Welcome to the North American Subaru Impreza Owners Club Tuesday July 17, 2018
North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC
Old 04-08-2018, 08:13 PM   #8326
SubDubRX
Member#: 155194
2016 WRX Limited
CWP
Swapped to brembos on the wrx
SubDubRX is offline   Reply With Quote
Old 04-15-2018, 02:43 PM   #8327
Breezio
Member#: 234357
2009 WRX
Sportwagen zum einbauen!
Pulled the rear cover off the transmission to hopefully find bad bearings on the center diff and replace them.
Found this instead...
Chunks of teeth from the two gears collected in the spot on the left.
The output shaft and gear.
Old diff on left, seems the keeper got torn out at some point and passed around in there, found a piece lodged in the oil channel for the output shaft. The main bearings for the center diff actually appear to be just fine.
Breezio is offline   Reply With Quote
Old 04-16-2018, 12:23 PM   #8328
robschilke
Member#: 397553
2014 GR8 DGM
Subaru Ambassador
Damn. So what's the remedy for that? Do you have to replace the entire trans?
robschilke is offline   Reply With Quote
Old 04-18-2018, 04:16 AM   #8329
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
Started cursing at it due to the increasingly loud noise coming from the trans. It's input shaft related. Guess it's getting close to time to tear it apart and see what needs to be replaced. I know it needs a new syncro for 3rd, but that's not my noise.
CosmoTheCat is offline   Reply With Quote
Old 04-18-2018, 02:10 PM   #8330
joepark89
Member#: 437614
Debating on what to do (if anything) with a new '18 WRX Limited
joepark89 is offline   Reply With Quote
Old 04-22-2018, 07:20 PM   #8331
jnorwooddds2004
Member#: 472308
2015 WRX
Red
Got car out of Tranny shop after new clutch kit, starter and transmission. Really messed things up!!!! Dragging my car trying to break that ever-elusive under 12 second 1/4 mile. Oh well. Iíll go easy on the take offs for a while.
jnorwooddds2004 is offline   Reply With Quote
Old 04-24-2018, 03:41 PM   #8332
subiechix10
Member#: 482895
2004 WRX
SAN REMO
I have new halo headlights coming in and new leds to go with, new cobb ap should be here tomorrow and going to be putting new raceland coilovers on my 04 wrx shagin wagon!
subiechix10 is offline   Reply With Quote
Old 04-25-2018, 10:23 AM   #8333
DrnknZag
Member#: 138473
2017 Focus RS
Stealth Gray
Guess this is goodbye for now....
DrnknZag is offline   Reply With Quote
Old 05-09-2018, 02:41 PM   #8334
SubDubRX
Member#: 155194
2016 WRX Limited
CWP
Bought some new wheels, be here friday
Old 05-09-2018, 10:11 PM   #8335
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
Hit up the junkyard for some forester struts to toss on my 91 legacy, fronts bolted in like butter and just need to swap the top hats on the rear tomorrow at work. Looking forward to seeing what size a tire I can stuff under there.
Scuby04STi is offline   Reply With Quote
Old 05-11-2018, 04:52 PM   #8336
BugeyeConnor
Member#: 470436
Finally getting around to pulling out the crushed rocker panel from the previous owner so my skirts can sit flush.
BugeyeConnor is offline   Reply With Quote
Old 05-18-2018, 08:29 PM   #8337
killadawg
Member#: 424203
2016 WRX stage 3
STI Drivetrain swap GM
I put summer tires on so I can drive my car from east coast to west coast and say good riddance to NE snow!! Hello Seattle rain I suppose.. lol
killadawg is offline   Reply With Quote
Old 05-19-2018, 08:21 AM   #8338
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
Project done. Everything fit perfectly after swappimg the rear tophats, then the hard part was getting a straight answer on tires. Ended up with a very aggressive tread on a 27/8.5r 14 that also actually somehow clears everything. Car has only rubbed once and it was at nearly full lock with the shock fully depressed.
Old 05-19-2018, 07:04 PM   #8339
ryguysti11
Member#: 389950
2011 WRX STi
Ordered some KSTech 19mm intake manifold spacers (not TGV spacers) to reverse my IM.
Installed the Killer B windage tray, flywheel, pilot bearing, clutch, and pressure plate to my motor.
ryguysti11 is offline   Reply With Quote
Old 05-19-2018, 07:08 PM   #8340
ryguysti11
Member#: 389950
2011 WRX STi
About to drop the motor in now and drop off my front bumper for the license plate bump to be shaved as well as have a lip and some canards installed.
Follow me on IG @ryguysti
Old 05-21-2018, 01:00 PM   #8341
bobbyvu
Member#: 237351
2004 SRR WRX Wagon
Lifted Stage 2+ EJ25
As of today, next 10 days of no rain and mid 70's in Seattle.
bobbyvu is offline   Reply With Quote
Old 05-26-2018, 09:32 PM   #8342
Razkoritz
Member#: 395454
2009 WRX Hatch
Test fit something I've been working on for a bit..
Razkoritz is offline   Reply With Quote
Old 05-28-2018, 01:36 AM   #8343
CosmoTheCat
Member#: 3409
98 My FMIC
I washed it last week. Actually, I washed both the 93 and the 96. And pressure washed my dadge, but didn't hit it with a soapy sponge. I think it's been over a year since any of them got washed.
Old 05-28-2018, 09:39 AM   #8344
Breezio
Member#: 234357
2009 WRX
No, as far as I could tell, the design of the center diff housing keeps any particulate separate from the main transmission parts.
So I replaced all parts in the center diff area. Just got it back together.
Tail housing with new output shaft bearing race, output shaft seal, center diff rear output shaft and bearing. All cleaned up
New output shaft and bearings, used old shims.
Transmission side with new bearing race for output shaft and new center diff installed.
You can do this job without removing the transmission, which made it something a normal person like myself can do in your garage pretty easy. Cost me about $1050 in parts from Subaru. All back together and she feels good and no bad noises anymore.
Old 05-29-2018, 09:48 AM   #8345
bobbyvu
Member#: 237351
2004 SRR WRX Wagon
Took her in to All Wheel Drive Auto in Kirkland, got a 60K service done. Everything is smooth like butter and better mpg's.
Old 06-01-2018, 12:07 PM   #8346
killadawg
Member#: 424203
2016 WRX stage 3
Added a box for my travels.. gonna roll with RE-71R's https://wheelwell.com/killadawg-09-1...016-subaru-wrx
Old 06-04-2018, 08:02 PM   #8347
johnxx
Member#: 215252
1996 Outback Sport
Red/Silver
Rolled the dice and put in a 1999-2003 Legacy GT driver seat. I think it sits a bit lower than stock which is just fine by me. And It's comfy!
johnxx is offline   Reply With Quote
Old 07-02-2018, 12:50 PM   #8348
killadawg
Member#: 424203
2016 WRX stage 3
Drove 4.3k miles Boston to Bellingham via Yellowstone and MI UP. Car held up like a champ on the steep hills and I only got followed by the Law for 1 hr. in Wyoming :-)..
Old 07-04-2018, 01:39 PM   #8349
SubDubRX
Member#: 155194
2016 WRX Limited
CWP
Default 2.5rs
Finally got myself a 2.5rs coupe. Trying to catch up on maintainence and fixing the little things. More to come 😬
Old 07-11-2018, 04:53 AM   #8350
Charlie_Bravo
Member#: 488183
TOB went bad..... sooo... upgrade time
Exedy Stage 1 Organic Clutch with ACT Streetlite Flywheel and a Carbon Fiber driveshaft.
Snout of the transmission was all chewed up so it got re sleeved with a Tranquil TSK-3 which is ultimately just a steel sleeve so that the bearing sits on steel not aluminum.
Clutch feels great but too early to give full review till I have everything broken in.
Charlie_Bravo is offline   Reply With Quote
What did you do to your Subie Today? Version 3 TrickNipple North West Impreza Club Forum -- NWIC 3796 09-07-2011 02:52 AM
What did you do to your Subie Today? Version 2 Smoke North West Impreza Club Forum -- NWIC 1978 05-21-2010 12:43 AM
What did you do to your Suby today? BREWPUBEAVER North West Impreza Club Forum -- NWIC 1197 11-01-2009 12:06 PM
What did you do to your subie today?! 07imprezadrifter General Community 277 06-14-2009 11:42 PM
