10-11-2008, 05:44 PM | #1 |
Member#: 32459
Vehicle:02 WRX VF34 (SOLD) Junior Tuned 301whp |
Easy DIY compression test with pics!
Spent 45 min performing compression test with $25 compression tester today.
2002 WRX with 90k miles Mods: VF34 @ 19psi protuned 282whp/272wtq JDM STI TMIC Maddad v2 DP & whisper catback One step colder NGK platinum plugs Stock intake with K&N panel filter German castrol oil 1. Remove stock intake box, etc: 2. Remove 12mm bolt in order to remove coil pack from each cylinder: 3. Remove spark plugs using 5/8" long socket with an extension 4. Coil pack and spark plugs removed:
10-11-2008, 05:44 PM | #2 |
Member#: 32459
5. Pull ignition fuse
- Fuse remover is located next to battery: 6. Connect compression tester into each cylinder: 7. Now it's time to crank the engine with wide open throttle. Crank the engine 6 times. 8. Repeat the test for each cylinder and pray numbers come out good: |
10-11-2008, 05:57 PM | #3 |
Member#: 167739
Vehicle:15 Forester NA dat gas mileage |
thanks!! will try soon
10-11-2008, 06:02 PM | #4 |
Member#: 32459
You're welcome. Make sure to pray before performing a test!
One thing I forgot to mention is: Make sure your car is warm when performing a test. |
10-11-2008, 06:41 PM | #5 |
Member#: 5810
Vehicle:2001 S366 2.5RS |
you forgot a huge part.
throttle to the floor |
10-11-2008, 06:43 PM | #6 |
Member#: 32459
I mentioned above, ".... with wide open throttle..."
10-11-2008, 06:47 PM | #7 |
Member#: 174442
Vehicle:2007 SuperWagon I don't spell well |
why do you crank with the throttle down? What difference does it make?
10-11-2008, 06:52 PM | #8 |
Member#: 190786
Vehicle:2002 WRX Sedona Red |
Im guessing so all the air can get in.
10-12-2008, 01:32 AM | #9 |
Member#: 187983
South East
Vehicle:2005 WRX WRB |
Wouldn't you need to remove the fuel pump relay also?
10-12-2008, 01:43 AM | #10 |
Member#: 111845
AKIC
Vehicle:97 RUBAsU Tall2dr 04 FXT VF22/COBB AP |
2 man job, or does the gauge peak hold?
10-12-2008, 02:45 AM | #11 |
Member#: 86659
Vehicle:2005 WRX Sedan WR Blue |
10-12-2008, 09:18 AM | #12 |
Member#: 85019
South East
Vehicle:MY02 & MY04 Turbo'd Money Pits |
I would disconnect the fuel pump relay too. Something about raw fuel washing the cylinder walls and fuel dilution in the oil just sounds like bad ju ju to me....Great write up though! Now someone needs to make one for a leakdown test! Hint hint...
10-12-2008, 09:24 AM | #13 |
Member#: 27075
Vehicle:09 WRX, 03 WRX, 98 OBS |
10-12-2008, 06:57 PM | #14 |
Member#: 158708
Vehicle:You would if you had robot ears |
Nice write up, can't wait to try it out for myself.
10-12-2008, 07:12 PM | #15 |
Member#: 188464
Vehicle:02 wrx wrb, silver, black,primer |
good write up with good pics, may have to give this one a shot this week
10-12-2008, 11:09 PM | #16 |
Member#: 50064
Vehicle:'12 WRX (WRX#8, Subi#12) |
Where'd you pick up the compression tester?
10-12-2008, 11:57 PM | #17 |
Member#: 32459
I picked one up from advance auto part.
10-12-2008, 11:58 PM | #18 |
Member#: 50064
Thanks. I just did my plugs but I'll do this test when I replace them next year (copper plugs).
10-13-2008, 05:20 AM | #19 |
Member#: 34924
SCIC
Vehicle:03 WRX Wagon 81 Scirocco S |
The injectors need a ignition signal to fire so disconnecting the fuel pump relay is not really necessary.
10-13-2008, 08:45 AM | #20 |
Member#: 36361
Vehicle:1980 Yugo Definitely not a Golf R |
Thank you for this write-up! I need to do one of these soon.
10-13-2008, 12:38 PM | #21 |
Member#: 170439
Vehicle:I <3 Lamp |
going wot at startup cuts fuel to the all cylinders, this is normal on al obd2 cars
10-13-2008, 01:17 PM | #22 | |
Member#: 16197
South East
Vehicle:07 GX470 PearWhite 09 VMAX, 02 BMW R1150r |
So going WOT is not necessary either, correct? |
10-13-2008, 03:11 PM | #23 |
Member#: 168354
good write up! thank you
10-13-2008, 04:52 PM | #24 |
Member#: 129428
Vehicle:2002 Wrx |
Want to do one for me? Ill pay you = )
10-13-2008, 05:10 PM | #25 |
Member#: 32459
as long as you buy me lunch, sure why not?
Similar Threads | ||||
Compression test instructions with pics. | Impr3zy0u | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 123 | 03-27-2013 06:04 PM |
new to boxers. help with compression test | wildacex187 | Newbies & FAQs | 19 | 02-27-2007 11:03 PM |
What is the standard compression test values on a 2.5ltr with forged pistons | tino | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 15 | 11-25-2005 02:16 AM |
can compression test be done with accessport and antitheft mode? | anthonyrb98 | Engine Management & Tuning | 12 | 09-25-2005 04:05 PM |
DIY Compression Test | thoughto | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 01-31-2004 05:31 PM |
