Welcome to the North American Subaru Impreza Owners Club Wednesday June 20, 2018
Old 08-29-2009, 12:29 PM   #1
GenoaWRX9
Member#: 212459
2012 sti wrb
rip: 95 and 02
Default how to: remove front fender
Someone decided to hit my car last night at a party and now i have a nice f'd up fender. If anyone could point me in the direction of how to remove the front fender on an 02 wrx i would much appreciate it. Did a quick search and didn't see anything
GenoaWRX9 is offline   Reply With Quote
Old 08-29-2009, 01:44 PM   #2
skimobile
Member#: 92114
03 WRX (NAVY Camo)
in"Special Ed." Run Group
Remove the front grille and you'll see some black body clips, remove those.
Remove both driver's and passenger side headlamp assemblies and remove the black body clips underneath/beside the headlamps.
Now the important two that many forget about..behind your forward fender sections of the front wheels are two body clips (1 per side) that secure the ends of the front bumper to the metal fender above. You can usually push the plastic fenderwell out of the way enough for access but it's tight (look for the square notch in the fender by the fender/bumper seam..the body clips are just behind those).
Once you have all the clips out, gently pull the bumper out at both sides of the fenders to unclip a hidden slide bracket at the bumper to fender seam and the bumper should come right off. Here's a clip with some info for you.....
I'll check on the FEnder stuff in a moment...here you go
skimobile is offline   Reply With Quote
Old 08-29-2009, 01:51 PM   #3
GenoaWRX9
Member#: 212459
2012 sti wrb
rip: 95 and 02
^^^^ and where did you get that picture?
ok well i have the headlights grille bumper removed right now.. so where do i go from here? sorry that post confused the **** out of me
Old 08-29-2009, 01:52 PM   #4
GenoaWRX9
Member#: 212459
2012 sti wrb
rip: 95 and 02
and again i'm looking to remove the fender
Old 08-29-2009, 04:11 PM   #5
GenoaWRX9
Member#: 212459
2012 sti wrb
rip: 95 and 02
moar help please
Old 08-29-2009, 04:25 PM   #6
cash1220
Member#: 156342
what dont you understand from the instructions posted above? remove side sill, mud gaurd, and bumper cover and the four bolts holding the fender should be exposed. removing the bumper cover should be more difficult than removing the side sill or the mud gaurd and you already did that.
cash1220 is offline   Reply With Quote
Old 08-29-2009, 04:38 PM   #7
GenoaWRX9
Member#: 212459
2012 sti wrb
rip: 95 and 02
ok i didnt see he added stuff in for the fender. i have all the bolts off on the top and side of the fender. removed mud flaps and all that. the side sill.. is that the side skirts just another word for it? cause it moves comletely off except for down by the side skirt. i'll check again but i wont be able to post again til tomorrow i have to go to work. thanks you ski mobile and where exactly are you getting those diagrams from?
Old 08-29-2009, 04:40 PM   #8
GenoaWRX9
Member#: 212459
2012 sti wrb
rip: 95 and 02
and the only bolts i could see were the four on the top in the engine bay one behind the headlight and two in the door frame.
Old 08-29-2009, 06:57 PM   #9
skimobile
Member#: 92114
03 WRX (NAVY Camo)
The shots are select prints from the Subaru repair manual.
You should really invest in one if you plan on doing work yourself.
It will really help.
Old 08-29-2009, 07:38 PM   #10
Jimba
Member#: 221498
06 WRX
Call your local salvage yard. Tell them you need a fender, give them your paint code. {should be on your vin stiker on your center pilar). You have to drop your front bumper cover, don't worry they are all push clips, remove your hedlamp with a 10 mm socket and there are 3 10 mm bolts on the inner channel of the fender under the hood. There is 1 in the channel when you open your front door and look @ your lower fender in the jamb.
Let me know how you turn out....
Jimba is offline   Reply With Quote
Old 08-29-2009, 10:19 PM   #11
GenoaWRX9
Member#: 212459
2012 sti wrb
rip: 95 and 02
how much would one of those repair manuals be? and would i just get it at a dealer? cause i hate taking little things to the dealership just to get raped on a price. i have many friends that used to work at a dealership and would help with paint/install if needed. i plan on calling the salvage yards on monday idk if they are open on sundays
Old 08-30-2009, 10:28 AM   #12
skimobile
Member#: 92114
03 WRX (NAVY Camo)
Old 08-31-2009, 04:20 PM   #13
GenoaWRX9
Member#: 212459
2012 sti wrb
rip: 95 and 02
ok fander is off the clips on the side skirt were the most frustrating part. thanks again for the help everyone
Old 04-07-2015, 08:54 PM   #14
Openboater
Member#: 337759
2002 Impreza WRX
Ok. I just did this. Les than 25 min to take off and put on. Pop the plastic clips/parts apart carefully.
Openboater is offline   Reply With Quote
How To: Remove eyelids/clean headlights SacksLax Interior & Exterior Modification 6 02-08-2009 01:38 AM
How to remove/install fender? cboylekc Service & Maintenance 4 06-16-2008 01:37 PM
how to: remove stock 07 wrx knob? CGM6 Interior & Exterior Modification 5 11-12-2007 12:38 PM
removing front fender drkramm Interior & Exterior Modification 1 10-24-2007 01:15 PM
How To: Remove Stock Radio MY05 Matth3w Car Audio, Video & Security 36 10-06-2006 03:01 PM
