Welcome to the North American Subaru Impreza Owners Club Thursday September 19, 2019
Old 04-11-2011, 10:59 PM   #251
fan boy
Member#: 241243
Originally Posted by blk25rsti View Post
Subscribed! Looking to do this to a 91 Toyota pickup
nice! i heard there was a 4runner with the subaru drivetrain up at the wicked big meet last year--such a sleeper
fan boy is offline   Reply With Quote
Old 04-12-2011, 12:46 AM   #252
Subhuman
Member#: 82339
2004 Legacy Spec OB
Mystic Blue Pearl
Subfvckingscribbed to the thread to end all threads!
Subhuman is offline   Reply With Quote
Old 04-12-2011, 09:58 PM   #253
Hogie
Member#: 97017
2015 Mustang GT PP
Competition Orange
If you convert to a 4runner or 4x4 toyota bumper and valance you will have room for a front mount. I am sure you could fab up the mounts easy enough. It looks much better when they don't remove all of the bottom half though.
Hogie is offline   Reply With Quote
Old 04-13-2011, 06:27 PM   #254
stimanmark
Member#: 235859
2004 WRX STI
World Rally Blue
And they make direct bolt on adapter kits so you can fit that toyota front end on your truck
stimanmark is offline   Reply With Quote
Old 04-13-2011, 09:20 PM   #255
fan boy
Member#: 241243
i didn't think of that...whew those just blew right past me!
Old 04-14-2011, 06:47 PM   #256
Mad Ra88it
Member#: 113563
98 Unicorn
The bumper doesn't line up well with the fenders though...cut and weld time!
I own a B2000 with a bumper that took a ton of time to make work with the fender lines.
Mad Ra88it is offline   Reply With Quote
Old 04-19-2011, 01:10 AM   #257
ConfusedZombie
Member#: 280187
The automotive hobby needs more like you, well done sir!
ConfusedZombie is offline   Reply With Quote
Old 04-19-2011, 07:17 AM   #258
stimanmark
Member#: 235859
2004 WRX STI
World Rally Blue
Indeed!!!!!!
Old 04-19-2011, 02:49 PM   #259
ben_art
Member#: 172635
2003 WRX Wagon
opc orn:
ben_art is offline   Reply With Quote
Old 04-19-2011, 08:50 PM   #260
fan boy
Member#: 241243
/\ Thanks , i agree! Sometimes you don't hear about them on the interwebbing-- He shows up to shows with a 5-600hp monster--
mad ra88it--how far does the bumper stick past the grille?
so nhra wants braided fuel line on non-stock fuel systems, so i tried using earl's compression fittings on the stock fuel lines to adapt them to AN style fittings---Well I wasn't happy with them, so I bought aftermarket fuel rails..
They have 10.5 cm holes and do not fit the stock injectors. Are there any solutions to make them work with stock sized injectors?? i already have a fuel cell mounted along with an aeromotive FPR---
Old 04-19-2011, 10:56 PM   #261
kaos200
Member#: 2692
Originally Posted by fan boy View Post
....Well I wasn't happy with them, so I bought aftermarket fuel rails..
10.5cm holes?
mm? Can you explain? Which fuel rails did you buy? Doesn't make sense that your stock sized injectors wouldn't fit.
kaos200 is offline   Reply With Quote
Old 04-20-2011, 01:42 AM   #262
fan boy
Member#: 241243
yes MM---
the ports where the upper injectors attach to the fuel rails via o ring are larger than stock---the fuel rails are driller for larger diameter injectors ---
Old 04-20-2011, 03:29 AM   #263
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP 2016 Sienna
subscribed ftw
Celery GT-5 is offline   Reply With Quote
Old 04-20-2011, 09:17 AM   #264
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
What brand of fuel rails did you buy? Whatever they are, they're apparently not the right ones.
Old 04-20-2011, 07:14 PM   #265
stimanmark
Member#: 235859
2004 WRX STI
World Rally Blue
Old 04-22-2011, 12:17 AM   #266
fan boy
Member#: 241243
those bumpers don't look like they stick out any more than the stock one?
Old 04-22-2011, 12:35 AM   #267
fan boy
Member#: 241243
cheapy no name----guess i got what i paid for
i had a new pair sent out to me---it's a beauty
also got the FPR mounted to the firewall and some braided hose ran under the hood---fingers crossed, should have it test fired tomorrow after we check for leaks.
Old 04-22-2011, 09:19 PM   #268
fan boy
Member#: 241243
no leaks! sweet--- hehehe she turns over, but doesn't have spark or any fuel smell---I removed the timing covers and double/triple checked everything looks OK. whats going on here??
Old 04-23-2011, 01:09 AM   #269
omz
Member#: 232060
is everything plugged in?
omz is offline   Reply With Quote
Old 04-23-2011, 11:04 PM   #270
fan boy
Member#: 241243
i think so---then again wiring is not my forte...
edit- cam/crank sensors are connected--as are everything else UNDER the hood...
as far as in the interior, what all needs to be hooked up? is there a ignition module? does the ecu have to see fuel pressure?
Old 04-24-2011, 07:26 AM   #271
sackytar
Member#: 149262
03WR rallycarFXTleg
PrimerGrey
Huh
Well I know that in wrx ecu maps that their are variables to tweak fuel pressure. And when people runE85 they have to run higher fuel pressure to compensate for the more fuel needed. So I would think that engine wants to see where the fuel is at to prevent irregularities in a/f ratios and prevent knock.
R
sackytar is offline   Reply With Quote
Old 04-25-2011, 12:47 AM   #272
bmw50021
Member#: 122393
02 WRX
Originally Posted by sackytar View Post
Huh
R
bzzzzt wrong. fuel pressure is controlled by the fuel pressure regulator which responds to vacuum/pressure and has no electronic control.
bmw50021 is offline   Reply With Quote
Old 04-25-2011, 12:50 AM   #273
bmw50021
Member#: 122393
02 WRX
check that the injectors are firing with a simple led & resistor on their connectors, or noid light, or oscilloscope. check fuel pressure with a gauge. also check that your fuel lines are connected properly. if you have the supply and return switched around, it won't work. check for spark as well. if you are using wrx/sti coilpacks with internal ignitors, the led trick will work for that as well. there are 3 wires, 12v, gnd, and signal from the ecu. pretty sure signal varies between 0-5 volts.
Old 04-25-2011, 10:31 AM   #274
sackytar
Member#: 149262
03WR rallycarFXTleg
PrimerGrey
Fanboy
No ****. For some reason thought it was ecu controlled. So here's a question when dudes are switching to e85 yeah injectors are upgraded and fuel pump too, is it just the fuel regulator that controlls flow or does injector scaling also have a part?
Just wanna know how it works.
Old 04-25-2011, 10:57 AM   #275
makopolo
Member#: 260046
2011 WRX Hatchback
Anytime injectors are changed they need to be recalled. This is usually done using the learned fuel trims so its important that the maf readings are correct.
makopolo is offline   Reply With Quote
School me on the Nissan Hardbody pickup truck. plunk10 Off-Topic 50 12-12-2015 12:01 PM
03 WRX drivetrain ---> 97 OBS fourstrokephysics Subaru Conversions 5 09-06-2012 12:30 PM
FS : MI: 96 Brighton with 02 WRX Drivetrain Swap eatadolfin Private Vehicle 'For Sale' Classifieds 9 09-22-2010 10:12 AM
FS: AZ - 1993 Nissan Hardbody, bagged with fully built backhalf and suicide door v8eaterWRX SWIC Private Classifieds 14 05-15-2010 03:23 AM
