09-20-2003, 01:48 PM | #1 |
Member#: 40782
SCIC
Vehicle:2007 UGM STi/97 EK 301 whp/339 whp |
best way to launch stock wrx?
ive been trying to launch my car at the drags but every time i bog. ive tried going to 6k and slipping it dut that doesnt help much. i even dropped it once and that was a bad idea. so what should i do to get the best 60' time out of this thing?
09-20-2003, 02:15 PM | #2 |
Member#: 21999
Vehicle:2017 Wrx DGM |
When I was stock I would just wait for the first yellow to hit then I'd smash the gas and let up on the clutch to get the car rolling. Then I pulled my foot smoothly the rest of the way off the clutch after the car moved, kinda like picking your foot up off the ground after you have just stepped on a piece of gum. A bit of wheel spin and your off. Just keep it smooth, don't be jerky and you gear box will like you for it. IMHO if you don't get a little wheel spin you will bog and add extra shock to the drive train.. Good Luck!
-Fess |
09-22-2003, 01:28 AM | #3 |
Member#: 16771
Vehicle:12.9 @ 102MPH 1.784 - Stock Turbo |
1. bounce/pulse rpms btw 4-6k
2. floor 3. drop/slip clutch 4. be out... <--------- |
09-22-2003, 02:52 PM | #4 | |
Member#: 18038
09-22-2003, 05:01 PM | #5 | |
Member#: 16771
pretend like you just stepped in dog ****, and you hafta retract your foot bak... |
09-22-2003, 05:51 PM | #6 | |
Member#: 33846
09-23-2003, 05:04 AM | #7 |
Member#: 44003
Vehicle:2004 Evo (sold) |
1. Before triggering the second yellow light of staging push the clutch all the way in and come to a stop. Release the clutch until the car starts BARELY moving forward, remember that "position" and put the clutch in all the way in until you stop. Then do the same thing until you stage but hold the clutch right before the "position."
2. Rev to 5500 while making sure that the car isn't moving 3a. Do what the guy said about lifting your foot off of a dog that you stepped on. (You have to feel the clutch engage, it is just something you have to practice) OR 3b. Side step that mug if you have the tires pumped up to max PSI and you have enough saved for another tranny. (You have to try it sometime! ) Note: If you are on a track that is uneven, use the e-brake. This works pretty good even if you are on a level track because you can build boost quicker by pulling the brake up higher (more clicks) and letting off the clutch a little more than in step three. You will feel the car trying to move. Once the second yellow light goes, start releasing the clutch and drop the brake. It takes some coordination though. |
09-23-2003, 05:20 AM | #8 | |
Member#: 31506
Vehicle:05 Tacoma on TE37' White |
09-23-2003, 08:49 PM | #9 | |
Member#: 33846
Best way to launch AWD WRX and STI | hwy61 | General Community | 40 | 07-04-2005 03:05 PM |
Best way to launch the 04' WRX... | WReX4 | General Community | 27 | 03-06-2005 03:10 AM |
Best way to launch?! | ChipJRyan | Transmission (AT/MT) & Driveline | 3 | 08-15-2004 03:00 PM |
best way to launch?? | wrx_snobordr | Proven Power Bragging | 14 | 01-07-2004 12:37 PM |
Best way to launch in an automatic? | fOoLiO37 | Newbies & FAQs | 9 | 12-25-2002 12:53 PM |
