Welcome to the North American Subaru Impreza Owners Club Wednesday June 20, 2018
Old 11-22-2017, 12:05 PM   #1
Nettalp
Member#: 93812
2004 Wrx wagon
Platinum Silver Metallic
Default Closed Loop to Open Loop Wavy
Hello fellow suby friends,
Looking to get some insight on the next step for my Rom. I basically have a stage 2 Rom that I have been tweaking myself with the help of the forum. I am still learning as we all are but now I am in need to ask for help to get to my next goals.
Goal 1: Smooth my AFR curve, See graph.
I want to setup the car and make it run smooth before I start adding more power. Currently running 16lbs on the TD04 turbo.
Car: 2004 USDM wax wagon MT
Fuel: CA 91 Octane (Socal)
Elevation: 39 ft (Sealevel)
Weather: Currently 60-70 degrees
Humidity: 60%-70%
Mods:
TD04 Turbo (Stock)
Gutted STI Downpipe
Sti Catless Uppipe
Oem Header (Port and Polished)
Greddy 3 inch exhaust
Grimmspeed EBCS
Walbro 255 Fuel Pump
Stock Intake
Stock Injectors
Stock Intercooler
Gauges:
AEM Wideband
Defi EGT, Boost, Oil Temp
Thank you everyone in advance as the community rocks! I am having fun and enjoying the process.
graphs below:
I addressed the knock already as this learning view is a week old.
Nettalp is offline   Reply With Quote
Old 11-22-2017, 12:08 PM   #2
Nettalp
Member#: 93812
2004 Wrx wagon
After the above I then zeroed out my CL to OL Transition table and it seemed to help but still need to figure a way to smooth my AFR.
image hosting facebook
Old 11-22-2017, 09:13 PM   #3
ShinjiML
Member#: 257231
2011 STI ShinjiTuned
Did you log to see when it's actually in open loop? i.e 8 vs 10 in CL/OL status. Could also be the front O2 acting up.
Also you have a bunch of areas pulling timing, including in the higher loads, have you tuned the timing table yet? If not, I would recommend addressing the the knocking areas first.
ShinjiML is offline   Reply With Quote
Old 11-23-2017, 01:14 AM   #4
Nettalp
Member#: 93812
2004 Wrx wagon
Hi ShinjiML,
I did address the knock as stated above, my total timing is pretty smooth and conservative. But regarding logging CL to OL status, the during the wavy parts in the beginning it displays 8 for CL.
Regarding the sensor, it possibly could be but hopefully not the case.
Any elsewhere to look at in the ROM?
Old 11-28-2017, 11:32 AM   #5
fenix-silver
Member#: 231700
2004 WRX Wagon
what CL/OL delay are you running?
fenix-silver is offline   Reply With Quote
Old 11-28-2017, 11:56 AM   #6
Nettalp
Member#: 93812
2004 Wrx wagon
The whole table is zeroed if your pertaining to the 16 celled table?
Old 12-08-2017, 01:56 AM   #7
Nettalp
Member#: 93812
2004 Wrx wagon
Bump..up
