Welcome to the North American Subaru Impreza Owners Club Wednesday September 23, 2020
Old 05-13-2011, 06:57 PM   #1
"lego"
Member#: 263187
Default Question about ecu's
Ive got a 92 legacy with the normal 2.2 in it..i wanted to know can my 2.2 ecu run ej25d cylinder heads? I know they dont fit due to the intake manifold. I plan on doing a build later on, i just need to know this part in order to move on..
"lego" is offline   Reply With Quote
Old 05-17-2011, 12:47 AM   #2
RallyColtTurbo
Member#: 16819
Yes. The only sensor on the head is the cam position sensor, and it is compatible. In fact, it's the same sensor.
The problem you will run into is that the only (common) throttle bodies that are compatible are the early Legacy EJ22/EJ22T and the early EJ20Gs ('89-'96). This is because of the separate idle switch in the TPS. EJ20K and EJ25D models do not use this.
Pick an intake manifold compatible with one of these throttle bodies. I *believe* an EJ22/EJ22T throttle body will bolt to an EJ25D intake manifold. The issue is where the throttle cable lands on the throttle body compared to where the bracket is on the manifold.
RallyColtTurbo is offline   Reply With Quote
Curious about ECU's with different engines mr_subaru_rs Normally Aspirated Powertrain 2 08-22-2007 05:43 AM
Questions about swapping ECUTEK ECU's B16A2NR Engine Management & Tuning 3 01-22-2006 09:43 PM
Noob AP question about 04' 05' ECU's M8 Engine Management & Tuning 11 06-19-2005 10:36 PM
question about jdm ecu's Benjamin Tang Engine Management & Tuning 2 06-04-2004 09:45 AM
About to buy STi, question about Subaru's fit & finish... JT-KGY STi Forum Archive 19 01-27-2003 02:39 PM
