Welcome to the North American Subaru Impreza Owners Club Thursday September 20, 2018
Old 07-10-2012, 11:33 PM   #1
tebriel
Member#: 244190
2004 WRB WRXes
Sedan and Wagon
Default Compression test tips
When I was trying to do a compression test on my outback, I found it was a total PITA to get the compression tester with the flexible hose threaded into the spark plug hole.
Does anyone have tips on how to do that? Is there an adapter that people use at all to make it easier?
Thanks!
tebriel is offline   Reply With Quote
Old 07-11-2012, 12:34 AM   #2
renhoek
Member#: 71339
1995 WRX STi RA
1995 WRX STi LS1
Nahhh. It's a pain. Just keep fiddling with it. You'll get there.
Good idea to be relaxed while you are doing it, with no time pressures. Otherwise it will take even longer!
renhoek is offline   Reply With Quote
Old 07-11-2012, 07:55 AM   #3
tebriel
Member#: 244190
2004 WRB WRXes
Sedan and Wagon
hah ok, will do. Thanks!
Old 07-11-2012, 08:41 AM   #4
GDR
Member#: 34924
03 WRX Wagon
81 Scirocco S
Spark plug anti foulers. I use three of them locked together.
GDR is offline   Reply With Quote
Old 07-11-2012, 11:43 PM   #5
tebriel
Member#: 244190
2004 WRB WRXes
Sedan and Wagon
GDR Thanks! That's exactly the type of thing I'll have to go hunting for.
Old 07-12-2012, 09:21 PM   #6
oaklandish_WRX
Member#: 267339
2002 0[[XXXXoXXXX]]0
MBP LongRoof
My new hero...awesome idea, especially for those of us of generous proportion.
oaklandish_WRX is offline   Reply With Quote
Old 07-13-2012, 09:02 AM   #7
jays05
Member#: 78165
05 STI 35r + e85
Put a rubber hose around the compression tester hose - it will help center it better.
jays05 is offline   Reply With Quote
Old 07-13-2012, 11:00 AM   #8
tebriel
Member#: 244190
2004 WRB WRXes
Sedan and Wagon
^^ that's an interesting idea.
I just bought 4 anti-foulers. So I think that should work well and make it a lot easier and quicker.
Old 07-13-2012, 11:24 AM   #9
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
Make sure the anti-foulers are very tight or Jbwelded. The last thing you want is for one of those to be stuck in the sparkplug hole while the rest of them unscrew from one-another. <<< would be a nightmare and is a pita to fix.
Also put a little grease or wd40 on the rubber boot inside the sparkplug socket, so that doesnt get stuck on the plug when you go to pull it out. Or tape it.
2gnt2wrx is offline   Reply With Quote
Old 07-13-2012, 11:27 AM   #10
tebriel
Member#: 244190
2004 WRB WRXes
Sedan and Wagon
2gnt2wrx, each anti-fouler is hex, so a socket would just pull it out anyway
But yeah, I'll put threadlock on them.
Anyone know of a writeup on how to do a leak-down test for subarus?
Thanks!
Old 11-12-2016, 07:21 AM   #11
wrxnh
Member#: 393998
/// WRx ///
I know it's an old thread but anyone know what size / part # for the non-fouler to get for the above photo? Been searching forever...
wrxnh is offline   Reply With Quote
Old 11-14-2016, 12:56 PM   #12
oaklandish_WRX
Member#: 267339
MBP LongRoof
https://www.oakos.com/wrx/specs.htm
