08-07-2004, 09:18 PM | #1 |
Member#: 21085
W. Canada
Vehicle:2.5 rs-t |
need copper headgasket for ej25
im currently running the phase 1 gasket cause its thicker but i just blew it. ive seen copper headgaskets around but they are all for the 2L. can anyone dirrect me to a place where i can find one.
ya i know this should be in the wanted forums but i just though the only people that would know would be the aftermarket guys. thanx, jay
08-07-2004, 09:48 PM | #2 |
Member#: 4133
Vehicle:'01 2.5RS Sedan '05 LGT Wagon |
Jay,
Cometic headgaskets seem pretty popular for AFI. Have you considered one of those? I know it's thinner (0.043" IIRC) than the 2.5 DOHC, but not as thin as the SOHC. klug |
08-08-2004, 03:42 PM | #3 |
Member#: 21085
W. Canada
Vehicle:2.5 rs-t |
hmm, ive never heard of a cometic head gasket before. i did some searches and it seams like this is deffinetly the way for me to go. axis power racing sells these so now i just need to cross my fingers that theyll have them in stock and to fit my application. are there any other places that i might try? also, i know that most heads are universal but how much do the gaskets differ? becides bore size are they pretty much the same, id imagine the closed deck and semi close deck blocks would require a different head gasket but do i need to specify my my00 ej25?
thanx for the advice klug. jay |
08-09-2004, 11:39 AM | #4 |
Member#: 21085
W. Canada
Vehicle:2.5 rs-t |
just got off the phone with the guys at cometic and was told that where my block is already o-ringed there gaskets wont work. id have to pull the o-ring out and have my block milled smooth and they dont make anything without a built in o-ring... so my search continues, any help locating a copper head gasket would be much appreciated.
jay |
08-10-2004, 01:35 AM | #5 |
Member#: 21085
W. Canada
Vehicle:2.5 rs-t |
ive done many searches and have read that a few places can make me a gasket and the only place that i found to actually have a part number for them is in australia. any know of a closer place that i can just call and order it and not have to wait for them to make me a set?
08-10-2004, 12:37 PM | #6 |
Member#: 47261
W. Canada
so that's what happened?
try http://www.xcceleration.com/contact.htm they use copper head gaskets in their ej25 builds. I'm not sure if they use the o-ring or if the shave it down but it's worth a shot. |
08-10-2004, 02:02 PM | #7 |
Member#: 1847
Vehicle:Team Broken: V6 GF rallyarmor.com |
you might call or email rallispec, all the help that I can give is, they built the motor in my car. 2.2T shortblock with phase 1 DOHC heads, the receipts say 'custom copper head gaskets'' @ 242.00 Each. The heads where milled when installed.
All the info I can offer.... Jay |
08-10-2004, 03:43 PM | #8 |
Member#: 447
Vehicle:1999 RSTI WRB |
why do you want copper?
08-10-2004, 07:39 PM | #9 |
Member#: 21085
W. Canada
Vehicle:2.5 rs-t |
at first i wanted copper cause thats what some of the big engine builders are going with, then after being told about the cometic i did some research and found that they were the way to go, but then i found out that cometic doesnt make any gaskets without a built in o-ring so i was back to copper. today i called axis power racing and found out that they make custom cometic gaskets(some with and some without o-rings) and they have them in stock. so now what im going to do is get the cometic gasket and if my blocks o-ring is small enough ill pull it out and get the gasket with it built in but if its too big(which i think it is) he wants me to pull it out and replace it with stainless steel(copper 0-ring now) and get the gasket without. fun never ends
08-11-2004, 01:59 AM | #10 |
Member#: 447
heh... you see my threads about never ending cycle of death..
i''ve been told that copper should only be used when you expect to do tear downs all the time... ie don't last that long... but i have no experience with them... how much boost are you running to start blowing gaskets... do you think i'm close to blowing one? |
08-11-2004, 07:51 AM | #11 | |
Street Racing Instructor
Moderator Member#: 110
Vehicle:1989 1989 XT6 |
Give Paeco Industries a call. http://www.paeco.com I had purchased some copper gaskets from them for my 2.2ltr engine. I forgot the cost though but I remember them seeming to be cheap. Unfortunately they never got installed because the shop I dropped them off at shutdown and the guys split-up and disappeared. Good luck! |
08-14-2004, 06:19 PM | #12 | |
Member#: 21085
W. Canada
Vehicle:2.5 rs-t |
15psi from my t3t4b. as far as how close you are, i have no idea, i didnt even think i was close. |
NEED engine specs for EJ25 | Roadrace1999 | Subaru Conversions | 3 | 05-17-2006 10:55 AM |
NEED Plug wires for ej25 | mr2hutch | Private 'Wanted' Classifieds | 6 | 09-25-2005 08:32 PM |
copper headgasket for ej25T? | White 2.5rs | Normally Aspirated with bolt-on Forced Induction Powertrain | 3 | 10-08-2003 03:28 PM |
Thicker headgasket for NA EJ25 | widesuby | Normally Aspirated Powertrain | 6 | 08-06-2003 06:19 PM |
Who has Copper headgasket for 1.8 XT turbo?!? | FLUBYUx2 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 14 | 10-06-2001 01:14 PM |
