06-25-2006, 09:57 PM | #1 |
Member#: 110520
NWIC
Vehicle:2004 Titan Smoke |
Cel with utec hooked up
so i got my utec installed and got the firmware updated to 5.0 and got the stage 1 map uploaded and got it all put back together changed to map one one on the map selector and my CEL came right on and will not turn off have not tried the ecu reset by d/cing the neg terminal yet. any thoughts or ideas? i am running the base stage one all i gots is the utec (TBE is on the way though yay)
found the setting to turn the cel off....
06-26-2006, 05:35 AM | #2 |
Member#: 38772
Vehicle:2 Cars, No Bling |
What was the CEL for? I'm sure you got the code pulled, right?
You can always turn the CEL off, but most people don't do this since it can actually tell you some useful information. |
06-26-2006, 03:41 PM | #3 |
Member#: 97642
SWIC
Vehicle:2002 Wrx Sedan MBP |
I would suggest pulling that code to see what is up. Just turning the light off with the utec does not fix what is actually throwing the code.
You can go to Autozone and use a obd2 scanner for free. |
06-26-2006, 10:13 PM | #4 |
Member#: 110520
NWIC
ok
thanks i might have to go do that, i thought at first that iwas just from hooking the utec up and running with it on. car runs great with it
06-27-2006, 12:14 AM | #5 |
Citizen Mick
Member#: 27646
NWIC
Vehicle:2003 Sleeved 2.5 Oil Dry Sump Goodness |
Bets on the MAF low code......
06-27-2006, 02:31 AM | #6 |
Member#: 94097
Vehicle:2004 WRX Hybrid GT35 [email protected] |
what ver. of the UTEC you installed?
06-28-2006, 03:08 PM | #7 | |
Member#: 110520
NWIC
vers
06-28-2006, 03:20 PM | #8 |
Member#: 7194
Vehicle:2011 997.2 Turbo Black |
You did upload the current parameters for the 5.0 firmware right?
maybe your old parameters had the CEL turned off which was masking a problem youve been having this entire time. |
07-01-2006, 07:37 PM | #9 | |
Member#: 110520
NWIC
07-02-2006, 10:20 AM | #10 |
Member#: 83865
Vehicle:2005 Saab 9-2X Aero Midnight Blue |
You cant 'fix' it, its a problem with the firmware.
07-03-2006, 11:41 PM | #11 |
Member#: 110520
NWIC
lets hope this issue gets fixed in the new version of sofware that is hopefully coming out soon, is this issue related only to version 6b my buddy has a previous version and does not have this issue?
Anyone with Disneyland hook up? | GHOS Ti | Southern California Impreza Club Forum -- SCIC | 21 | 01-06-2009 04:57 AM |
Need HELP quick with gauge hook up at the BPV end | shamrock 05 | Interior & Exterior Modification | 1 | 06-11-2008 07:56 PM |
UTEC hooking up to lap top? | axion7606 | Newbies & FAQs | 2 | 10-15-2003 07:26 PM |
Car stalls with MAF hooked up. Idles at 1500 with out | scottm1978 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 09-22-2003 08:41 AM |
flashing cel with utec, what could be causing it? | datdudedennis | Engine Management & Tuning | 7 | 04-07-2003 05:16 PM |
