Welcome to the North American Subaru Impreza Owners Club Tuesday December 18, 2018
Old 01-16-2004, 12:17 AM   #1
norcaliwrx
Member#: 46374
02 WRX
Default how much psi can the stock engine hold?
As the title says........what psi can the engine with stock internal's hold? ALso what are the weak links in the engine internals? i hear its the rods then i hear its the pistons etc. Just wondeirng if anyone knows for sure.
norcaliwrx is offline   Reply With Quote
Old 01-16-2004, 12:35 AM   #2
cronic
Member#: 9749
sorry man there is no set number to engine failure.. There are other factors that contribute to the death of your motor..
cronic is offline   Reply With Quote
Old 01-16-2004, 01:10 AM   #3
pjcoregon
Member#: 15384
eleventy billion psi.
pjcoregon is offline   Reply With Quote
Old 01-16-2004, 04:07 AM   #4
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
I have heard of 24psi on a WRX stock block
Bad tuning will destroy the pistons in short order. Rods and rod bearings seem to go on the very high, well tuned, hp cars if anything. Over time on the mid to high hp cars the cyl liners tend to oval.
mr2guru is offline   Reply With Quote
Old 01-16-2004, 06:58 AM   #5
TheMadScientist
Member#: 23717
2005 Big red
I have been running ~20psi every day for the past 5 months and put ~10000 miles on the car. I tuned it my self with no WBO2. There have been no problems. I just scared the crap out of my self and hit the fuel cut in the utec this morning because of the cold.
TMS
TheMadScientist is offline   Reply With Quote
Old 01-16-2004, 10:13 AM   #6
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
The pistons can have problems if your tune is bad. There really isn't a magic don't go above this boost level though.
mbiker97 is offline   Reply With Quote
Old 01-16-2004, 12:28 PM   #7
WRX Jim
Member#: 22321
depends on tune, turbo size and what not.
I can run 21psi on one map setting ... i havent done it for extended periods though.
I run around on about 17.5psi daily ...
WRX Jim is offline   Reply With Quote
Old 01-16-2004, 01:02 PM   #8
SupaSizeFries
Member#: 10088
2002 Wrx Sti back
from the Dead
I know of one person that BRIEFLY (as brief as brief can get) spiked to 30 psi. He was lucky enough to still have the engine in one piece.
SupaSizeFries is offline   Reply With Quote
Old 01-16-2004, 01:04 PM   #9
TheMadScientist
Member#: 23717
2005 Big red
On what turbo?
Old 01-16-2004, 01:09 PM   #10
pjcoregon
Member#: 15384
Sponaugle was running about 25 psi with his stock block while he built his frankenstein 2.5... the biggest factor to your boost is having adequate fuel and management of the fuel in place to support it.
Old 01-16-2004, 01:10 PM   #11
SupaSizeFries
Member#: 10088
2002 Wrx Sti back
from the Dead
Originally posted by TheMadScientist
On what turbo?
I forget, but I know he bought it from XS Engineering and it was pretty pricey. He blew the pipe clear OFF the throttle body in his FMIC set up. Stock internals too.
Old 01-16-2004, 02:03 PM   #12
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
I have run 2 bar of boost on stock EJ205 engines. Jeff Sponaugle ran ALOT of boost on one of his Stock bottom ends.
Clark
AZScoobie is offline   Reply With Quote
Old 01-16-2004, 04:35 PM   #13
subieworx
Member#: 47769
I ran 25 psi daily in my Talon on a big 57 trim TD04E, 13.5 in my WRX
subieworx is offline   Reply With Quote
How Much Hp Can The Stock 2.0 Hold?? jcbluescooby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 04-25-2009 04:15 PM
How much hp can the stock tranny hold??? w321shark Newbies & FAQs 11 08-18-2008 05:19 PM
How much power can the stock trans hold/ Are WRX trannys fragile? Reference thread! RebelINS Transmission (AT/MT) & Driveline 12 07-02-2003 10:10 PM
How Much Boost can the stock engine hold SERGEREYES Engine Management & Tuning 6 05-10-2003 03:11 PM
How much boost can a stock block hold? Szm426 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-12-2002 08:21 AM
