Welcome to the North American Subaru Impreza Owners Club Thursday July 19, 2018
Closed Thread
Old 03-12-2014, 06:08 PM   #29951
sc00ter
Member#: 117767
2014 Audi S4
Stage 2 (418whp/398ft-lb)
Originally Posted by cmiller219 View Post
Yes these came on all factory base model sedan STis in 2011.
^ Yep. Here's mine...
I actually prefer these Enkeis over the BBS wheels on the DGM and OBP cars. I just wish they sat a little wider but that's what these babies are for...
http://perrinperformance.com/i-13324...05-14-sti.html
Perrin says to go with 15mm in the back and 20mm in the front to get ideal fitment like this:
sc00ter is offline
Old 03-12-2014, 06:36 PM   #29952
cmiller219
Member#: 187179
14 STi
Cocain
i think i went 20 or 25 all around. pretty sure it was 25
cmiller219 is offline
Old 03-12-2014, 06:44 PM   #29953
sc00ter
Member#: 117767
2014 Audi S4
No rubbing issues?
sc00ter is offline
Old 03-12-2014, 08:19 PM   #29954
cmiller219
Member#: 187179
14 STi
Cocain
went back to look i went 15mm all around. You can see how flush it was in the picture of my car with the stock wheels lowered. no issues
Old 03-12-2014, 08:26 PM   #29955
fiatlux
Member#: 340639
2013 WRX STi Sedan
WR Blue Pearl
Did you use extended bolts or the stockers?
fiatlux is offline
Old 03-12-2014, 08:30 PM   #29956
cmiller219
Member#: 187179
14 STi
Cocain
I used ichiba v2 spacers. They have their own built in studs google it
Old 03-12-2014, 09:28 PM   #29957
Mr. Lin
Member#: 344988
2013 WRX STi
ISM
25s all around is perfect. roll ur back fenders
Mr. Lin is offline
Old 03-12-2014, 09:55 PM   #29958
cmiller219
Member#: 187179
14 STi
Cocain
for a wrx you have to do a minimum of 25mm or your wheels will not fit back in. If your using spacers that have built in studs like the ichiba v2. If you doing extended studs your fine with whatever. Reason being the STi wheels have notches in the back and the wrx wheels do not. So the wrx needs to go 25mm so their stock studs clear the spacer. If you understand what I am saying
Old 03-12-2014, 10:42 PM   #29959
Gen2WRX
Member#: 367752
2014 STLie
Crystal Black Silica
Few pics I took on my iphone today:
Gen2WRX is offline
Old 03-12-2014, 10:55 PM   #29960
FL4TFTW
Member#: 256953
2014 Built DGM BRZ
2016 Fiesta ST WP Tricoat
Suspension setup?
FL4TFTW is online now
Old 03-12-2014, 11:01 PM   #29961
Gen2WRX
Member#: 367752
2014 STLie
Originally Posted by FL4TFTW View Post
Suspension setup?
Eibach Pro-kit springs. Not low enough for my liking so coils are coming in the very near future
Gen2WRX is offline
Old 03-13-2014, 12:31 AM   #29962
Relier1
Member#: 350437
2013 WRX w/20mm spacers with attached lugs all the way around. Wheels fit just fine over the stock lugs..
Relier1 is offline
Old 03-13-2014, 05:35 AM   #29963
cmiller219
Member#: 187179
14 STi
Cocain
I stand corrected it must be 20 mm min my bad. I was mistaken
Old 03-13-2014, 09:00 AM   #29964
guitarman19853
Member#: 290734
2012 WRB WRX Hatch
2015 Forester XT
Originally Posted by Celery GT-5 View Post
do you guys use fuelly?
jeep hypermiling ftw
so much terrible mpg
Yep.
guitarman19853 is offline
Old 03-13-2014, 09:19 AM   #29965
Januch09
Member#: 309459
2011 STi Sedan
Satin White Perl
You can see in the picture that the oem lugs and ichiba nuts are sticking out past the spacer. Therefore with a stock wrx wheel, the back of the wheel is most likely sitting on the lug and not the spacer, you just don't notice it. It's the same with the STi. You have to run a minimum of 25mm for it to sit flush against the spacer.
I'm pretty sure that's how it is, but if you could put your stock wheels on the car with the spacers attached and take a picture of the spacer, say from the middle of your wheel on the outside, you might see a very tiny space between your wheel and the spacer, which means you're not sitting flush against the spacer which is rather dangerous and could ruin your wheel and other internals.
What cmiller said was correct from what I'm aware.
Now on the flip side, I could be wrong. The notch in the back of the WRX wheel can be bigger then is stated or I thought. You may not have that gap and the wheel may clear the lug. I just don't think that's the case. Try to take that pic though so you can either find out: Im wrong, or you're driving your car pretty dangerously lol.
Januch09 is offline
Old 03-13-2014, 09:54 AM   #29966
ocdpvw
Member#: 282232
2012 TP Stage 3
Bagged SWP & Bagged DGM
On the back of most wheels there are cutouts for spacers/adapters such as this. I can tell you with a 20mm that the OEM WRX wheels sit flush on the spacer from experience. On my aftermarket wheels I had to make modifications because my pockets on the back of the wheel were not large enough.
ocdpvw is offline
Old 03-13-2014, 10:02 AM   #29967
Relier1
Member#: 350437
Sorry, I am absolutely positive that the wheels sit completely flush against the spacers. The stock wheels have suitable hollowed space between each lug mounting hole in the back side. Just wanted to add my 2 cents to the conversation about needing 25mm to clear. I am well versed in auto mechanics and auto body repair. Built my first V8 when I was in middle school. Maybe I'll take a better picture of fitment this weekend, gonna install front and rear sways w/end links (hopefully).
Relier1 is offline
Old 03-13-2014, 10:04 AM   #29968
besthaticouldo
Member#: 279660
You and ocdpvw are correct, a 20mm will be fine. You don't need a 25mm to fit flush. There's cut outs in both WRX and STI wheels.
besthaticouldo is offline
Old 03-13-2014, 10:12 AM   #29969
Januch09
Member#: 309459
2011 STi Sedan
Satin White Perl
Gotcha, like I said, I could be wrong, just putting another opinion out there. I know that the STi BBS wheels, a 20mm spacer will not work. You have to do a 25mm or extended studs or else the back of the wheel will hit.
I'll be running some 25mm spacers on my stock STI BBS's for winter setup.
Also, you guys need to remember that there are different OEM sets of wheels for certain years. So I'm basing my info off of the BBS wheels, not the Enkei's. Apparently they are different.
Januch09 is offline
Old 03-13-2014, 10:16 AM   #29970
besthaticouldo
Member#: 279660
I ran 20mm on my STI BBS and they worked just fine. Sat flush and everything.
Old 03-13-2014, 10:20 AM   #29971
Januch09
Member#: 309459
2011 STi Sedan
Satin White Perl
With extended studs or? Do you have any pics of what it looked like?
I tried fitting a 20mm spacer and the back of the wheel hit the oem lugs because they stuck out too far.
Januch09 is offline
Old 03-13-2014, 10:31 AM   #29972
cmiller219
Member#: 187179
14 STi
Cocain
I ran 15mm ichiba v2 spacers on my 2011 STi with the stock enkies and it was flush. That's the lowest you can go. But the enkies have a pretty decent cut out.
Old 03-13-2014, 10:38 AM   #29973
besthaticouldo
Member#: 279660
No, bolt on spacers. They didn't hit, everything was flush. I'm sure it was pretty close, it was a shallow cut out.
I don't have pics, haven't had those wheels in like 2 years.
Old 03-13-2014, 10:50 AM   #29974
Januch09
Member#: 309459
2011 STi Sedan
Satin White Perl
Yes, I have the BBS's.
You sure they were the BBS's and not the Enkeis?
I tested 20mm spacers and they hit.
Januch09 is offline
Old 03-13-2014, 11:00 AM   #29975
besthaticouldo
Member#: 279660
I'm 100% sure they were BBS.
Closed Thread
('11-'14) 2011-2012 wrx/sti picture thread (for real this time) guamanian_powered Impreza Forum 151 04-29-2014 08:35 AM
01-07 wrx and sti drivetrain? xj bmx Newbies & FAQs 13 01-26-2012 03:30 PM
('11-'14) 2011 wrx/sti picture thread (for real this time) guamanian_powered Impreza Forum 1 11-16-2011 11:51 PM
Anyone have the 06-07 Impreza WRX and STI master part number and picture list STEALTH-WRX Interior & Exterior Modification 0 08-22-2008 02:12 PM
The Official World One STI and SEMA picture thread.. WorldOne Member's Car Gallery 25 11-29-2003 05:21 PM
