Tire & Wheel Forum sponsored by The Tire Rack |
08-04-2005, 01:41 AM | #1 |
Member#: 64802
Hankook Ventus R-s2
After searching and reading reviews I think I'm going to get the HANKOOK VENTUS R-S2 tires for my 05 wagon.
What are the chances of getting 25K+ miles out of these? I haven't found much information about long term wear. I do the occasional auto-x and I drive pretty conservatively on the street with the occasional 40 MPH, 90 degree turn or the 90 MPH sweeper when it's safe to do so. Probably 40% city 60% hwy. The only other option I've found that I like that would seem to provide a little bit better wear would be the BFG G-Force Sports but would they be anywhere near as sticky as the R-S2? Also, I will be using these on the stock 16x6.5 rims. With the BFGs I could squeze in a 215/55 without too much bulging. The only size wider than the 205/55 in the R-S2 is the 225/50. Are the sidewalls of the R-S2s stiff enough that I could run the 225s on a 6.5" wheel without too much turn-in loss? Thanks, Jeff
08-04-2005, 09:17 AM | #2 |
Member#: 20301
Vehicle:2004 BMW M3 lightweight optioned |
It will currently be hard to find good long term mileage numbers out of these Hankook's since they are so new. Pretty much all you will find right now is estimates.
08-04-2005, 11:58 AM | #3 | |
Member#: 86316
Vehicle:2003 WRX Wagon I eat rice...Its good 4 u |
08-04-2005, 01:48 PM | #4 |
Member#: 2279
South East
Vehicle:2000 Slingshot Pastelito Racing |
I've had them on since April. 215x45x17. I've also tracked them at Homestead, and still have a lot of meat left, considering their 200TW. They are an AWESOME tire, and get really sticky when warmed up. Plus, you can't go wrong with the price. Definitely an excellent competition to the Azenis 615.
08-04-2005, 01:52 PM | #5 |
Vehicle:OK buy Nates beans westcoastroasting.com |
My set has ~1500 miles on 'em and so far, for the $$$ , impossible to beat---IMO
08-04-2005, 02:08 PM | #6 | |
Member#: 86316
Yeah... I've been getting good feedback on them.... I just wish I could get someone to tell me if they are running 225/50's on stock 16 x 6.5 wheels??? |
08-04-2005, 02:15 PM | #7 |
Member#: 53548
SCIC
Vehicle:2004 WRX PSM (sold) 2007 S2000 |
I just got 225/50R16 R-S2's put on my stock wheels this morning. My next autocross event is August 13th. I'm not sure how much information I'll be able to get since the event is in the dark, I've upgraded the front sway bar since my last autocross, and the only tires I can compare these to are the OEM RE92's that I wore out.
08-04-2005, 02:39 PM | #8 | |
Member#: 86316
Cool!! Sounds like you are on the same path as me. I just ordered my new front sway bar and end links (Perrin). My next autox is Aug. 14th. I won't have tires by then, but I hope to have the front bar in. How do the tires look? Are the sidewalls bulging? Got good clearance all around? Maybe if it's not too much hassle for you, could you repost here after your Aug. 13th run and give us a report?? Last edited by speednby; 08-04-2005 at 02:40 PM. Reason: Punctuation |
08-04-2005, 02:53 PM | #9 | |
Member#: 53548
SCIC
Hopefully I'll be able to notice the difference in tire grip. The front sway bar will probably mess up the comparison of turn-in response and handling in sweepers, since I already noticed a big difference with just the bar on RE92's in normal driving. |
08-04-2005, 03:05 PM | #10 | |
Member#: 31636
Vehicle:2005 STi & '82 911 CGM & rosewood |
08-04-2005, 03:25 PM | #11 | |
Member#: 53548
SCIC
PM "Student Driver" for an opinion. I just saw in a search that he has the same tires on stock wheels and has already autocrossed with them.
08-04-2005, 04:49 PM | #12 |
....the Z212 is available in a 215/45-16 AND a 225/45-16 as well......either of those would be a bit better than the 225/50 as far as the sidewall is concerned......the diameter difference isn't too bad.
http://www.miata.net/garage/tirecalcold.html |
08-04-2005, 07:14 PM | #13 | ||
Member#: 86316
BTW, very cool tire calculator web site. That sure beats the shiznit out of beatin' on my desk top calculator! |
08-04-2005, 09:41 PM | #14 | |
Member#: 68346
Vehicle:2004 Tacoma 2015 GX460 |
08-04-2005, 09:46 PM | #15 | |
Member#: 86316
DOH! Sorry... to many years lost in dirt oval land.... I think that makes me sort of a "Super Noob"! |
08-04-2005, 11:34 PM | #16 |
Member#: 64802
Well, I went ahead and ordered the "Kooks" (I think that's what we should call them). You can't beat <$90 per tire installed.
I got the P205/55 because I was scared to go with the 225s on my 6.5" rims. I hear the sidewall isn't that stiff on these so they would probably flex a lot on the stock wheels. Even in the OEM size the tread width is still over 1/2" wider than the stock RE92. The 225 tread width is about 1.5" wider than the RE92. I couldn't imagine another 1.5" width when looking at how the RE92s sit on these wheels performing very well. |
08-05-2005, 01:26 AM | #17 |
Member#: 53548
SCIC
I took some pictures of the tires on my wheels earlier this evening.
Last edited by PossumK; 08-05-2005 at 01:31 AM. Reason: moved pictures to different URL |
08-05-2005, 08:37 AM | #18 | |
Member#: 86316
08-05-2005, 09:01 AM | #19 |
Member#: 43111
South East
Vehicle:2016 Lapis Blue STi Now with more NEW |
I have run the 225/45/16's for 2 auto-x's now. Before I had Azenis Sports in 215/45/16. The new Hankook's run circles around the Azenis Sports hands down. With the girth of the WRX on a narrow tire, the Azenis got very greasy when they got a little warmth in them. Hankooks on the other hand love the heat. The hotter I get them, the better they are.
The Hankooks are wearing fairly well considering at the last 2 Auto-x's here in Birmingham we got 8 runs each. I see tread at 60-70% For the money, Hankook is the way to go. |
08-05-2005, 11:09 AM | #20 |
Member#: 37575
Vehicle:2012 WRX Std 4D Blue |
I just picked up a set of Hankooks and my initial opinion is that they are squishy and vague. Is upping the pressure going to fix that?
08-05-2005, 12:10 PM | #21 | |
I have my 235/40-17's at 42F/39R and may go up another psi or 2.....they get better as they wear in a bit.....the first couple hunderd miles is usually like that, anyway, 'cuz the mold release agent is wearing off the tires. |
08-05-2005, 05:26 PM | #22 |
Member#: 35421
Vehicle:2003 WRX W R Blue |
So how are they in the rain?
08-05-2005, 05:27 PM | #23 |
Member#: 18928
South East
Vehicle:2002 jdm wrx v7/v8 inter/w Spec C roof vent |
Nice..I need to get a new summer tire..It's a 200 treadwear..jeez/
08-05-2005, 06:08 PM | #24 |
Member#: 64802
Crap! I'm at the tire shop.
They mounted the new tires and I went out to look at them. They put the HR2 on there instead of the RS2 like I asked for. They've never heard of the RS2/Z212 and neither has their distributor. They're putting my 3 RE92s back on there and my doughnut spare. I should have just ordered them from DiscountTire since the shipping is free anyway. Now I won't have tires until next week at the earliest. |
08-05-2005, 06:44 PM | #25 |
Member#: 64802
OK, it just got worse!
They scratched the crap out of every wheel accept the one that was already scratched! Not little, incidental, scratches that occur when working on a wheel but large 1/8" wide x 1-2" long scratches through the paint to bare metal. I said something about it but they said the manager was gone for the day and I'd need to come back tommorow. Hopefully they'll be paying for either refinishing or replacement wheels after I talk to the manager. |
Similar Threads | ||||
Initial Impressions: Rota Tarmac II's with Hankook Ventus R-S2 Z212 | Paradenu | Car Part Reviews | 0 | 05-11-2006 07:58 PM |
Hankook Ventus R-S2 Z212 vs. Good Year Eagle F1 GS D3 | Pete Holt | Tire & Wheel | 13 | 03-12-2006 09:20 AM |
HANKOOK VENTUS R-S2 Z212 VS AZenis RT-215 | SeattleWRX | Tire & Wheel | 3 | 07-13-2005 08:43 AM |
should i get Hankook Ventus R-S2 or Falken Azeins sport RT215 | Dark | Tire & Wheel | 4 | 06-11-2005 11:29 AM |
Falken GRB FK451 or Hankook Ventus R-S2? | ommmjido | Tire & Wheel | 10 | 04-12-2005 08:25 PM |
