11-18-2001, 03:02 PM | #1 |
Member#: 12176
Vehicle:2002 Geo Metro Teal |
How do I remove sun visor stickers?
Like the subject says. Any advice on "nicely" removing the blaring warning stickers without damaging the visors?
11-18-2001, 03:17 PM | #2 |
Member#: 12189
Vehicle:2002 WRX sedan Silver |
hey good question
I was starting to pick at mine the other day
whats the deal? maybe we have to take the cars to a Tattoo removal place,,,,,,,,,,,,,,,,,,,, like one of those tags on a new Mattress . maybe the MOD squad will appear and drop down from the ceiling and stick us in a 70's sitcom never to return!!!!!!!!!!! |
11-18-2001, 03:31 PM | #3 |
Member#: 717
NESIC
Don't pick at them. Buy some "Goo Gone". It's nasty, toxic shiznit. Perfect for removing the warnings.
Be sure to do it in a small, unventilated room, for maximum effect! j/k Ed |
11-18-2001, 05:10 PM | #4 |
Member#: 3149
Vehicle:01 V7 GC/R32 sky |
Yeah, goo gone will work fine, but if you are working in a garage and the fumes start getting to you, just turn your car on and let it idle for a while to mask those nasty fumes!
Dan Coty |
11-18-2001, 05:15 PM | #5 |
Member#: 6573
Vehicle:03 WRX Silver on Gold |
you could always do wat my man did....easy-peasy mod..get some white vinyl, cut it out to match the visor, slap it on..and add a decal (sti in his case) and it loosk pretty cool...it helps that he has a aspen white rs to match the vinyl
11-18-2001, 05:20 PM | #6 |
Member#: 6971
NWIC
Vehicle:2008 WRX STi SSM |
make sure the garage door is closed too, who needs that "ventulashun" stuff anyway?
11-18-2001, 07:17 PM | #7 |
Member#: 8907
Vehicle:2002 Impreza WRX Sdn WR Blue Pearl |
If you don't like the fumes from thr Goo Gone in your car, you can pull the car into the driveway and remove the visors. Take the visors into the garage and dowse liberally with Goo Gone.
At this time, you may also want to fire up that old snow blower in case it snows. Put it on full choke and run it until all of the old gas is gone. Be sure to close the garage door while you are doing this so you don't disturb the neighbors! |
11-18-2001, 11:09 PM | #8 |
Member#: 11944
Vehicle:1994 Mazda MX-6 Hunter Green |
Here's an easy way,
take the visors off grab a pair of scissors/cutters cut around the sticker( make sure you cut all the way trough) Remove the piece put the visors back on Voila'! no more sticker I'm starting to become a post whore |
11-19-2001, 03:34 PM | #9 |
Member#: 4532
11-19-2001, 03:38 PM | #10 |
Member#: 717
NESIC
You definately want to remove the visors first....
Ed (still reeling from the lingering effects of Goo Gone, 3 mos. later).... |
11-19-2001, 04:36 PM | #11 |
Member#: 5596
TXIC
Vehicle:2010 Honda Fit Sport Black |
Goof off!
I used "Goof off", and that's the solvent that's recommended on this board all the time. Make sure you use the original, not "Goof off 2".
-Ray |
removing defi pod -- broken tabs, how do you remove | whiterabbit | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 02-23-2003 01:49 AM |
How do you remove visor warning stickers? | BlueFlash | South West Impreza Club Forum -- SWIC | 5 | 08-24-2002 03:29 PM |
How do I get a County sticker in VA | J Colman | Mid Atlantic Impreza Club -- MAIC | 10 | 06-13-2001 10:30 AM |
('93-'01) How do you remove cup holder? | Alex RS | Impreza Forum | 1 | 06-13-2001 07:53 AM |
('93-'01) How do you remove the corner lamps? | GooseMan | Impreza Forum | 2 | 05-03-2001 11:48 AM |
