Welcome to the North American Subaru Impreza Owners Club Thursday June 21, 2018
Old 11-02-2017, 05:21 PM   #1
pedu123
Member#: 460290
Question remap after decat
I eliminated the cat in my Impreza of the 2002 sti and I have to remapped to avoid turning with higher turbo pressure and risking it detons.
What tables should I vary and how should I change them?
pedu123 is offline   Reply With Quote
Old 01-22-2018, 04:37 PM   #2
Nettalp
Member#: 93812
2004 Wrx wagon
Platinum Silver Metallic
Since you opened up the airflow in your exhaust without any calibration your going to experience boost spiking and possible leaning out. I'd start by reducing waistgate duty cycle in the appropriate RPM cells to counter the boost spiking.
Nettalp is offline   Reply With Quote
Old 01-28-2018, 07:26 AM   #3
kein0303
Member#: 459380
After decat you need to put a Wideband o2 sensor on your downpipe and do a log to analyze your air fuel ratio.
You need also to put the original rear sensor at the free air.
After correct your primary open loop fueling or your boost target maps and WGDC map depend of your logs.
For SP98 with TMIC the ideal air fuel ratio is between 10.5 and 11.
kein0303 is offline   Reply With Quote
