#1 |
Member#: 531699
Vehicle:2023 Crosstrek |
![]() I thought I'd ask here as there's a lot more 'how to' knowledge floating around here than on most Subaru forums. I installed a Quaife ATB differential into a 98 outback 4.44 housing, I then installed that housing into my 2023 crosstrek 6MT. I did the gear pattern check and it was good, I put new carrier bearings in. I did not touch the pinion setup. The pinion preload seemed to be at the lower end of the range (not surprising with a used differential unknown miles, but good condition). Backlash was good as well. Installed it with Amsoil 75w-90.
So far I've put about 200-300miles on it and no leaks or noises. When driving I hear the tires most of all and a little engine noise when giving it throttle. I've checked it with an IR temp gun after an hour long drive and it was only about 95* on the aluminum rear cover (this is in Alaska in September, so ambient temp was only 50* or so) . No noticeable increase in drive train slop. So everything seems hunky dory, but this is my first differential swap/setup I've done myself. It didn't really require any 'setup' I put it back together with the spacers that were in it, checked backlash and tooth pattern after torquing the side plates down. I have a long cross country trip coming up (Alaska to NJ) and wanted to see if anybody out there had any experience with swapping a diff out and how soon the first signs that you didn't do something quite right show up? I still have the factory differential assembly that I can reinstall at any time relatively easily (it's just drained, I'll probably take it with me on my trip). Any experience on what to look/listen for? or check before a long trip like this?
#2 | |
Member#: 508105
NWIC
Vehicle:Link G4X flex tuned 02' EJ205 20G 6MT wagon |
![]() Quote:
#3 |
Member#: 531699
![]() I read up on that, it seems it's an issue for 'shiny' metals. I cleaned the gunk of the factory aluminum cover, but I don't think it would classify as shiny. But next time I'm out in it, I'll run the thermometer over a few different spots on it.
Last edited by Chopperpilot; 09-19-2023 at 01:10 AM. Reason: looked up thermal distortion |
#4 |
Member#: 532328
![]() If it's not getting hot in the first few hundred miles it is almost certainly fine.
#5 |
Member#: 531699
![]() Thanks, I towed a trailer with it today (maybe 1K lbs total) helping the girlfriend get a woodstove. I checked with the IR temp gun and it was about 112*, 120* at the cv axle seal area (this coincides with transfer cases I've checked as well, hotter at the seal). Still no noise, so I can probably relax and stop wondering about it.
#6 | |
Member#: 508105
NWIC
![]() Quote:
#7 |
Member#: 491095
SWIC
Vehicle:2009 STi Blue Blue |
![]() normally if its not setup correctly it will make alot of noise or fail within the miles you have on it already...if it tracked well and as you had described it, i would call it good too!
#8 |
Member#: 531699
![]() Thanks guys! I appreciate the responses. I 'tried' out the differential (before and after) on crossed up wheel ramps, the difference was pretty amazing. Stock it wouldn't back up the crossed up ramps (1 frt wheel/1 rear wheel) at all, with the Quaife, it spun for a sec, then backed up lifting a rear wheel off the ground. Just like I heard, with the modern traction control on these cars, it really makes the helical gear LSDs perform nicely.
I drove from Kansas to Alaska pulling a trailer with my truck with a recently rebuilt turbo, so I'm getting more relaxed about it being good to go. I figured like the turbo, if you don't set a rear end up correct, it'll let you know pretty soon. |
