Welcome to the North American Subaru Impreza Owners Club Saturday February 22, 2020
Old 12-13-2018, 08:56 PM   #8801
Sexy_Rexy_09
Member#: 484254
https://imgur.com/a/ewVUEmA
do these numbers look normal to you guys?
stock vf52 turbo, cobb dp, 1000cc, aem 320lp, grimspeed ebcs, e70
Sexy_Rexy_09 is offline   Reply With Quote
Old 12-13-2018, 09:00 PM   #8802
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
Can't see numbers but with that setup I'd expect you to top out around 300hp/325 torque at 24psi and 85% duty cycle
no694terry is offline   Reply With Quote
Old 12-14-2018, 03:52 PM   #8803
carsebuco
Member#: 482289
2018 STI
It says 305/374.
Man, I wish I could drop some money on this thing and go E85..
carsebuco is offline   Reply With Quote
Old 12-15-2018, 09:32 AM   #8804
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
Gotta love the dart throw. Lol
Scuby04STi is offline   Reply With Quote
Old 12-15-2018, 12:49 PM   #8805
Tmack2425
Member#: 493909
Hey guys im running my 2017 WRX stock block/turbo. With frontmount. E65 and much more. Making 380WHP/370TQ But running e65 there isnt alot of lubricant for the High pressure fuel pump. I know there arnt any upgraded FA20DIT HPFP out yet. But is there anything else you guys put in the tank to help with this?
Tmack2425 is offline   Reply With Quote
Old 12-15-2018, 10:41 PM   #8806
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
Put some 2-stroke oil in the tank? I do that occasionally to make sure everything is lubed.
yamahaSHO is offline   Reply With Quote
Old 12-24-2018, 02:02 PM   #8807
birdflu
Member#: 272186
03 wrx csevo6
vf34 e85 salted peanut
Anyone have base fuel pressure drop with e90?
8 year old (15000km) walbro 255, that’s been running E for 5 years (12000km) with id1000’s. My filter is a fuelab 818 6 micron micro-fibreglass element and I have a turbosmart mechanical gauge after the filter on the supply to stock fuel rails with a stock FPR.
When I start the engine the fuel pressure is at 33 psi and with FPR disconnected 43 psi. It stays like this until well after it’s warmed up(engine oil at operating temps), but at around 15 to 20 mins after completely warmed up my base fuel pressure drops from 33 to 28 psi and 43 to 38 psi with the FPR disconnected. No change in idle AFR or trims. My fuel pump duty cycle is set at 74.90% to 14.41 psia.
Can the degradation of e85 cause this type of base fuel pressure drop?
It’s not a daily and sits for months sometimes and I’ve only just fitted the filter, gauge and started a Carberry rom tune. Had been running the stock fuel filter and changing it every year.
Do you guys use e85 treatments?........such as lucas, vp or nulon
All thoughts welcome.
Merry Xmas
birdflu is offline   Reply With Quote
Old 12-26-2018, 10:49 AM   #8808
Foo_Blyat
Member#: 93750
Im trying to sort something out with e85 and spark plugs.
while doing research on here the info i came across was with e85 you should do one step colder plugs. with a modified motor making more power over stock plus e85, its two step colder plugs.
but, i came across instances where people running one step colder plugs on e85 in cold climates like the midwest had trouble starting their cars during the winter until they went back to oem plugs.
the reason i ask is because im running a jdm ej205 with avcs that uses NGK PFR6G as oem plugs. im not sure if i should replace with the same plugs, go one step colder and which plugs would be the one step colder for the jdm ej205 w/ avcs, or go two steps colder since the engine received an upgraded brand new 16gxt, sti tmic, aps inlet, zerosports elbow, id1050x , iag rails, upgraded lines and FPR, full tbe, uppipe, etc. this motor is going into a DD which will see chicago winters.
Foo_Blyat is offline   Reply With Quote
Old 12-26-2018, 12:44 PM   #8809
birdflu
Member#: 272186
03 wrx csevo6
I run bkr6e with a vf34 set up with over 300 whp.
When I was running pump 98 before switching to e90 I was running bkr7e.
Old 12-26-2018, 12:49 PM   #8810
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
I run 1 step colder on my EFR 6758 @ 26 PSI. I originally put them in while on gas and a TD05 20G. That said, I wouldn't have an issue running a stock plug on this setup (E85).
As far as cold starting for referenced cars, I'd need to know way more info on said car and tune.
Old 12-26-2018, 12:58 PM   #8811
NighthawkSTI
Member#: 495630
one step colder is a good idea at this level as others have noted, the cooling effect of E85 may (relative to a built motor on pump gas only), somewhat negate the need for a colder plug though at least from the perspective of preignition from a relatively hotter OEM plug. On the other hand lots of renouned builders use the OEM plugs.
NighthawkSTI is offline   Reply With Quote
Old 12-26-2018, 01:06 PM   #8812
anarekist
Member#: 468117
2017 WRX
DMG
anyone using a inline fuel filter after going e85?
anarekist is offline   Reply With Quote
Old 12-26-2018, 01:15 PM   #8813
birdflu
Member#: 272186
03 wrx csevo6
Just fitted a fuelab 818 6 micron micro-fibreglass inline.
Don't know if they are any good as I'm yet to test drive.
Any thoughts on these filters and my fuel pressure drop I mentioned a few posts back would be much appreciated.
Old 12-26-2018, 03:36 PM   #8814
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
I use the same filter and seems to do what it is designed to do.
As for your pressure drop, what pump and injectors are you running?
Old 12-26-2018, 06:09 PM   #8815
Foo_Blyat
Member#: 93750
Stock plugs it is.
Hopefully I won't have that issue so won't even need to address it
Old 12-26-2018, 07:21 PM   #8816
NighthawkSTI
Member#: 495630
hard cold starts in cold climates with E85 or higher is completely normal. Its just a characteristic of high Ethenol %. ITs still a quirk WELL worth putting up with for the power gained with E85.
Old 12-26-2018, 08:52 PM   #8817
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
They don't have to be hard...
Old 12-27-2018, 05:22 AM   #8818
birdflu
Member#: 272186
03 wrx csevo6
yamahaSHO your car sounds sik! Great to hear you have the same filter and it works.
I'm running a Walbro 255 and id1000 injectors.
Old 12-27-2018, 09:17 AM   #8819
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
here's mine a couple years ago using a emanage ultimate to run flex fuel on a stock 98 forester ecu. 6:30am, 9 degrees fahrenheit, E68
using carberry 4.2 now in exo on a 02 wrx ecu. But ive been on 93 octane tuning gas tables for winter
Old 12-27-2018, 09:21 AM   #8820
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
inline trickflow
Old 12-27-2018, 02:44 PM   #8821
09WRXYNZ
Member#: 493375
2009 Wrx
Gray
2009 WRX
78% IDC
60psi fuel
ID1300's
Hardwired AEM320
Radium Fuel Rails
Aeromotive FPR
410/[email protected] (mustang dyno)
20GXT
09WRXYNZ is offline   Reply With Quote
Old 12-27-2018, 06:48 PM   #8822
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
It's not my car, just a customer car that I tuned. I have never really tested really cold starts on my car as I don't drive it in the extreme cold. My car also does not sound like a Subaru, so the video doesn't sound "good" to me other than it firing right up.
Is your pump hardwired? If you're getting a pressure drop like that, I'd probably start with the factory FPR. I've seen quite a few fail over the years... Two in the last couple months with customer cars, and I do this as a side gig. They also made things like hot starts seem more like a -20 cold start with constant cranking.
https://youtu.be/NqmI0o0Cf64
Not too bad, especially for a piggyback.
Old 12-27-2018, 07:47 PM   #8823
anarekist
Member#: 468117
2017 WRX
DMG
do you have any pictures?
Old 12-28-2018, 01:56 AM   #8824
birdflu
Member#: 272186
03 wrx csevo6
anarekist
Yes I do have pictures but don't have a image hosting account.
I will register with imgur and post pics
Old 12-28-2018, 02:08 AM   #8825
birdflu
Member#: 272186
03 wrx csevo6
No my pump isn't hardwired. Hot starts are instant.
Only noticed this since flashing carberry rom as I fitted the filter and under bonnet gauge at the same time.
Did you replace the stock FPR's that failed with standard or go aftermarket?
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY Motion Lab Tuning Proven Power Bragging 125 04-12-2010 03:57 AM
jid2 Track Car - e85 ARMY jid2 Member's Car Gallery 38 01-22-2010 11:44 PM
The Honduran army is the bravest in the world... wrxcelent Off-Topic 36 07-07-2009 09:21 AM
Spacific E85 Tuning thread Here ? discopotato03 Engine Management & Tuning 1 09-09-2008 12:01 PM
Did anyone hear the one about the Italian army and the IRAQI satiation? Asinine Off-Topic 3 09-20-2005 08:06 PM
