   #16
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
I think you are correct. 96 happens to be the first year of the EJ25... coincidence I think not!
Old 05-26-2008, 09:46 PM   #17
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
running 7 psi here on a 1.8 w. ej22t heads. pretty fun.
shooting for 17 psi out of the td04 when i get bigger injectors
mxpunk is offline   Reply With Quote
Old 06-03-2008, 07:00 PM   #18
4drgc8er
Member#: 180990
93 boosted impreza
white 2.0 18g
can i use wrx header uppipe and down pipe i have everything from my wrx that i have swaped out for better parts
4drgc8er is offline   Reply With Quote
Old 06-04-2008, 10:27 PM   #19
blackturbo
Member#: 139365
1995 Impreza L
If you have a ej18, you can hook up a wrx header up pipe/downpipe but you'll either need to notch the crossmember or get a turbo crossmember. You also have to relocate the water pump i believe. The good thing is that you can acquire the parts for next to nothing.
blackturbo is offline   Reply With Quote
Old 06-09-2008, 10:47 AM   #20
panky14
Member#: 181479
sorry, im not able to post a thread anywhere else. if it doesn't bother you guys, does anybody know if i can put sti pistons on a 97 legacy ej25 engine for turboing. is there a recipe for this? thanx
panky14 is offline   Reply With Quote
Old 06-10-2008, 02:47 AM   #21
pheonix991
Member#: 154173
2006 STI
Pistons don't make an engine turbo. If it is the ej25D, don't even bother with a turbo, get a swap.
Old 06-10-2008, 08:06 AM   #22
turboL
Member#: 111735
97 Impreza L
Rust and White
i think i can find some maps, they are all for 550cc injectors with a blow through maf setup. PM me if youd like them.
and to the people who dont believe that turboing the ej18 is a worthy venture, talk to the STi's I walked on. And itd still be running if I put the correct headgaskets and headbolts on it from the get go.
heres my thread:
http://forums.nasioc.com/forums/show...ghlight=turbol
turboL is offline   Reply With Quote
Old 07-01-2008, 11:43 PM   #23
WickedRydaX
Member#: 31900
I am running my 1.8 (220,000+miles on the engine) at 10-12 psi with a TMIC, but no scoop so it might as well be non intercooled. Stock USDM STi injectors, Field FC, E85 fuel, the rest of the ECU system is stock, VF22 JC sports kit, WRX trans with RA gears, twin plate exedy clutch, WRX rear diff, and 2.2 cams in 1.8 heads for the engine. I didn't feel the cams till I turned the boost up, but they are nices from 4-6k. Other chassis mods, WRX sways front and back, WRX rear disc brakes, JDM black 4 pots up front, WRX stock wheels for summer, 5 spoke RS goldies for winter, WRX seats F&R.
I wish I had a better tuning system I know it has a lot more power, high rev limit, and drivability (idle and MPG issues). I just have a hard time buying a nice system for a $3k car. Everything else has been hand me down parts from other car. It is a lot of fun to drive top 3 of cars I own right now. Beats up on WRX, haven't run any STi yet. I should take it to the track to see how it runs, but I am lazy. Matt come pick it up tomorrow and make an afternoon out of it.
MCL
WickedRydaX is offline   Reply With Quote
Old 11-01-2012, 11:15 AM   #24
95imprezasears
Member#: 336709
Default 95 impreza 1.8l
i was also thinking about throwing a turbo on my 1.8 to see what i can get but from what i have heard its better to swap but what motor should i swap into it any suggestions?
95imprezasears is offline   Reply With Quote
Old 11-01-2012, 02:21 PM   #25
pheonix991
Member#: 154173
2006 STI
ej257, ej22T, ez30r
('93-'01) 2.5RS or A4 1.8T? Kamb1ng Impreza Forum 30 03-15-2015 04:12 PM
Impreza 1.8T '93Impreza1.8T Normally Aspirated with bolt-on Forced Induction Powertrain 12 02-09-2008 09:09 PM
1.8T in Impreza? martonikaj Subaru Conversions 14 12-04-2006 06:36 PM
'02 impreza 2.5TS to '01 a4 1.8t avant soccrstar Off-Topic 5 11-18-2005 06:44 AM
impreza or gti 1.8t? pman81 General Forum Archive 16 10-03-2000 09:29 AM
