Welcome to the North American Subaru Impreza Owners Club Monday June 5, 2023
Old 03-04-2023, 07:28 PM   #1
Mauled
Member#: 500169
Default Gtx 3076r gen 2 vs gtx3582r gen 2 ej207
I have a gtx30r gen 2 .82 currently on a ej207 v8 with built heads and cams. Wondering if it's worth it to upgrade to a gtx35r and how much power gain I would see. Currently I make full boost at 4.8k which is 28psi. I want to crack 500whp, I have no idea what power I'm making now, I'd say around 480.
If I get the 35r gen 2 should I go .63 or .82? Also could I turn the rpm up to 8500 safely?
Car is 2005 wrx, daily driver, no track time
Ej207 v8 gsc s1 cams valves springs retainers
50/50 meth injection and 93.
Mauled is offline   Reply With Quote
Old 03-04-2023, 09:32 PM   #2
K3rm1tth3fr0g
Member#: 508105
Link G4X flex tuned
02' EJ205 20G 6MT wagon
Many many variables here. Too many to say anything with certainty.
Going from a GT30 to a GT35 will certainly open up the topend while killing midrange, but exactly how much depends on the turbo.
The 3576 Gen 2 is actually a more balanced turbo than the 3076 you're on now, of which it shares its compressor wheel dimensions. It's much better suited for 500+ applications than the 3076. I have a Gen 2 3576 in my garage waiting for my built motor.
Without corn makes hitting 500 tougher but the meth of course helps - you just risk the meth system failing and the motor blowing up at high RPM... Such is life without corn.
I would guess going to a 3576 with a .82 you'd spool just a hair later with a lot more topend. Being a 2.0L though does seriously hinder spool and boost threshold though.
There are many schools of though regarding A/R selection. .82 is a good middleground for most setups, with the 1.xx A/Rs typically either killing spool/boost threshold, or making the motor feel more N/A like with a more linear power delivery. The ladder of which can actually be preferable. .63 will hit hard but drop off, not really what you want if you're sizing up to a GT35, though on a 2.0L a GT35 w/ a .63 house makes much more sense than a 2.5L.
I'd stay .82 probably though if you are up-sizing turbos.
With a 3576 you could probably hit 500 with meth. Same with 3582 but the spool and response will be considerably worse.
Do you have a tuner who you can discuss options with? They are always a good resource to engage if possible as they have a good understanding of the ramp rates, and how A/R affects power and spool. I would advise getting on a dyno rather than E-tuning a setup like this.
Not to throw another wrench in the mix but the EFR turbos also kick ass.
K3rm1tth3fr0g is offline   Reply With Quote
Old 03-05-2023, 08:41 AM   #3
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I would start with getting the car on a dyno as-is, so you know where you are truly starting from. 20whp is not a big gain and could potentially done with other mods alone. Heck, with an EJ20 and cams already, you could go to the next size A/R (1.06 IIRC) and gain that 20 you're looking for up top.
Going from a 3076 to 3576 will typically yield 80-100whp on an EJ25, on an EJ20 less, but still more than enough to exceed your goal with minimal increase in spool time. A 3582 will add a lot of lag. On an EJ20, you'd really want to have the heads built for high end use. At stock RPM range, there's just not enough gas flow to really take advantage of what the 3582 needs to make best power.
KillerBMotorsport is offline   Reply With Quote
Old 03-05-2023, 08:49 AM   #4
benflynn
Member#: 515308
E85 E85
benflynn is offline   Reply With Quote
Old 03-05-2023, 10:30 AM   #5
K3rm1tth3fr0g
Member#: 508105
Link G4X flex tuned
Originally Posted by benflynn View Post
E85 E85
Old 05-12-2023, 07:18 PM   #6
Mauled
Member#: 500169
Well my heads are fully built, but the bottom end is stock. I might get a 3576r. I can't find any info about people running a 3576 or a 3582 on a ej207. My car makes 27psi by 5k rpm. Just wondering when you think the 3576 will spool? And will it hit 500whp with meth?
Old 05-23-2023, 11:19 AM   #7
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
The 3582 will get you 500whp no problem. Just remember you'll need to run it in the mid/upper 20psi range to hit your 500whp.
The 3576 runs a smaller compressor wheel. It may come on a little quicker but you'll have to run it around 30psi range to clear 500whp.
Your stock bottom end will die eventually. Don't lean out or detonate.
FuJi K is offline   Reply With Quote
Old 05-23-2023, 11:52 AM   #8
subaru_gc8
Member#: 29292
2004 WRX wagon
my question is why not consider a g30 770 if you are looking for the 500 level? why not go with the newer tech?
subaru_gc8 is offline   Reply With Quote
Old 05-23-2023, 12:13 PM   #9
K3rm1tth3fr0g
Member#: 508105
Link G4X flex tuned
Couldn't agree more
G30 770 is the ultimate SWEET spot for ~500+
Gt30 spool and response with gt35 power
Old 05-24-2023, 01:11 PM   #10
Mauled
Member#: 500169
What will the gtx 3582r spool at? I have gsc s1 cams and beehive springs plus aftermarket valves could I turn rev limit to 8500?
Also reason I can't get the g series turbos is because I don't have a actual garrett it's a 3076 copy. I don't want to spend 3k on just the turbo alone. Plus there's no actual data with the g series turbos that I can find. Even the gtx turbos don't have much info, cant find anyone running one on a ej207. When I switched from the gt3076 .63 to the gtx gen 2 .82 and added cams, my car doesn't spool up till 5k now, with the gt3076 I was making 24psi by 4200.
Old 05-24-2023, 02:27 PM   #11
HughGordon
Member#: 355996
You can get a G-series copy too.
HughGordon is offline   Reply With Quote
Old 05-24-2023, 03:51 PM   #12
Mauled
Member#: 500169
Who makes it? But still I have no idea when it will spool, haven't seen much info on these turbos on our cars.
Also my tuner won't go past 24-26psi of boost so i can't be running 30psi
Old 05-24-2023, 04:41 PM   #13
K3rm1tth3fr0g
Member#: 508105
Link G4X flex tuned
Late, like 4500+
A crappy one
Wut? Who's the tuner
Why in the hell does your tuner have an arbitrary boost limit without even knowing the turbo?
Max boost absolutely depends on the specific turbo and it's efficiency islands. Saying 24-26 is the max is quite silly and makes no sense.
What makes 27psi inherently more dangerous than 26? Nothing aside from the increased flow
Made up limits are dumb
Old 05-24-2023, 05:16 PM   #14
HughGordon
Member#: 355996
Originally Posted by K3rm1tth3fr0g View Post
A crappy one
Yeah or a good one...
Old 05-24-2023, 05:17 PM   #15
HughGordon
Member#: 355996
double post
Old 05-24-2023, 05:17 PM   #16
K3rm1tth3fr0g
Member#: 508105
Link G4X flex tuned
Good knock off turbos are virtually non existent without spending 65%+ of the cost of the real product.
This is even more true with the ultra cutting edge tech like the G series....
Old 05-24-2023, 05:31 PM   #17
Mauled
Member#: 500169
I've asked tuner if he could do 30psi but he said since the bottom end is stock he doesn't feel safe doing it. Also I disagree my last gt3076 was $200 and I kept up with cars making 500whp, never had a problem with it only pulled it to get a gtx. I understand wanting the real thing but the gt I had performed exactly like a garrett. I've had knock off turbos for 4 years now, as well as the wrx 5 speed that hasn't blown up yet. My friend who drifts his car has a no name gtx3582r and drifts it every weekend with no issue. The knock off turbos are better then you think.
Old 05-24-2023, 05:35 PM   #18
HughGordon
Member#: 355996
Yeah ok, what do you think is so expensive to make on a G-series turbo? The copies don't have a Mar-M turbine but who really cares about that unless you plan on running a lot of anti lag and such. Turbos are way overpriced it's rediculous.
Old 05-24-2023, 05:37 PM   #19
HughGordon
Member#: 355996
Totally agree with you there. Turbos cost such little money to manufacture. It's funny because in v8 turbo world, people think that VS racing turbos are expensive.
Old 05-24-2023, 05:43 PM   #20
K3rm1tth3fr0g
Member#: 508105
Link G4X flex tuned
Definitely didn't perform like a real Garrett, doesn't matter what the butt dyno said.
The "my buddy does it" argument doesn't really work when most people are buying $1000 knock off turbos and claim they're a good deal.
If you feel safe running a $200 turbo, more power to you.
Aside from R&D, materials, manufacturing, quality control, and support.
Old 05-24-2023, 06:00 PM   #21
HughGordon
Member#: 355996
You "definitely" know this how? Have you ever seen a back to back test with a copy vs a Garrett? Why are you such a know-it-all?
Old 05-24-2023, 06:52 PM   #22
Mauled
Member#: 500169
Lol the $200 one spooled exactly the same as a real garrett, same rpm. Kept up with a 530whp supercharged camaro, he only barely started pulling away in 4th gear. And that was on 24psi with no meth.
The garrett turbos are definitely overpriced.
Old 05-24-2023, 07:03 PM   #23
K3rm1tth3fr0g
Member#: 508105
Link G4X flex tuned
Seen enough dyno sheets comparing knock off Garrett crap to the real deal.
Also lol
Dyno sheet?
Definitely feel free to buy a $200 turbo if you want - no one is stopping you.
I have seen enough cheap CWs and turbos in general grenade for me to not feel comfortable doing it myself.
Research and development + meaningful support costs money - gotta pay to play.
You're right, it's much easier and cheaper to just steal intellectual property and produce it in countries with dirt cheap slave labor.
Old 05-25-2023, 07:33 AM   #24
HughGordon
Member#: 355996
Can you show us all these dyno sheets? You know that Garrett make turbos in China too right? Lol.
I have purchased both a band new Garrett g-series turbo and a Pulsar Gen ii copy within the last year. I have yet to run the Garrett but the Pulsar has been performing great. The Pulsar turbo comes with full gasket set, and a nice full color install sheet. The Garrett came with one gasket (bent in package), flange with clamp, and an install sheet that had typos. It's all just marketing just like any luxury item now. There is a market for copies that perform just as well as the real thing because the real thing is overpriced.
I find it funny/annoying that you are in every thread trying to gate keep tuning and modifying Subarus. Trying to tell every person what parts they can and can't use, ****ting on people for using brands that you have deemed unworthy. What makes you an expert on any of this stuff besides regurgitating stuff other people have said? Get over yourself dude. You make this forum boring to read.
Old 05-25-2023, 09:56 AM   #25
K3rm1tth3fr0g
Member#: 508105
Link G4X flex tuned
China has good and bad labor practices. It's not as simple as, China labor bad.
you know that Garrett make turbos in China too right? Lol.
You're upset because the gaskets that came with were bad....?
Who uses included gaskets anyway?
Hahaha - no one is gatekeeping anything.
That is rich coming from a goober who contributes nothing to the forum.
