07-26-2001, 07:54 PM | #1 |
Member#: 457
Vehicle:---- Smells like weed and rampage |
long, hard left turn + hard acceleration + shifting = 2nd gear grind?
Here's the situation:
Wide intersection, green turn arrow, have to hustle across 4 lanes to make the next light. Shift to second while cornering and accelerating, and second gear grinds. It had been doing this a lot (under all kinds of conditions), but I changed my tranny oil and it seemed to go away, except this one circumstance. Any ideas why this one situation would make second grind like that? I think my clutch is going out, wonder if that has anything to do with it? Could the transmission mounts be flexing enough while turning to mess up the clutch cable and cause it to not be totally disengaged? Any other thoughts? Josh
07-26-2001, 10:00 PM | #2 |
Member#: 815
Vehicle:2013 Boss 302 White 2008 S2000 CR ABP |
Hmm, sure you filled up the tranny with enough oil? Perhaps oil starvation on the lateral g's during cornering? Don't know. I doubt the cable is the culprit.
- Steve |
07-26-2001, 11:14 PM | #3 |
Member#: 457
There's definitely enough oil in the tranny... This tranny is out of a 1998 Impreza, and only has about 15k on it, so I doubt it's the synchros going out (which was my first thought).
07-27-2001, 01:35 AM | #4 |
Member#: 1818
Vehicle:03 1996 Impreza Wa Soon to be a v3 STI |
You need to double clutch or heel toe.
07-27-2001, 04:54 PM | #5 |
Member#: 457
Thanks for the suggestions, but to my mind, this is a symptom that something is wrong. I'd rather find out what the problem is and fix it than simply mask the symptoms. Double clutching may help, but where do you get this heel-and-toe business? I always do that while braking, but it's not an effective strategy while accelerating.
Josh |
07-27-2001, 05:44 PM | #6 |
GC84Ever
Super Moderator Member#: 301
NWIC
Vehicle:1970 FF-1 & '70 Van 02 WRX/01 RS |
2nd gear is the subie's weakest link...
that is the gear that goes first... very common in racing.. if you are doing hard shifting... well now that's similar to racing... hmmm...... i'd be concerned... j. www.subiegal.com |
07-27-2001, 10:25 PM | #7 | |
Member#: 457
2nd Gear Grind | rodney757 | Transmission (AT/MT) & Driveline | 19 | 02-28-2010 03:05 AM |
E-brake light came on during hard left turn | QwikRex | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 11-03-2007 10:32 AM |
Jerking acceleration in 2nd gear | WimpWgn | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 11-01-2004 01:51 PM |
2nd gear grind...diagnosis? | b00st3d | Transmission (AT/MT) & Driveline | 1 | 09-11-2002 12:11 AM |
'95 1.8 L - 2nd Gear grinding and fighting me | Kostamojen | Transmission (AT/MT) & Driveline | 10 | 10-11-2001 04:18 AM |
